Results 1 to 27 of 27
    Dec 07 2014
    Mn
    Engine Torque Monitor 2 (P1335)
    Has anyone else seen this fault code or know anything about it? I was giving it steady throttle as I was rounding the on ramp, then once I started to accelerated a little harder to merge it popped the EPC and went limp. The gear selector showed "S7" for the first time ever and the gas pedal was totally dead. Pulled over and restarted and all worked fine.
    2014 S4 DSG///Unitronic Stage 2+.
    Dec 07 2014
    Mn
    Sent from my LG-H901 using Tapatalk
    Aug 23 2015
    Texas
    I'm going to contribute my guesses based on other VW/Audi models:
    -Dirty MAF
    -Carbon buildup
    -Tune needs updating
    You can search on Google for "Audi p1335" or click the link below:
    http://bfy.tw/7QR6
    Jun 28 2016
    US
    No MAF on B8+ S4's.
    Aug 23 2015
    Texas
    Quote Originally Posted by SwankP3RF3ct10n View Post
    No MAF on B8+ S4's.
    Fair enough
    So carbon buildup or tune related
    Dec 07 2014
    Mn
    I found the explanation of the code in the Ross Tech site and looks like it could be Intake related. I'll have to take a closer look later after work.
    Carbon seems unlikely since its a 2014 with 20k miles.
    Senior Member Two Rings SeniorCypress80's Avatar
    Nov 09 2016
    01 A4, 01 S4
    Indianapolis
    Ever diagnose what’s this was? I just had p1335 limp me out while on a spirited drive.
    Aug 27 2018
    phoenix, az
    Had the same thing happen to me yesterday on the freeway. Luckily there wasn't too much traffic at the time. I took some logs and sent them off to the tuner to see if it is related to the stg ii I just flashed.
    Nov 09 2016
    01 A4, 01 S4
    Indianapolis
    Quote Originally Posted by midnitemass View Post
    Weird, are you on 93 big TB file? Iv never had this but always ran e40 file. Did yours happen getting on freeway? There is not a lot of documentation I’m seeing for this code but the couple mentions seemed to be while Corning w/ throttle. Mind sending me your log?
    Aug 27 2018
    phoenix, az
    91 file. I was just maintaining speed on road, maybe 2500 rpm. The log I sent is about 16mb, but you can take a look and see if anything appears out of the ordinary.
    Dec 07 2014
    Mn
    Quote Originally Posted by SeniorCypress80 View Post
    It was either the supercharger intercooler leak, or rodents that chewed thru some wiring. I don't remember which ailment caused this one, but it was one of those two.
    Sent from my LM-G710 using Tapatalk
    Veteran Member Four Rings UkuRiSh's Avatar
    Jan 09 2010
    New York
    colder air more power ! Most like it you hit TQ limit on tune and your tuner should adjust that... In what area are you locate and what ambient was at that day ?
    2013 AUDI S5 4.0T SWAP 9.7@145mph < Press @svarog_performance < last test updates
    Aug 27 2018
    phoenix, az
    Quote Originally Posted by UkuRiSh View Post
    I'm in Phoenix, AZ. It was probably 70-75 degrees F when it occurred.
    Jan 09 2010
    New York
    you got very low timing 4-9* across all runs, sounds like limp mode or something ! What specs and what fuel ?
    Jan 09 2010
    New York
    also when you tune your car or did you do any new revision of software recently ? Car was runs fine before ?
    Aug 27 2018
    phoenix, az
    Yeah the EPC light came on, so limp mode makes sense.
    IE stg ii DP tune
    KI 206mm crank pulley
    - - - Updated - - -
    Was running stg I and it was running fine. Installed Merc HX and crank pulley this weekend
    Jan 09 2010
    New York
    IE stg ii DP tune
    - - - Updated - - -
    100% tune related ! Holy batman 206mm … You need new revision lol
    Contact with IE and provide them your new upgrades ! I hear only good staff about customer service at IE
    Aug 27 2018
    phoenix, az
    That's what I figured. Emailed them twice since Monday, no response yet. Looks like they are overhauling their ordering portal, and coupled with Black Friday, they are probably overloaded with emails. I appreciate the response from you, my dude!!!
    Jan 09 2010
    New York
    No problem and good luck ! Looking for results.... I want big 200mm+ on my Q7
    Aug 27 2018
    phoenix, az
    so what's the best practice while I'm waiting for IE to sort this out? just roll the dice, or revert to stg I?
    Nov 09 2016
    01 A4, 01 S4
    Indianapolis
    Any updates on this?
    Aug 27 2018
    phoenix, az
    IE said the had me in line for a tune revision...waiting on that.
    Nov 09 2016
    01 A4, 01 S4
    Indianapolis
    Damn, so that means I’m ever further away from resolution. I am still waiting on the email to tell me I’m in line for new revision.
    Did they offer up any information or suggestions for the time being? Are you still driving your car?
    Aug 27 2018
    phoenix, az
    I reverted back to stg ii and it seems fine, but I have been driving my q5 in the meantime. Getting EPC light and losing power on the freeway is not something I want to happen in the near future
    Dec 07 2014
    Mn
    Just something to keep in mind, the more I thought about it, this was the initial symptom of my supercharger leaking coolant into the cylinder. Started slow like this, then eventually started getting misfires.
    Nov 09 2016
    01 A4, 01 S4
    Indianapolis
    Quote Originally Posted by brianc21 View Post
    I JUST replaced mine less than 1k ago with new v2 OEM. I can safely say on my car this isn’t the problem. But yes you are 100% correct, my car was doing this all the time when it was leaking from ICs. However the logs and codes are completely different. I was seeing misfires which resulted in EPC mode this didn’t have and misfires saved and a new code of the P1335, which I’m finding very little documentation of.
