Results 1 to 7 of 7
    Apr 15 2016
    Sydney
    Can the OEM drivetrain parts handle regular hard driving?
    So it's time for me to replace a few components of my 6MT S5 (engine mounts, flywheel, clutch). I like to drive "hard". I.e. fast accelerations around corners, quick down/upshifts, etc. I don't drive it much (weekend car), I'll maybe take it to red line once or twice a week.
    Wondering if people have any comments on the following:
    1. Replacing the fluid filled mounts with a solid one from 034 Motorsports
    2. Replacing the dual mass flywheel with a single mass lightweight from (ecstuning)
    3. Heavy duty clutch kit (southbendclutch)
    The OE parts obviously provide more comfort and smooth shifting, but can they handle rough driving (longevity wide)? Do the performance parts give better longevity, or are they purely designed for performance? I don't mind a bit of extra vibration, but really don't want rough shifts between gears when cruising.
    Thanks
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    As for clutch kit, this is the way to go:
    https://jhmotorsports.com/shop/catal...21_276_277_280
    Thread end.
    2013 S5 Build Thread
    2001 S4 Avant
    2017 Ducati Monster 821
    Instagram
    Gone but not forgotten:
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Apr 15 2016
    Sydney
    Didn't really answer any of my questions though..
    Established Member Two Rings brunogomes's Avatar
    Apr 21 2015
    New Jersey
    OEM parts should handle spirited driving just fine on a OEM S5.
    The issue is when you start adding more torque/hp from things like tune and pulley upgrade. The OEM clutch can't really handle many launches and it will start slipping after some time. At that point you should consider a stage 3-4 clutch and LWFW.
    You can still achieve OEM like drivablity/comfort with aftermarket upgrades.
    Hope this answer your question....
    Senior Member Two Rings jwr9152's Avatar
    Apr 08 2015
    Pensacola, Florida
    I think what you listed are the only real weak points of this car. I had to replace my motor mounts with 034. Like them a lot and don't notice any extra vibration, and they should last longer. I wouldn't just change them to change them. Wait until the oem motor mounts go out.
    As far as clutches, if you go with southbend or jhm they have their own single mass flywheels that go with their clutches. Not sure how the oem clutch and flywheel hold up to a stock car, but they were no where near up to the task with a modified car. In my opinion the main problem is the oem pressure plate. The southbend stage 3 has an upgraded pressure plate and the JHM R3 series clutches have upgraded pressure plates.
    2011 S5 6 spd 4.2 V8 with APR stage 3 supercharger, APR tune, B&B exhaust, Bilstein PSS10 B16, 034 strut mounts, SPC adjustable control arms, USS sway bars and end links, JHM lightweight flywheel and clutch, Meisterwerk short shifter, 034 transmission mount, Stoptech BBK, carbotech xp12, alu kreuz, 034 intake, apikol differential mount, AWE S-flo filter, cr-15 strut brace, Advanti Hybris 19X9.5, Michelin Sport Cup 2 275/35/19. USP RS5 grill. 034 Motor Mounts
    Oct 17 2012
    NoCal
    Since you do care about the "longevity", then why would you want dat clutch kit and LWFW from different brands?
    I would go with solid proven route if I were you, especially u are outside of U.S (shipping cost)
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Aug 19 2008
    US (Al.)
    I killed a power steering pump and the front suspension bushings by driving aggressively in N. Ga. and E Tenn. Brakes take a beating too but so far no issues (stock calipers with Tyrol stiffening kit, EBC reds and BrakeTech rotors). Everything else seems to be holding up fine (stock clutch, flywheel and engine mounts)
