Results 1 to 2 of 2
    Jul 08 2015
    Meridian, ID
    Alternator or Voltage Regulator Problem
    I had my battery light come on while driving and tested the battery and alternator. The battery was fine, so being cheap, I decided to just replace the voltage regulator. After replacing it, I have a god awful noise coming from the voltage regulator, and the battery light is still on. It's definitely not a belt squeal. Here's a short video:
    https://drive.google.com/open?id=0B3...WNVejBvc1hBVlU
    Maybe I didn't install it right? Seemed pretty straight forward...
    Active Member Two Rings wagongang's Avatar
    May 25 2016
    1999 Audi A4 Avant 1.8t (totalled)
    Neenah, Wisconsin
    While you're driving does the battery voltage ever jump up? My light would come on while driving but voltage would spike sometimes. Better yet and alternator tested fine. I replaced the alternator with one I had lying around and it worked fine.
    Sent from my SM-G930V using Tapatalk
    Watch out for drunk drivers...
    they'll total your car.
