    Established Member Two Rings leightonw's Avatar
    Aug 12 2016
    Soldotna, Ak
    Light white smoke and oil burning smell
    I'm just wondering if anyone else has had this issue. The compression on all 4 cylinders are near perfect at 132k miles, spark plugs changed, oil changed 1k miles ago and still at the perfect level, coolant level perfect. I removed valve cover to check for any milky oil, nothing. It doesn't and has never overheated. When revving and prolonged driving then idling it emits faint white smoke from exhaust and can smell burning oil. Any thoughts?
    Sent from my SM-G925I using Tapatalk
    Active Member Two Rings WOT's Avatar
    Apr 18 2016
    A few!!
    Elizabeth city, North Carolina
    When I bought my a4 I had same issue... turned out to be turbo, then I had over heating and it was the head. Bought a head from rai motorsport and week later I noticed it was still leaking coolant and had to buy used engine.
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Aug 12 2016
    Soldotna, Ak
    So it was the turbo? Would some oil dripping out of outlet side be a sign it's bad, just enough to see oil on that side.
    Apr 18 2016
    A few!!
    There shouldn't be any lubricants dripping from anywhere.
    Aug 12 2016
    Soldotna, Ak
    Well damn, time to replace the turbo for a better and bigger one, lets see the wife handle that one lol.
