Results 1 to 6 of 6
    Veteran Member Four Rings jonan's Avatar
    Nov 25 2006
    2X B7 RS4 - STG III B6 A4 (gone, but still in the family) - Mini R56 S - '15 Macan S - 997.1
    Austin, TX
    leaking roof drain
    so after stripping my headliner out i decided to test my roof drains because i could see water stains on my old headliner...the last thing i want to do is mess up my new s4 headliner...
    any ideas how to make this tube water tight???
    the front ones are fine but the two rears are leaking pretty badly...
    Want my guns??? ΜΟΛΩΝ ΛΑΒΕ!!!
    B6 Mods:
    Fully Built Motor w/ GT2860RS and all supporting mods : My Build Thread
    RS4 Mods (sprint):
    RNS-e MKII : ECS SS : JHM Spacers : Deflapped IM : UM Tune : KW V3s : Tubi Rumore : Hotchkiss F&R SBs : 034 Diff Inserts : Phil Special Headlights w/ STI Lenses : 10 Layers : Spare 07BNS (#masterrace) : Apikol Diff & Trans Mount
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    First make sure that they aren't clogged. Then wrap the connection with some self-fusing silicone tape.
    Nov 25 2006
    Austin, TX
    done...they drain good, it's just that water weeps between where the hose meets the white portion that connects to the ball on the sunroof drain...
    do i wrap the outside of the tube or remove the tube and wrap the ball??? or both? let me know if you need me to snap more pics...
    B6 Mods:
    RS4 Mods (sprint):
    Dec 28 2006
    Western Maryland
    Wrap it all. The self-fusing silicone tape works really well for sealing fluid leaks.
    Nov 25 2006
    Austin, TX
    OMW to home depot right now!!!
    B6 Mods:
    RS4 Mods (sprint):
    Jun 08 2007
    GLI
    Orlando, Fl
    I used some sealant on mine. Pulled the tube out, coated it in sealant and stuck it back in. Water tight!
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
