Results 1 to 11 of 11
    Veteran Member Four Rings integroid's Avatar
    Mar 01 2013
    Atlanta, GA
    Parking Brake Malfunction Help
    Ok, so long story short, I damaged my rear caliper while replacing the rear pads. It was my fault I own up to it. So I got a replacement refurb unit. I put the motor on the unit and instsll....bleed all brakes...everything looks fine except now I get a parking brake malfunction when starting the car. I have tried to clear it in vagcom but it immediately comes back on after I clear it. Any ideas? Everything see,s to work fine including the parking brake. Here is the code I am getting. Thanks for your help.
    Saturday,27,August,2016,10:57:53:07357
    VCDS Version: Release 16.8.0 (x64) Running on Windows 10 x64
    www.Ross-Tech.com
    Address 53: Parking Brake Labels: 8K0-907-801-V2.clb
    Control Module Part Number: 8K0 907 801 N HW: 8K0 907 801 J
    Component and/or Version: EPB-4 H01 0005
    Software Coding:
    Work Shop Code:
    ASAM Dataset: EV_ParkiBrake 001028 (AU48)
    ROD: EV_ParkiBrake_VW51.rod
    VCID: 3A7BE69BBD432492AE-806E
    1 Fault Found:
    262656 - No Basic Setting
    B2010 00 [137] - -
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 72
    Mileage: 26418 km
    Date: 2016.08.20
    Time: 21:08:51
    Voltage terminal 30: 12.0 V
    Internal Fault ID: 67
    Vehicle speed: 0 km/h
    Network management state: normal
    Function light in parking brake button: OFF
    Red operating lamp: OFF
    Red warning lamp: OFF
    Green operating lamp: OFF
    Yellow warning lamp: OFF
    Terminal 15 status: On
    RWU: not active
    DSD: not active
    HTR: not active
    ECD: not active
    ACC requested apply: not active
    Auto Adjust: not active
    General Inspection Function: not active
    Internal Parking Brake state: static
    Status of parking brake button: Not operated
    Status ParkingBrake left: Open
    Status ParkingBrake right: Open
    2024 RS3 Kemora Gray
    Jan 13 2014
    nyc
    Quote Originally Posted by integroid View Post
    www.Ross-Tech.com
    Software Coding:
    Work Shop Code:
    1 Fault Found:
    B2010 00 [137] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 72
    Mileage: 26418 km
    Date: 2016.08.20
    Time: 21:08:51
    RWU: not active
    DSD: not active
    HTR: not active
    ECD: not active
    Did you try to go in basic settings and do the function test?
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Sep 09 2010
    Destin, FL
    Jan 13 2014
    nyc
    😒 thats helpful.
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by nycaudi View Post
    😒 thats helpful.
    Again, that's why you post it in the existing thread and build it from there.
    Jan 13 2014
    nyc
    Honestly Your thread was and is doa. Have not seen anything useful in there
    Sep 09 2010
    Destin, FL
    Because people keep posting in the main thread area. People need to post there with all codes to build a page with useful info as stated in the thread.
    Mar 01 2013
    Atlanta, GA
    Thanks for the suggestions.
    Unfortunately I updated vagcom software on my computer which forces a firmware update on the dongle. The language in all of the menus are different. For instance to disengage the electronic praking brake it is now called "start lining change mode". I ran a command called "Start of Operations" and this cleared the code and everything seems to be fine again. I have no idea what exactly this did but I started the command and heard the servos move. Thanks again for your help nycaudi.
    Jan 13 2014
    nyc
    So youre good?
    Mar 01 2013
    Atlanta, GA
    So youre good?
    You...thaks man....
    Jan 13 2014
    nyc
    Kool man. Glad your issue is gone
