Page 1 of 3 123 LastLast
Results 1 to 40 of 103
    Veteran Member Four Rings JD S4's Avatar
    May 07 2016
    '18 S5, '94 Integra DB8 JDM, '20 Highlander Hyrbid
    Citrus Groves, Arizona
    The first 5 modifications every new S4 owner should do
    EDIT!!
    I have tallied the votes from about 40 different voters in this thread. Essentially what I did was went through the entire thread and copied all of the responses (that weren't one off) into a spreadsheet. I then took the modification recommended and put them into a modification "bucket". For ease of use - I grouped like/similar modifications into buckets (removed brand preferences, etc).. The results are pretty cool. I've visualized them into a chart for easy reading. Essentially - AZ members believe that you should 1. Stage 2 then 2. Intake then 3. Coilovers / Springs then 4. Exhaust then 5. Drivetrain inserts. I've removed a lot of the onesy twosy options and left only modification recommendations that had more than a couple of votes. It's pretty cool to see this trended out..
    So - if you're new to the B8/B8.5 and are looking for the mods that are proven and AZ members love the most, here they are.
    END EDIT - Back to your original post
    Original Post
    Let's keep this fun and light. I know this type of thread has been done before (yes, I searched) but this platform is continuing to improve and so many tuners are continuing to push out new products.
    What are those top 3-5 modifications you've done that every new S4 owner should consider. Post the mod, the rough price and what the outcome was.
    Example only
    Intake ~$250, SC whine makes spiriting driving more enjoyable
    Rear Sway Bar ~$250 locks in the understeer and nose push
    VAGCOM ~ etc etc etc
    X-Brace etc etc etc
    What are those 5 first things that Audi should have added from the factory, etc..
    And yes, I know. Everyone would love dual pulley type performance from the factory. :-)
    '18 S5 - BBS / EPL
    Established Member Two Rings brunogomes's Avatar
    Apr 21 2015
    New Jersey
    1. Suspension/Spacers (Lowering a bit and sitting flush)
    2. Wheels
    3. VAG-COM
    4. E-codes (if US spec)
    5. RS mesh grille
    and of course stage2+ but since you left that out I will also leave it out.
    Jan 12 2011
    2016 Q5, 2018 S90
    1. Drivetrain inserts
    2. Rear sway bar
    3. Intake for fun sounds
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    Quote Originally Posted by DontHait View Post
    2. Rear sway bar
    Agree with 1 and 2
    Also,
    3. CR15
    4. Car should sit a bit lower, too much is not needed, just be like rs5
    5. Definitely a louder and deeper exhaust note, the stock exhaust is too boring
    I think these are the things Audi should do from the factory
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Jul 28 2013
    2017 Ford Edge Sport; 2004 Ford Exploder (as my wife calls it) V6, 7 passenger
    Rabat, Morocco
    1. short throw shifter
    2. cai
    3. cat-back exhaust
    4. drivetrain inserts
    5. pulley and stage 2+ tune
    Jan 12 2011
    2016 Q5, 2018 S90
    Quote Originally Posted by yjypm View Post
    Agree with 1 and 2
    Also,
    3. CR15
    5. Definitely a louder and a deeper exhaust, the stock exhaust is too boring
    What is a cr15?
    I agree that it should be lower, I was thinking sub $500 mods. Good coil overs costs 600+, same goes with exhaust.
    Senior Member Two Rings Seattle996's Avatar
    Apr 07 2009
    Best bang for the buck top 5.. IMO
    1. Chipwerkes Software (Most bang for the buck!)
    2. ECS Intake (My personal preference)
    3. Exhaust Mod (Resonated Xpipe for Baby DPs and straight pipe Center Resonator)
    4. Bluetooth Dongle (if you cant stream music with stock MMI)
    5. H&R OE Springs (Dont need new shocks but others would disagree, mine drives just fine)
    Enjoy!!
    Oct 08 2015
    What is a cr15?
    It's a upper tower bar, forum member U2Nelson makes it for a very reasonable price. Everyone loves it, be sure to check it out.
    I can't say much about coils, but you can go for custom exhaust, which might cost below $500
    Current: '18 M3 ZCP
    Senior Member Three Rings AudiSTL's Avatar
    Sep 21 2013
    2011 S4
    st. louis
    1. get rid of the chrome!!!!!!!!!!
    1. Suspension
    2. Wheels
    3. rs mesh grille. if you dont have black optic grille or exhaust if you have black otic grille
    4. stage 1 or 2
    5. intake
    AWE Quad Exhaust / Rotifom Ind 19x10 (old) / V12 245/35 tires / Solo Werks / ECS Carbon Luft Intake / Stoptech / Verde V99 19x9.5
    Enlaes CF decklid / EPL 1+ w DSG
    https://www.instagram.com/admirstl3/
    Jun 28 2016
    US
    You have understeer with the rear sport diff? In my opinion, an AK is about the only thing Audi should have done stock. That and Stage 1 flash... lol
    Mine:
    AK
    Trans/Diff (top/bottom/carrier) Inserts
    AWE Intake hose w/AFE filter in modified OEM box
    Stage 1
    Veteran Member Three Rings Silverbullet S4's Avatar
    Mar 10 2015
    CO - 6,200' +
    1. Stage II (any vendor - don't waste your time/$ with Stage I)
    2. Intake
    3. Exhaust
    4. Coilovers
    5. Cosmetic (RS grill, wheels, diffuser, tasteful spoiler, etc.)
    2013 S4 - APR Stage 2+, DP, CPS v3, BLQ 20s, Solo Werks coilovers, CR-15, EBC Rotors F&R, Deval diffuser, AWE exhaust & USP Intake - TD1 inevitable
    Jan 12 2011
    2016 Q5, 2018 S90
    Quote Originally Posted by SwankP3RF3ct10n View Post
    Mine:
    AK
    Stage 1
    I have the sports diff and the rear sway made it even more fun. Yes there's still some understeer stock
    Apr 29 2013
    Detroit, MI
    1. APR "Ultra"
    The End
    2018 S4 8AT
    2012 S4 6MT
    2006 S4 6MT
    2000 S4 6MT
    Mar 10 2015
    CO - 6,200' +
    Quote Originally Posted by BaumerS4 View Post
    1. APR "Ultra"
    The End
    Oooh, do tell! What is it, where can we buy it, dyno, 1/4 mile, how much? Oh yeah...nevermind.
    May 10 2012
    2013 s4, 2008 cbr1000rr
    United States
    1. APR "Ultra"
    The End
    Lol
    May 07 2016
    Damn!! It was an Audizine miracle.. We were on track, no flaming, good nature.. and BOOM.. Gotta drag APR's dick in the dirt..
    in 2 weeks
    '18 S5 - BBS / EPL
    Nov 21 2013
    Texas
    1) Coilovers
    2) Wheels
    3) BO grill
    4) Intake
    5) Exhaust
    Can flip 4/5 around.
    2013 Brilliant Black S4 - SOLD :(
    Navi / Advanced Key / B&O / Sports Diff / Carbon Atlas Inlays / SC badges / Black Alcantara
    Modifications: AG M510 19x9.5 +40, Black optic grill, H&R Street Coilovers
    Apr 10 2016
    Reading/PA
    1. Dipstick
    2. Brakes (I hated the feel of stock pads)
    3. Intake
    4. CR-15
    5. Tune
    At least, that's my plan. I'm patiently waiting for #4.
    Veteran Member Three Rings chopz33's Avatar
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    these were the first 5 i did in order
    1. lower
    2. intake
    3. RS4 grille
    4. LED interior
    5. AWE exhaust/transmission mount
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    Good Friday humor
    1. Tune
    2. de-badge
    3. CAI
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    May 10 2012
    United States
    1. Window tint
    2. Intake
    3. Cr-15
    4. Tune of some kind
    5. Change interior/exterior lights to LED.
    Active Member Two Rings gottlobfrege's Avatar
    Aug 18 2015
    Bay Area, California
    Interested to hear everyone's thoughts on this. Of the mods I've done, my five favorite (not considering cost, so this is not necessarily "bang for the buck") are:
    (1) Stage 2 Tune + Pulley
    (2) Exhaust
    (3) Wheels
    (4) Short-throw Shifter
    (5) Rear Sway Bar
    2015 S4 6MT | Moonlight Blue Metallic | Sport Differential
    ADS | B&O | G.I.A.C. Stage 2 + AWE Pulley | 034 X-Brace
    034 Rear Sway Bar | 034 Throttle Body Inlet Hose
    Milltek Resonated Exhaust | KW Height Adjustable Springs
    DEVAL Carbon Fiber Rear Diffuser | Black Optic Grille
    JHM Short Throw Shifter | HRE FF01 Liquid Silver 19x9.5
    StopTech ST-60 355x32 Big Brake Kit
    APR Coolant Performance System
    Apr 14 2016
    2014 Cayman S, 2004 A4, 2005 4Runner
    Eastern PA
    My 5:
    - 35% ceramic tint ($300)
    - Black out red sections of badging and grey strips on front grill ($40-80)
    - Swap Peelers and Conti's for Rotors and PSS' ($1000)
    - Replace OEM squealer brake pads with silent Akebono's ($200)
    - Sub upgrade ($80 w/dynamat)
    $1,650.00 total
    May 07 2016
    Great thread! Let's clean up the APR bashing, keep it on topic and make it a sticky!!
    '18 S5 - BBS / EPL
    Senior Member Two Rings soptic425's Avatar
    Apr 18 2016
    Macan GTS, G82 M3 CS
    (2) S-Flo intake (got it cheap off a friend)
    (3) HR OE springs
    (4) AWE Track exhaust
    (5) AMS cooler (should've done before tune)
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    1. RS4 badge
    2-5. See #1.
    Hahaha I kid I kid
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Nov 29 2013
    Silver Spring, MD
    1) Save your mod money and get into an M, AMG, or P-car
    /thread
    But, if you're going to stay, IMHO:
    1) Tint
    2) Suspension (lower)
    3) Wheels
    4) Intake / Stage 2 Tune / Exhaust (*cause once you start modding, there is no such thing as 'first five', lol)
    2017 BMW F80 M3 | Mineral Grey | BBS FI-R | AWE Non-resonated Exhaust | M Performance HAS | Ceramic Pro
    Gone but not forgotten: 2014 S4| Phantom Black| BBS CI-R Platinum Silver 19 x 9 ET 42 | 3M Crystalline 40 Tint | Opti-Coat Pro | Bilstein Coilovers | SPC UCAs | EuroCode ÜSS Sways/Links | Alu Kreuz | Roc-Euro | 034 Trans Mount | RS5 Front BBK | ECS Street Shield | AWE Touring 102s | AWE ColdFront | RS4 Grille
    Established Member Two Rings na_v's Avatar
    Jan 27 2015
    Quote Originally Posted by Seattle996 View Post
    Enjoy!!
    1 & 3
    1) Supercharge Badges
    2) Black Optics Grille or RS4 Grille
    3) Coilovers
    Current : 2013 S5 Premium Plus | Glacier White | Magma Interior | DSG | ADS | Sport Diff | Carbon Atlas | B&O | Adaptive Lights
    AWE Track Exhaust | PUR 4OUR Forged Wheels | ECS Spacers | Carbon Imports Trunk Lip | Carbon Imports CF Mirrors | ECS Carbon Fiber Intake
    Past : 2014 Ibis White Audi A4 Progressiv | ECS Spacers | H&R Sport Springs | APR Stage 1 | RS Grille | US Millworks
    Established Member Two Rings darkstarghost's Avatar
    Feb 08 2014
    2014 Estoril blue s4
    1)tint
    2)supercharged badges
    3)intake
    4)exhaust
    5)radar detector and laser jammers.
    Veteran Member Three Rings skiptowncat's Avatar
    Nov 13 2014
    Manchester, England
    1) fluffy dice
    2) neon underfloor lighting
    3) stretch tyres
    4) mad camber
    5) straight through exhaust
    2015 C7.5 S6//DS1 STAGE 3//SRM INTAKES//034 X-PIPE//H&R SWAYS
    Senior Member Three Rings Victor Newman's Avatar
    Oct 26 2014
    NC
    what i did in order:
    1) brakes
    2) wheel spacers
    3) SRP pedals for heel / toe
    4) rs grille
    5) tint / taillight tint / black out side trim
    planned:
    1) delay valve delete clutch line
    2) x-pipe mod
    3) wrap mirrors
    4) re-finish wheels
    2010 S4 / 6MSG / Sport Diff / Alcantara Interior / StopTech 380mm BBK / Hawk HP+ / Castrol SRF / SRP Pedals / H&R Super Sport / VMR V710
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Here are my 5:
    1. Roc Euro intake
    2. Carista mods
    3. Stage 1 software
    4. CTS S/C Pulley and Stage 2 software
    5. Akebono brake pads
    Senior Member Three Rings DEEZ's Avatar
    Dec 11 2008
    Utah
    Quote Originally Posted by Silverbullet S4 View Post
    2. Intake
    3. Exhaust
    4. Coilovers
    This.
    11' S4 Ibis White | Prestige | DSG | APR Stage II+ V3.0 | APR DSG Tune | Stage II APR Carbonio Intake | AWE Exhaust w/Diamond Black Tips | Deval Diffuser | JHM Slotted Rotors F&R | 20x10 ET35 AG M590 | H&R Coilovers | Eurocode Adjustable Rear Sway | RS4 Grill
    18' Q7 Glacier White | S-Line | Prestige | Black Optics | Adaptive Air | Adaptive Cruise | Thule Aeroblade
    Aug 15 2015
    1199 Panigale
    San Antonio , TX
    My 1st 5
    1) Brake pads & Fluid
    2) Tires
    3) ChipWerke Pro
    4) CR-15
    5) Coilovers
    Its a toss-up for the fluffy dice vs the underbody neon as next!
    Jun 22 2016
    West Chester, PA
    Subbed!!
    My car is 3 months old & stock (didn't want to touch anything before 5k). Thank you for starting this thread...I'll definitely need some help with the upgrades very soon.
    2016 S4 Sepang Blue Premium+ | Black Optics | B&O Tech Pack | Sport Diff | ADS | Black Nappa
    CTS Intake | Alu Kreuz | EBC Red Stuff | 034Motorsport Dynamic+ Springs | CR-15 | Vorsteiner VFF-103
    Build Thread
    Apr 11 2012
    haha, damn, everyone's different. here's my order:
    1. Stance: coilovers + spacers.
    2. Power: stage2.
    3. Stopping: front BBK.
    4. Noise: Intake and Exhaust.
    5. Further reduction in body roll: sways, end-links, drivetrain stabilizer, diff/trans inserts.
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    Mine:
    AK
    Stage 1
    Too funny, my car is set up nearly exactly like yours. you are like the only other poster here that thinks these cars with the sports dif do not need a rear sway bar besides me.
    Jun 28 2016
    US
    Quote Originally Posted by onlyaudis View Post
    That's because people don't push it enough. They go into a turn what they think is too hot and then let off and of course the car will feel like it's going to push... it's heavy. But if you'd just keep on pressing the accelerator even more, you'll feel this weird rotation sensation from the back and you just go right around the turn without an issue, but you do have to have the balls to do it the first time because the car will hold a turn a lot faster and if you have PSS tires on it, it'll hold an even higher speed than you think it can. I don't think most people push the sport diff enough for it to really kick in.
    Deactivated Three Rings
    Oct 03 2014
    Boston
    Didn't see anyone mention this, but #1 on my list if you have a B8 DSG is to replace the pontiac shift knob with a B8.5 one!
    Jul 29 2016
    AB, Canada
    my 5...
    already tuned when I bought it to stage 2+. already have new alloys
    1. Tint
    2. LED Lighting kit from deautokey
    3. lowering springs
    planned:
    4. black optics grill (or RS style grill)
    5. change shift knob from B8 to B8.5
    6. Flat bottom wheel
    2011 S4
