Results 1 to 6 of 6
    Veteran Member Three Rings abe's Avatar
    Feb 22 2009
    2008 S4 Avant, 2015 Q7 TDI, 2017 Q5, 2013 F-450, 2015 Ford Edge SEL
    Dielectic Grease on the Coil Pack?
    Is it recommended to put dielectric grease in the coil pack during a spark plug and coil pack replacement? I'm accustomed to using it on spark plug boots, but this, obviously, is different. I'm thinking yes, a thin layer on the connector but I figured I'd ping the experts here first.
    I did search but I didn't see this particular (very newbie, sorry) question.
    Thanks.
    Onwards,
    -abe
    '08 B7 Ibis White Avant
    Senior Member Two Rings b6dolphins4's Avatar
    Aug 07 2011
    Binghamton,NY / Raleigh, NC
    I've been doing it for as long as I can remember. I just apply the grease to the contact surface on the coil, then stick it in.
    2004 DG S4
    Mods:| JHM 93 Tune |JHM Stg 4 Clutch | 034 Light Weight Flywheel | Trexturk Cat less Dp's | Custom 2.5" Non-res Magnaflow CB | K&N Drop-in | 034 MAF hose | Apikol Snub/ Zero Gap Bracket | 034 Trans mount | JHM S.S. | JHM Knob |
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by b6dolphins4 View Post
    Same here.
    Feb 22 2009
    Separate question. Two of the new coil packs, in their boxes, fell to my garage floor from about a 3' height. Should I be concerned? Are they fairly delicate?
    Onwards,
    -abe
    Feb 22 2009
    Interestingly enough, the OEM coil packs come pre-greased, so no need for me to add anything. I took a photo but it's not too clear.
    Onwards,
    -abe
    Mar 25 2006
    Upstate NY
    I put a dab of grease around the seal too. My original coils had some issues in that area. But I've got an oil burner too, so my plugs get changed a lot. lol
    --Alex
    -'07 S6, JHM Exhaust and intake spacers, more to come
