Results 1 to 17 of 17
    Aug 27 2008
    Houston Area
    USP Intake owners - check your fiter...
    So granted this intake is about 2.5 years old, but has been on and off the car - with a total of maybe 15,000 miles of use...
    Was inspecting it and the top looked only slightly dirty...
    ...but I thought I'd take it off and clean it ...
    once I got it off, the bottom looked like :
    The element has partially disintegrated. Way past due for a replacement I guess. The reason for the post is that when installed, none of this was visible - the filter looked fine from the top - so take the filter off to inspect the whole thing. There was/is no damage to the mesh - it's just the filter element.
    Last edited by B8_Jim; 07-08-2017 at 06:55 PM. Reason: rehosted original photobucket images
    Senior Member Two Rings lowjonathan's Avatar
    Jun 30 2015
    yes, my CTS 1 year old 20k km air fliter suffer the same fate as well
    i swop to blitz stainless steel fliter solved this issue once for all
    Volk racing G25
    KW v3
    Hotchkis ARB
    034 adjustable upp arms
    034 tranmission inserts & mount
    Uprated front bushing.
    CTS intake kit
    CTS SC pulley
    KI 184mm crank
    Custom tuned with DSG remap
    Veteran Member Three Rings chopz33's Avatar
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    Guess I'll be doing this today. Thanks for the heads up
    2012 S4/ Prestige/ Black Optics Package/DSG/Red Leather/B&O sound
    KW HAS/RS4 grille/LED conversion/USP Intake/AWE Touring-resonated DP's/034 trans mount/Niche Stacatto 20x9/CF Stvbek front lip/Unitronic Stage 2 ECU/TCU/ECS CF diffuser/CR-15 Strut brace
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Same thing happened to me, but I didn't make a big deal about it because I bought used and couldn't confirm it was the original USP provided filter. Definitely not happy with the way this dry filter wears, switched to an oiled filter after this. Yours is much worse shape than mine was too
    2021 Audi S4, P34 Intake
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    USP running a dry filter?
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    Has anyone checked in on ecs filter over time?
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    Got 4 replacement filters from Roc-Euro during sales event and always replace it every 5K with oil change... just my 4 cents
    2013 S5 Build Thread
    2001 S4 Avant
    2017 Ducati Monster 821
    Instagram
    Gone but not forgotten:
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Jun 28 2016
    US
    That's not a dry filter. It's a cheap copy of a K&N wannabe. Go find yourself a similar sized AFE dry one and be done with it. Might also want to call USP and let them know they may want to not be so cheap on the filters. That is a serious issue there... not only is the filter material pulled into the intake and then engine, but other foreign particles will now enter as well. Keep in mind that damage from debris and sand or anything else that's small enough to go through that can cause more damage to the supercharger impellers (due to close tolerances) than it would if the engine was NA. It's not a good thing to happen. Get a real filter.
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by rtl5009 View Post
    No but I will be checking it when I do an oil change next month. I had the same issue on my CTS Turbo intake filter after ~9000 miles of use which was very disappointing. It would be nice to know the brand/manufacturer of these filters so we could all avoid them in the future.
    SOLD 2015 Daytona Gray S4
    Established Member Two Rings iviegatron's Avatar
    May 15 2015
    Texas
    Can a K&N air filter fit over the CTS Turbo intake tube? If so, would it affect the supercharger whine (sound level)?
    Current Cars: 2014 Audi S4 Ibis White; 2005 Toyota Camry (Daily Driver)
    Previous Cars: 2000 Audi TT, 2006 Audi A4, 2009 Audi A6, 2010 Nissan 370Z, 2011 Mitsubishi Evo X
    Wish List: Lamborghini Huracan, Porsche 911 Turbo S, Nissan GTR, BMW M3/M4
    Jul 05 2016
    Ontario
    The noise is fun, but I don't get why anybody would put a shitty filter in front of a $15000 engine. Even with the "good" filters, I've ruined MAFs with both the oil and silicone coatings they use. No MAF in the S4 of course - but still, lesson learned for me... Sucking chunks of cotton or foam through your super-expensive engine and supercharger (plus a bunch of dust, sand, leaves and bugs because the filter isn't a filter anymore) isn't going to be fatal, but it's also ranks a solid zero on the "good idea" scale. Sucking in chunks of the wire mesh could make for a super shitty day.
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by jonwoods View Post
    I think the point here being, we trust when a paid AZ sponsor offers a $300-$400 intake, that it should come with a quality filter...
    I immediately switched to an oiled filter I have experience with once I noticed the condition of my own USP intake.
    Jul 28 2009
    Philadelphia PA
    These cars are speed density, no maf. Perfect for an oiled filter
    c8 a6 allroad
    Jun 23 2014
    US
    Can I ask which filter did you end up using in replacement of the filter provided with the USP intake. Brand and style# as this would greatly help.
    Thanks
    Jun 23 2014
    US
    Any details on the part number for the upgraded filter?
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    Checked my USP filter when I removed my intake yesterday. It's about a year old and still in excellent condition.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Jul 20 2016
    Checked mine after about 6 years. There is 1 section with a little bit of damage? Would this need to be replaced?
