Results 1 to 7 of 7
Hybrid View
    Aug 12 2015
    Minneapolis MN
    How does anyone actually replace rear Calipers???
    Does anyone have a trick for removing the rear caliper carrier bolts? I have found it to be nearly impossible without stripping the bolts themselves. There is no way to get clean leverage using a breaker bar with the space provided. I have to use a u joint adaptapor on the bar itself to even get at it. Maybe my breaker bar is too long? I have heard people say to try and use a jack to lift the breaker bar while holding the socket on the bolt. Any other tricks? How do the shops do it?
    2017 Audi RS7 Glacier White w/ Black Optics
    2014 Porsche Panamera Turbo Executive Amethyst
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    A lift. LOL. Makes the world of difference.
    Sent from my SD4930UR using Tapatalk
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Aug 12 2015
    Minneapolis MN
    Quote Originally Posted by blackfunk View Post
    Right but the bottom carrier bolt is not accessible from underneath either, only from the side
    Jul 12 2012
    I haven't removed mine either but I got a ratcheting breaker bar which helped with the front tremendously. I think it was like $25 from Amazon.
    Apr 30 2010
    San Diego
    I was able to get them off with a swivel joint on my 1/2" wrench. Messed up the swivel joint a bit though as they are on their good.
    2011 Audi S4 | 6MT | Ibis/Black Silk Nappa | Nav l B&O | Sport Diff | Carbon Inlays | H&R l Strat Intake l Strat SS l Alu Kreuz l AWE Exhaust l AG M510 20x10 et35 l GIAC Stg II l DTM Lip l Eurocode Diff Mounts l SS Clutch Line
    Jun 28 2016
    US
    Use the box end of a normal wrench on the bolt. Then on the open end, interlock the next smaller wrench size you have down and that will make a wrench with enough leverage to get the bolt loose. Do the same to get enough torque to tighten them back up on reinstall.
    In case you're wondering what I'm talking about...
    Helps to have a set of these too... go buy some if you don't have any. In tight places where you can't line up a normal wrench to engage a bolt head without interference from something.
    Aug 12 2015
    Minneapolis MN
    Some others have posted that you dont even need to remove the caliper carrier to remove the rotor? Is that the case???
