Results 1 to 40 of 68
    Veteran Member Four Rings JD S4's Avatar
    May 07 2016
    '18 S5, '94 Integra DB8 JDM, '20 Highlander Hyrbid
    Citrus Groves, Arizona
    E85 on stock car
    Doing my first E85 mix today.
    Stock 3.0T (intake/exhaust, no tune).
    At elevation (6,000 ft base, will be up to 12,000ft this weekend)
    Will report back on findings
    I'm scared. Hold me.
    '18 S5 - BBS / EPL
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by JD S4 View Post
    You are running E85 without an E85 tune? May God have mercy on your engine.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Veteran Member Three Rings Silverbullet S4's Avatar
    Mar 10 2015
    CO - 6,200' +
    What's your mix and what are you hoping to gain?
    2013 S4 - APR Stage 2+, DP, CPS v3, BLQ 20s, Solo Werks coilovers, CR-15, EBC Rotors F&R, Deval diffuser, AWE exhaust & USP Intake - TD1 inevitable
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Lol
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by redline380 View Post
    he is doing a mix.. if he does 3 gallons it won't be that bad of an impact
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Jan 10 2014
    2012 a4, 2015 s4
    TX
    Quote Originally Posted by doug97gxe View Post
    I'm guessing cel while on e85/mix then normalizes once reg gas is used?
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by mintytoo View Post
    depends.. if he does more than 4 gallons he might see a CEL .. 3 gals of E85 and 93 should be good
    but yeah if you switch back to full 93 no more codes
    Present:
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    I hope you are being ridiculous on purpose... If not, please educate yourself on both E85 and modern technology. Lol.
    I run E85 in Colorado in my stock S4 as often as possible. 3 gallons in a full tank does the trick. Feels better in the heat, pulls a little longer, power is more consistent. I messed with multiple ratio mixes, 3 gallons makes me happy. I did get a lean code once when I was trying a 3.5 gallon mix. Tony at EPL himself has stated that this type of lean code is completely software based, as the ecu can't keep up fuel supply within the parameters of the stock tune. There actual limits of the hardware are higher.
    I've driven with this mix up to above 8k feet without issue. I don't think you'd have an issue at higher elevation, as the car is actually more starved for air, so I would think fuel demand would be lower if anything? Just an uneducated guess really..
    2021 Audi S4, P34 Intake
    Dec 03 2008
    2018 SQ5
    He'd be damn lucky to find 93 in CO. 91 is typically the best available.
    May 07 2016
    3 gallons of E85 vs. fill on 91.
    As mentioned - no 93 octane in CO (almost anywhere).
    Will be running no more than 3. Same car/mods/location as Jim ^^
    '18 S5 - BBS / EPL
    May 07 2016
    Quote Originally Posted by Silverbullet S4 View Post
    Empty tank, 3 gallons of E85.
    More consistency. it's been incredibly hot and I'm heading to elevation. No real "goals" - just consistent feedback across forums that it pulls stronger, even on a stock tune.
    '18 S5 - BBS / EPL
    Dec 03 2008
    2018 SQ5
    It doesn't blow your mind or anything, but it's noticeable. Definitely worth it in the summer. I go back to normal 91 through winter. It also brings more instant power from the gas pedal during shifting imo.
    Senior Member Three Rings BAHNSTORMER's Avatar
    Mar 26 2010
    Waukesha, WI
    My fill ups are typically 10 gal 93 octane E10 and 2 gal E85. The mix gives me a bit over 95 octane & E22. No issues so far.
    Daily driver: 2012 S4 P+
    Phantom Black Pearl Effect / Sports diff / Alcantara / S-tronic / MMI Navi + / B&O / 19" Peelers / Carbon Atlas inlays / advanced key / rear camera / Supercharged badges
    Previous Audis: 1984 4000S Quattro // 1989 200 Quattro // 1994 S4 // 2005 S4 // 2010 A5 3.2
    Veteran Member Four Rings 4RCFED's Avatar
    Aug 27 2014
    12' Audi S4 (sold), 18' Discovery HSE (V)
    Sandy Springs, GA
    Yessir, been doing this for well over a year, hell all the Colorado Audiziners (including Jim ☝️) got together and made a list of stations with E85. Drove it home to Telluride and higher with no problems.
    2012 S4 (sold)
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by BAHNSTORMER View Post
    So you don't fill the tank?
    I calculate based on claimed tank size 16.9
    I like my 3 gallon mix.
    3/16.9 = 17.75% e85
    After monitoring and calculating mpg for a while with this mix, I can typically get 19 mpg in my normal city driving.
    When it's time to fuel up, I divide miles traveled on the last tank by 19, then multiply that number by .1775 and this gives you the amount of E85 to pump. I pump the e85 and then top with 91 until it clicks off.
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    I've went as high as 3.5 gallons of e85 in a tank of 91 untuned and I'm currently running 5 gallons of e85 with about 10 gallons of 91 on my stage 3 file. Jim is right the higher in elevation you go, the less air you have to mix with fuel so your system would have less of a demand to reach the target afr. E blends and check engine lights seem to vary car to car...I started out with 2 gallons, then 2.25, 2.5, 2.75, 3, 3.5, 4 and finally 4.5. I ran that mix for stage1 and 2, but eventually said fuck it and put 5 gallons in. I don't know if this gave my ecu time to slowly adapt, but I've never had a check engine light. Anything above 2-3 gallons and you need to log.
    Will
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Of course the ECU can't keep up with supply since it takes more fuel on e85! Also, all codes are software based since it is the software triggering the code. The software is telling you "Hey, I'm leaning out. This isn't safe." But you are all "I know more than you. Shut up with your stupid lean code."
    I mean do as you guys wish, but I wouldn't without a re-tune. However, it may not make a huge deal depending on which gas you are using and how much alcohol you put in. What is fed requirement, cars must be able to run on 15% ethanol? If you start with straight gas and go 20% ethanol, this probably wouldn't cause a massive concern but still probably too lean for the engine to like it. Here in MN, ethanol is required to be added to gas. So, by adding another 20% ethanol to gas that is already diluted could cause cauastrprohic failure without a retune for additional fuel. If you guys in Colorado are diluting straight gas with ethanol, it won't matter since the car can handle 15%. But in other states, adding ethanol to gas that already has ethanol in it could be bad. Hence, my concern.
    2000 S4- Working?
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    been running 3 to 4 gallons e85 with a fill up on my EPL stage 1 car for nearly a year, no cels, no issues at all. even at 4 gallons of E85 (which is usually less than 85-more like 70) you are still less than E20 overall if you do the math, and these cars can deal with that no problem. I get maybe 2 MPG less, but E85 is cheaper so it almost even's out. My car pulls noticeably harder and is more responsive --its not a subtle difference and was even more noticeble going backwards when I had to put a tank in without the E85 once. CA 91 gas is not great for high HP forced induction cars
    Apr 05 2009
    SF BayArea
    adding 4 gallons of E85 will not be adding another 20% ethanol. more like 10-15 % most blends are really like E70 or even lower. Our tank takes 16 gallons, so only if the stuff was E100 would it be close to 20%. Could always do 3 gallons if you are concerned about how much is already in the fuel, which will be only adding another 10%. The engine management in these cars is superb (its why people can run those add on box Chipwerke tuners and not destroy their engines) It can easily cope with 15 to 20 % total ethanol. Been doing it for nearly a year with no issues at all.
    Mar 26 2010
    Waukesha, WI
    3/16.9 = 17.75% e85
    Yeah, I fill the tank. I drive the about the same number of miles every week so the gallons are pretty consistent.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by onlyaudis View Post
    Of course it can handle 15%, EPA says it has to. I'm saying going over that is a problem. If you are adding more ethanol to gas that already is 15% ethanol, you are going to reach the limit sooner or later. I'm not going to do the math on how much e85 to add to 100% gas since it seems like you guys have that handled. But there are seven states that require ethanol to be blended into gas. Saying you are fine running X gallons of e85 is not exactly accurate if you take into account E15 fuel.
    2000 S4- Working?
    Dec 03 2008
    2018 SQ5
    We do have e10 in our 91 here, still hasn't been a problem with a 3 gallon mix, for me.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Again, do as you wish but you wouldnt catch me experimenting like that on a car that new. Well, unless I had realtime logs of AFR's and EGT's while doing it. But still probably not...
    2000 S4- Working?
    Veteran Member Three Rings sirsycott's Avatar
    Sep 20 2013
    Orange County/CA
    engine is smart enough to compensate where it can, unfortunately (or thankfully) no one has locked up their engine or blown up their motor mixing e85 or running full e85 on stock software to forum knowledge
    we have guys running around with full e85 tanks and dedicated full e85 tunes, only thing that changes hardware wise was the fuelpump and a sensor for the APR beta guy who was running it, epl is running their own variation of that
    but it tells you that the motor when told to run full e85 is just technically a remap (yes I'm oversimplifying it) , which means the car can handle it
    stock software with the code, would mean if the ecu detected something out of parameter it would try whatever it can do to keep it running safely in which ever way it can
    May 07 2016
    When E85 came out and people started using it 5-10 years ago in boosted applications - I remember people talking about an E85 "conversion".. If I recall - the discussion was always around fuel lines and pumps needing to be changed out.. Strange to see that has gone away - at least in the 3.0T over the years.
    I have zero worries. Will toss 3 gallons in and roll.
    '18 S5 - BBS / EPL
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    why?
    what do expect to gain? We in CT. are lucky I get 93 Shell for $2.89 gall. Was $2.79 for long time. Get 19.5 MPG city/
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    May 07 2016
    Quote Originally Posted by jygesq View Post
    Common consensus is that E85 mix gives the ECU enough net octane to hit that extra timing map, run a little stronger, pull a bit stronger into the rev range, etc. Especially in heat (and elevation). Dyno proven on tuned cars - not sure if anyone has dyno'd a stock tuned car with E85 blend but common consensus is butt dyno approves. We don't get 93 here due to the elevation so I'm just fiddling around to see what we can do.
    '18 S5 - BBS / EPL
    Mar 10 2015
    CO - 6,200' +
    I guess I don't see the point in running a mix on a stock car. That said, I'm currently stage 2 on a 91 map and have been running 3-4 gallons mixed with 91 and haven't throw any CELs. Good enough results that I'm about to get the 93 map instead of the 91 and run a blend from here on out targeting ~94 octane with the blend.
    Dec 03 2008
    2018 SQ5
    Well, since our cars are engineered for 93 octane, but many of us are only able to run 91 Oct, there is the immediate benefit of increasing octane and getting the full potential out of the oem software without having 93 to use.
    Mar 10 2015
    CO - 6,200' +
    That's sound logic right there and I hadn't even taken that into account. Good call!
    Dec 03 2008
    2018 SQ5
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    But you have to keep in mind it takes more alcohol to reach stoich than gas! Sure, you can add alcohol to get to your 93 oct, but you'll have to inject more fuel overall to run safe AFR's. Which is of course why E85 vehicles get worse mileage. It has way more power potential, but takes more fuel to reach it safely.
    2000 S4- Working?
    Mar 10 2015
    CO - 6,200' +
    True but, I can't imagine most folks in S4s are that worried about losing a couple MPGs. Especially if it results in (as Clarkson would say) "mooore powerrrrrr"! ;-)
    May 07 2016
    Happy to make that trade off.
    E85 is 75% the price here which also offsets a portion of the mileage decrease. Wrong car to own if you're solely focused on MPG anyways as we all know. Performance is a tradeoff I'm willing to make.
    Cliff notes: most of us are rich as fuck and dont care about MPG.
    '18 S5 - BBS / EPL
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    MPG's are the last concern. The reason behind lower MPG's is the biggest concern. When comparing to gas, it takes more alcohol to fuel an engine hence the lower MPG's. But if you are running the same amount of alcohol as you did gas, AFR's and EGT's go up and shit starts getting hot. As we already went over, the stock ECU has to be able to compensate for up to 15% alochol per EPA regs. Anything over that and you are running into uncharted territory and the ECU cannot compensate to run enough alcohol to properly fuel and prevent high combustion temps. Running lean is a bitch.
    Admittedly, I know next to nothing about recent model cars. Perhaps the B8 S4 ECU is smart enough to compensate for running alcohol above 15%. But I am willing to bet it isn't and I certainly wouldn't be the one who wants to try it. I want to emphasize nobody here gives a cat's ass about MPG's, it is the reason MPG's are lowered that matters, and that is because it takes more fuel when running alcohol to avoid lean conditions.
    2000 S4- Working?
    Mar 26 2010
    Waukesha, WI
    Adding 2-3 gallons of E85 per tank didn't affect my calculated mpg at all.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    It probably wouldn't, although driving and weather conditions do matter greatly. However, going to full E85 would have a very negative effect on MPG's. However, because of the lower price, it could all equal out in the end, or close to it.
    2000 S4- Working?
    Aug 27 2014
    Sandy Springs, GA
    FTW! We use it to boost octane, IIRC E85 is like 105-110 octane.
    2012 S4 (sold)
    Mar 26 2010
    Waukesha, WI
    Quote Originally Posted by 4RCFED View Post
    Yup. 3 gal of E85 + 13.9 gal of 91 octane = 93.5 octane E23
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Might as well just use straight e85 for 105oct then 😔
    2000 S4- Working?
