Results 1 to 1 of 1
Thread: P10AE
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    P10AE
    Putting this in the general 2.0T section incase someone outside of the B8 A4 forum has an answer.
    Scanned for codes this week and found P10AE. It comes up as wiring malfunction with the supercharger clutch. Obv, I don't have a supercharger.
    Car was running great last week with the k04 installed and GIAC stage 2 software. Dropped it off Sunday night to have the K04 software added and Tuesday when I drove it, I could only hit 16psi in most gears. I did find that the diverter valve had come unplugged, but even after fixing that, the boost is still low and the code won't go away.
    I'm getting a new file from GIAC that has a higher N75 duty cycle, thinking that is the low boost issue, but there is a small chance that it has to do with this code.
    Anyone came across this before?
    My theories are:
    1. It has to do with the DV and won't clear with a scan tool.
    2. The DV being unplugged blew some fuse.
    3. Some other wire to the DV or N75 is damaged.
    4. Somehow caused by the underboosting and the ECU doesn't know what code to throw.
    5. Has nothing to do with the turbo and is a water pump code (this comes up in google too).
    I've read every link I could find in google on this code, even translating foreign forum discussions. They all talk about cars with superchargers. Wait:
    6. Somehow I got a S4 tune loaded earlier this week. ;-)
    Edit:
    P10AE was the code Carista sent. VCDS read a different code.
    looks like an underboost code caused by the tune or caused by the DV being unplugged
    Saturday,27,August,2016,12:15:34:18225
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 16.8.0.3 (x64)
    Data version: 20160803 DS255
    www.Ross-Tech.com
    VIN: WAUHFAFL2AN042101 License Plate:
    Chassis Type: FL (8T0)
    Scan: 01 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 55 56 62 72 77
    VIN: WAUHFAFL2AN042101 Mileage: 177190km-110100miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (DL0MA-CAEB) Labels: 06H-907-115-CAB.clb
    Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D
    Component: 2.0l R4/4V TF H16 0001
    Revision: E1H16---
    Coding: 0104010A180F0160
    Shop #: WSC 63693 000 16448
    ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
    ROD: EV_ECM20TFS0118K2907115AL.rod
    VCID: 79F9CE49F89E638AE7-802C
    1 Fault Found:
    4270 - Turbocharger Bypass Valve Control Circuit
    P0033 00 [104] - Malfunction / Open Circuit
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 3
    Mileage: 176813 km
    Date: 2016.08.22
    Time: 16:51:41
    Engine speed: 243.00 /min
    Normed load value: 37.3 %
    Vehicle speed: 0 km/h
    Coolant temperature: 30 °C
    Intake air temperature: 30 °C
    Ambient air pressure: 990 mbar
    Voltage terminal 30: 11.120 V
    Unlearning counter according OBD: 40
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
    Part No SW: 8K0 907 379 CA HW: 8K0 907 379 CA
    Component: ESP8 quattro H04 0010
    Revision: -------- Serial number: --------------
    Coding: 074D18
    Shop #: WSC 02391 823 56573
    VCID: 7AFBD145F5986892EE-802E
    No fault code found.
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 DG HW: 8K0 907 064 DG
    Component: BCM2 1.1 H02 0326
    Revision: 00002001
    Coding: 0B0100
    Shop #: WSC 02399 823 56573
    VCID: 78FFCB4DCB947A8298-802C
    Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
    Component: FBSAUDIB8 IDG H37 0060
    Serial number: 0509000070976004
    Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: J764 ELV MLB H37 0042
    Serial number: 0209000092404013
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
    Component: KLIMA 3 ZONEN H08 0171
    Revision: C1000000 Serial number: 01041220091791
    Coding: 64002000
    VCID: 000FA3AD93443242A0-8054
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
    Component: BCM1 1.0 H25 0380
    Revision: 10025001 Serial number: 00000000410846
    Coding: 260012910034AF310700000300003D0D4F1C12080001016100 0000
    VCID: 3C77175DBF2C96A2BC-8068
    Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 041209 H06 0070
    Serial number: SWF09120046317
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0003
    Serial number: 10704017
    Coding: 025028
    Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
    Component: E1 - LDS H08 0090
    Serial number: 00000000000212091910
    Subsystem 4 - Part No SW: 8K0 907 410 B HW: 8K0 907 410 B
    Component: HOMELINK H01 0010
    2 Faults Found:
    03110 - Active Steering Control Module (J792)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 79
    Mileage: 177194 km
    Time Indication: 0
    Date: 2009.06.26
    Time: 00:18:00
    03207 - Charisma Switch Module
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 79
    Mileage: 177194 km
    Time Indication: 0
    Date: 2009.06.26
    Time: 00:18:00
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 H HW: 8K0 959 655 H
    Component: AirbagVW-AU10 H39 0560
    Serial number: 003EGD05B7G%
    Coding: 303836354230303030304A55304C384B3053
    Shop #: WSC 02135 785 00200
    ASAM Dataset: EV_AirbaECUVWAUDI010 003010
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    VCID: 428B69A5D5C8E052F6-8016
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
    Component: BF-Gewichtss. H01 0030
    Serial number: 5810000R0900005BDX
    Crash sensor for side airbag: driver side:
    Serial number: 6334MSME4E616264G
    Crash sensor for side airbag: front passenger side:
    Serial number: 6344MSME4D722574I
    Crash sensor for side airbag: rear: driver side:
    Serial number: 6352QSME6544440CG
    Crash sensor for side airbag: rear: passenger side:
    Serial number: 6362QSME0646230ED
    Crash sensor for front airbag: driver side:
    Serial number: 63732SME3D45493A7
    Crash sensor for front airbag: front passenger side:
    Serial number: 63832SME38452D10-
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
    Component: Lenks.Modul H16 0014
    Revision: -------- Serial number: 90304IL4000I2
    Coding: 000016
    VCID: 3D711A59A4369FAA8B-8068
    Component: E221 - MFL H02 0003
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 950 E HW: 8K0 920 950 E
    Component: KOMBIINSTR. H20 0255
    Revision: 00100000 Serial number: CIM14UVC9
    Coding: 931D09000300D705020000
    VCID: 31693669686E6BCA1F-8064
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 R HW: 8T0 907 468 H
    Component: GW-BEM 5CAN H06 0105
    Revision: GB600050 Serial number: 5000G09C0381E4
    Coding: 00C303
    VCID: 50AF53ED03A402C270-8004
    Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
    Component: J367-BDM H06 0170
    Serial number: 1909E9D6301109
    Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
    Part No SW: 8T0 035 785 A HW: 8T0 035 785
    Component: SG ext.Player H08 0280
    Revision: 00000000
    Coding: 020302
    VCID: 39790E49B01EA38AA7-806C
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
    Component: TSG FA H11 0306
    Revision: Serial number: 0000009724446
    Coding: 011C03204000410001
    VCID: 458172B9CCE6D76AD3-8010
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0124210371
    Coding: 0106063A007A44440330013200000000
    Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
    Component: GTO BF H06 0050
    Serial number: 00000000000000202851
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
    Component: J245 PS037 H06 0041
    Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
    Part No SW: 8T0 035 223 AH HW: 8T0 035 223
    Component: DSP STD H07 0230
    Revision: S2200000
    Coding: 0203010102
    VCID: 74E7FF7DD7FC1EE2B4-8020
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
    Component: TSG BF H11 0306
    Revision: Serial number: 0000009771134
    Coding: 011C03204C00410001
    VCID: 44876FBDC7DCEE62C4-8010
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
    Component: EPB Audi B8 H09 0100
    Revision: 00000003 Serial number: 10000000388729
    Shop #: WSC 00000 000 00000
    VCID: 34673F7D977C5EE274-8060
    Address 55: Headlight Range Labels: 8K0-907-357.clb
    Part No: 8K5 907 357
    Component: Dynamische LWR H01 0010
    Revision: 00000001 Serial number:
    Coding: 0000004
    Shop #: WSC 02145 785 00200
    VCID: 77FDC871068A75FA91-8022
    Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
    Part No SW: 8T1 035 186 R HW: 8T1 035 186 R
    Component: Con3 Sirius H04 0351
    Revision: 00000006 Serial number: AUZ5Z6I1323731
    Coding: 04020002010185004359070800
    VCID: 468375B5F1E0DC72DA-8012
    Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E
    Component: Display
    1 Fault Found:
    02635 - Tuner Not Enabled/Activated
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 79
    Mileage: 177194 km
    Time Indication: 0
    Date: 2009.06.26
    Time: 00:18:55
    Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
    Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
    Component: TSG HL H10 0306
    Revision: Serial number: 0000102481463
    Coding: 010C03204000210001
    VCID: 428B69A5DDC8E052F6-8016
    Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
    Component: TSG HR H10 0306
    Revision: Serial number: 0000102481471
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8T0 862 336 D HW: 8T0 862 336 D
    Component: FSE_256x BT H39 0600
    Revision: 00000000 Serial number: 00000005064052
    Coding: 0010370
    Shop #: WSC 02156 785 00200
    VCID: 3C77175D7F2C96A2BC-8068
    End-------------------------(Elapsed Time: 03:06)--------------------------
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
