Results 1 to 21 of 21
    May 30 2015
    2012 Ford Fusion (wife's car)
    Wellman,Tx
    Bought a set of retrofitted lights.. Question
    What are the red/black wires for? The come from inside the light?
    Maybe auto leveling motor
    The lights were retrofitted using the Retrofit source parts.
    I'm getting new bulbs and ballast.
    Oct 24 2015
    Perth, WA
    Need more information, but they're definitely power.
    My respray thread
    May 30 2015
    Wellman,Tx
    They were halogen lights to start with.
    The guy had it plugged in to the healight socket.
    When I plug in the ballast( tht came with) there is no room for those.
    The come from somewhere in the headlight but behind the reflective portion
    I had them cracked open but didn't see a motor
    May 20 2014
    e92
    Possible bixenon function. Check if they are coming out projector. You can even put 12v to them and see if the projector flap opens.
    Veteran Member Four Rings yungcotter's Avatar
    Jun 10 2010
    Queens
    Those are definitely the bi xenon flap. They should be plugged into the the hi beam. When I did my retrofit I soldered that into the back of the connector for the high beams.
    Sent from my iPhone 6s using Tapatalk
    -Theo
    2018 S4,Florett Silver, Magma
    2014 Q5, Phantom Black Pearl, Chestnut, 2.0T,Moms Ride
    2015 S4, Daytona Gray, DSG,Gone
    06 A4 2.0 T, Quartz Gray, Quattro, Tiptronic.
    May 30 2015
    Wellman,Tx
    Quote Originally Posted by yungcotter View Post
    Ok
    How does one use the high beam then
    Do I just put a light in the spot for looks
    May 30 2015
    Wellman,Tx
    Never mind..
    I guess I just put a light in for looks??
    Jun 10 2010
    Queens
    Quote Originally Posted by fhh02a View Post
    Ok
    Rite now the high beam will be the halogen bulb. If you wire it up to the high beam bulb it will activate the flapper instead. I wired it so I go t both the halogen and bi xenon to work. Mostly so that I could flash people with out the headlights being on and it's just more light. Let me see if I can find pictures tomorrow of how I did it.
    -Theo
    May 20 2014
    e92
    There are many ways to wire them for bixenon.
    -Easiest is to tap the high beam wires.
    -Best/OEM way is to extend those wires to power module. This way you get push/pull high beams on the bixenon and your high beam bowl bulb works (can be) DRL. I set up mine that way with led bulbs in the high beam bowl so they are on all the time and high beams are only projectors. Flash to signal works just as fine by turning on the xenons and opening the flaps when you pull the stalk. Follow phil's Diy for the proper wiring and pins.
    May 30 2015
    Wellman,Tx
    I guess I can tap the flapper motor wires into the high beam wire
    And still run high beam?
    May 20 2014
    e92
    Yes. You can. Not OEM functionality but still functional. My post above describes the OEM way to do it.
    May 30 2015
    Wellman,Tx
    I meant.. Tap the wire and still put the bulb in
    May 20 2014
    e92
    Yah. That will work. High beam bulb lights up and the bixenon flap opens when you flash to pass or high beams. That's how I wired it on my other car, but with b7 I went OEM style because it's not difficult to run the wires. Just connect the the ground wire to the ground in the headlight, run the positive wired to the module inside the firewall. Done.
    Veteran Member Four Rings tcm glx's Avatar
    So Cal
    Little late to answer, but above guys are correct. Those are the trigger the high beam on the projectors, tap into the high beams and you will have some great High Beam power, essentially using the projector and the halogen for your high beams. It's a great setup.
    2013 Audi Q5 2.0T Premium Ibis White/Chesnut Brown
    2018 Audi Q7 3.0T Glacier White/Nougat Brown
    Senior Member Three Rings killerb7's Avatar
    Apr 27 2009
    05.5 A4 2.0T 6MT
    Orange County, CA
    All you need is a simple H7 splitter cable, no need to cut into any wires.
    Should be very easy to find online, Retro Fit Source has one for $5 plus shipping
    https://www.theretrofitsource.com/co...l#.V8PwavkrK00
    (should be second one from the drop down menu "H7 male/ H7-9006 female")
    Retro Fit Lab has a video that should help getting a good visual for how the xenon wiring is connected @ 4:12 minutes into the video
    https://youtu.be/W6UvaSYdeDo
    May 30 2015
    Wellman,Tx
    Sweet thanks killerb7
    Veteran Member Three Rings supple's Avatar
    Jan 27 2016
    I don't have a garage
    Woburn, MA
    fly has a DIY in here thats for a halogen to Bi-xenon retrofit. Part of that kit are 2 long wires (1 from each assembly) that are supposed to be routed under your driver wheel well and into your dash. You can then plug those into the connector and you will have High Beam to use on your Bi-xenons. It's easy to install if the wires are long enough.
    2013 S4 Monsoon Grey | APR Stage 2 Single Pulley | Roc Euro Intake | 034 RSB + Drivetrain Inserts + Control Arms | CR-15 | KW V1
    RIP 2007 Brilliant Black A4 Quattro | Unitronic Stage 1+ | Bilstein Sport + H&R Sport | Apikol Snub | GFB DV+ | 034 Turbo Inlet, Street Density Motor Mounts, RSB & End Links, Control Arms | Pipercross Filter
    May 30 2015
    Wellman,Tx
    do i need the anti-flicker cap?
    May 30 2015
    Wellman,Tx
    trying to buy this week
    May 20 2014
    e92
    Why would you buy anti flicker cap? I don't even know what it is? Just code your car to accept xenons.
    I sent you a pm some days ago with links to DIYs. Not one says anything about anti flicker cap.
    May 30 2015
    Wellman,Tx
    I looked at the DIYs
    And thank you for the links.
    Phil even said get the resistor. To anti flicker
    https://www.theretrofitsource.com/co...l#.V8egrom9LCQ
    Sense I'm plugging and playing.. And using a high beam splitter,
    No coding to be done, is Wht I am gathering
