    Mar 04 2011
    New Jersey
    Any experience with Bilstein B6 on stock B8 suspension?
    My 2011 Prem. Plus with 84K miles on stock suspension is leaning a bit more in corners (ever so slightly). So, I think it's time for new struts/shocks. I want to maintain near-stock ride compliance, but want less lean/more control in turns/corners as I do like taking turns a bit aggressively. Based on some research, I think Bilstein B6 struts/shocks are the way to go. I don't mind spending a bit more to get what I want if there is a better option. Does anyone have experience with them or have recommendations? Thanks.
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    If you plan on staying with the stock springs in the future then the B6s are a fantastic choice. To lessen lean in corners even more, pick up a set of sway bars. Zero ride quality difference, much flatter cornering.
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    Quote Originally Posted by Vogz View Post
    Will B6s make the suspension stiffer?
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by yjypm View Post
    They shouldn't. They are a stock replacement. B8s make it stiffer.
    Mar 04 2011
    New Jersey
    My understanding is that B8s are for cars on shorter (lowered) springs. I think I'll try the B6 first and decide if they give me the feel I'm looking for. If they're not enough, I'll look into thicker bars.
