Results 1 to 22 of 22
    Jul 29 2016
    AB, Canada
    potential coolant leak
    My coolant overflow tank is steadily dropping. After I let it sit for an hour I go check it and before it was just above min, now this week its about an inch and a half below min. I went and grabbed some G12+ to top it up. Checking what I can see without a hoist I'm not seeing any active leaks, and I'm guessing I wouldn't as it's a pretty minimal amount (maybe 400ml?) thats leaked out. I'm guessing thermo housing? The waterpump and stat were changed 2 months ago.
    2011 S4
    Senior Member Two Rings jwallace0988's Avatar
    May 16 2016
    None
    Rochester, NY
    In my past experience... On my 2012 gti - It was related to the water pump that went bad prematurely. After I replaced that, I still noticed that coolant would slowly have to be added over time. They techs said that it is common... Since the engine consumes the coolant for lubrication purposes. Something along those lines, good luck tho!
    13' S4 - Ice Silver (DSG, B&O, Carbon Inlays, Black/Magma Leather, Sports Diff) - EPL Stg. 1 ECU w/ DSG tune, Roc Euro Intake, DeAutoKey Full LED interior(white), Red (Front floor), LED Exterior lighting (Turn/Reverse). Eurocode poly mounts, Soundakor DELETE!, Xpipe mod, Carista!
    Past: 12' GTI Autobahn, APR Stage 1, CM FX350 w/ flywheel, Magnaflow CB exhaust :: 06' Scion tC: Full Bolt-ons to turbo build at approx. 300 WHP/TQ on 8-10 psi, Konig After-burners, RL Coils, poly mounts etc.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Since you just had the WP and T Stat replaced, there probably was some residual air in the system. It will take a little time for it to work itself out of the system.
    Apr 04 2015
    United States
    I had my overflow tank replaced recently, they pressure tested it for hours afterwards at temp. I STILL need to fill mine once a month and have NO IDEA where its all going! I only fill it when its hot, I fill it to under the max line, within two weeks, its at the low marker at temp.
    no idea! blow-by? where else would it go?
    Veteran Member Three Rings EHesh14's Avatar
    Jul 16 2010
    Colorado
    I wouldn't worry about it if you already did the metal pump and thermostat. I've noticed that I need to add a bit every so often during the colder months and I made sure there wasn't any leaking anywhere. My ams pump was leaking a bit, but somehow it's not anymore.
    Stated above there is probably some air bubbles in the system that's causing this.
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    Just for reference
    When the engine is cold it should be between the “MIN” and “MAX” marks. When the engine is hot it may be slightly above the “MAX” mark.
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Apr 04 2015
    United States
    How would you know if the pump was bad? 2012 S4
    today: Driving around during lunch time. I watch my coolant temps all the time on my P3 gage. The temps are usually between 200-212F. Parked the car and the coolant was POORING out of the overflow tank! I start the car again check the temperature and its 227, within 3 minutes or less, the coolant temps were back down to 190 and the coolant was well below the low line.
    pump? Thermostat?
    Also, the overflow tank low and max marks are hot levels, why would I want it between that when cold? It seems that would surely overflow at all times if I kept it like that.
    Jul 29 2016
    AB, Canada
    thanks for the info
    2011 S4
    Feb 05 2016
    UK
    I'd fill the coolant to half way between min & max when cold
    Have you tried a new expansion tank cap?It could be faulty causing the coolant to overflow at too low a pressure
    Jul 29 2016
    AB, Canada
    Quote Originally Posted by xpoweruk View Post
    I put it about half way on saturday. it seems to be sitting pretty. took a full L of mix to get it there.
    2011 S4
    Apr 04 2015
    United States
    I have a brand new overflow tank. I'm not sure if that comes with the cap or not, but I do know that the coolant was clearly boiling and exiting the overflow.
    Nov 30 2010
    Anchorage, AK
    FWIW I just had my car in for service and to check a coolant leak, I was having the same issue. They found a hose on the bottom somewhere, don't have the notes in front of me otherwise I would specify where, but it had a small leak and needed to be replaced.
    2010 Meteor Gray Prestige //S4 DSG
    Apr 04 2015
    United States
    Quote Originally Posted by mgaman View Post
    Thank you! I think they mentioned that to me at some point too, but then when they pressure tested it..... no issues. I will stop back and have them take another look.
    Although, this doesn't explain my boiling over issue. :/
    Jul 29 2016
    AB, Canada
    dropped below the min mark again when I checked this am (cold).... she's going to the shop tomorrow for a pressure test (and brakes, and springs... and rear diff leak....)
    2011 S4
    Apr 04 2015
    United States
    I think you need to check it while its hot, not cold. those marks are the hot level from what the Audi techs told me.
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ă C, CĂ*
    My hose coming off the bottom of the coolant tank was leaking very slowly. I found when doing my spark plugs, the movement of the tank disrupted the seal.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Jun 29 2015
    Quote Originally Posted by rwtzero View Post
    I'd be thinking a bad cap. If while driving you were at 212 but had flow and possibly some pressure in the system then you would not be boiling over. As soon as you stopped, the pressure was lost from the system and the boiling point was reached and therefore it started to boilover, inexplicably. Restarting the car showed 227 which is still not boiling point for a system that would still have been under pressure from just running.
    Obviously anything that is not maintaining pressure is going to be your problem, I say cap because if you had it pressure tested then they removed the cap to do so. I would definitely have the cap tested
    Apr 04 2015
    United States
    Thank you!
    Apr 04 2015
    United States
    Quote Originally Posted by timzcat View Post
    Found one local... $9.20 at German Auto Parts!
    Jul 29 2016
    AB, Canada
    just heard from the shop. thermostat leak
    2011 S4
    Apr 04 2015
    United States
    oh! Let us know what thats going to cost!
    My overflow cap O-Ring was TOAST! replaced the cap, hopefully that was half of my problem.
    Jul 29 2016
    AB, Canada
    dealership gave me a free extended warranty trial when I bought the car. 3 months and 5,000km.
    Tech also found the read differential leaking at both output shaft seals.
    The plus side is, I'm getting brakes and lowering springs done (I'm second guessing how low I bought though...) and the tech is telling me that if everything gets approved it will save me a ton of labor on my brakes/springs!
    2011 S4
