I'm getting an error P0172 on my 2007 Audi V6 FSI car.
Any good people out there to help out?
Code:
Friday,26,August,2016,07:53:51:55111 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 16.8.0.3 (x64) Data version: 20160803 DS255 www.Ross-Tech.com VIN: ************* License Plate: Mileage: 203360km-126362mi Repair Order: Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008)) Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: ************ Mileage: 203360km-126362miles ------------------------------------------------------------------------------- Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl Part No SW: 8E1 910 559 F HW: 8E0 907 559 J Component: 3.2l V6 FSI 0080 Revision: --H19--- Serial number: Coding: 01040109190F0120 Shop #: WSC 93009 999 04862 VCID: 3169D31DA8FE1DCA1F-8064 3 Faults Found: 001632 - Intake Manifold Tuning Valve Control Circuit (Bank 1) P0660 - 009 - Elect. Malfunction - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 37 Reset counter: 25 Mileage: 202291 km Time Indication: 0 Freeze Frame: RPM: 896 /min Mass Air / Rev.: 103.6 mg/str Temperature: 102.0°C Idle Voltage: 11.93 V Speed: 0.0 km/h 004407 - Fuel Trim: Bank 1 (Add) P1137 - 007 - System too Rich - Intermittent - MIL ON Freeze Frame: Fault Status: 10100010 Fault Priority: 6 Fault Frequency: 4 Reset counter: 40 Mileage: 202436 km Time Indication: 0 Freeze Frame: RPM: 768 /min Mass Air / Rev.: 218.0 mg/str Temperature: 94.5°C Idle Time: 512.0 s Bin. Bits: 00000010 004506 - Fuel Pressure Sensor (G247) P119A - 007 - Malfunction - Intermittent Freeze Frame: Fault Status: 00000010 Fault Priority: 5 Fault Frequency: 3 Reset counter: 38 Mileage: 202437 km Time Indication: 0 Freeze Frame: RPM: 3104 /min Mass Air / Rev.: 267.1 mg/str Temperature: 93.0°C Part Throttle Pressure: 53.9 bar Speed: 67.0 km/h Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 8E1 910 156 L HW: 09L 927 156 B Component: AG6 09L 3,2 FSI USA 0010 Revision: --H01--- Serial number: 4207022 Coding: 0000002 Shop #: WSC 06335 000 00000 VCID: 306FD619A3F414C210-8064 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-910-517.clb Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH Component: ESP8 quattro H06 0140 Revision: 00000000 Serial number: 00000000000000 Coding: 0004532 Shop #: WSC 06335 000 00000 VCID: 2E53C861B9C0023202-807A No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 BM Component: A4 Klimaautomat 2833 Coding: 00000 Shop #: WSC 00000 VCID: 6DD10F6D2746B92A7B-5124 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl Part No: 8E0 907 279 N Component: int. Lastmodul USA 0907 Coding: 01023 Shop #: WSC 06335 VCID: 3D71FF2D37A6E9AA8B-4B00 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-94.lbl Part No SW: 8E0 959 655 H HW: 8E0 959 655 H Component: Airbag 9.41 H12 3840 Revision: 91H12384 Serial number: 0036N0023U5T Coding: 0033607 Shop #: WSC 06335 000 00000 VCID: 3C77F2297FBCE0A2BC-8068 Subsystem 1 - Serial number: 6332DRB4039A46AC. Subsystem 2 - Serial number: 6342DRB4039D4F9D7 Subsystem 3 - Serial number: 6352ARB40162AD0FT Subsystem 4 - Serial number: 6362ARB4016018177 Subsystem 5 - Serial number: 63729RB40173B171E Subsystem 6 - Serial number: 63829RB40173B181G No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 Q Component: Lenksáulenmodul 0701 Coding: 04141 Shop #: WSC 06335 VCID: 418983DD4B5E8D4AEF-4AE8 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl Part No SW: 8E0 920 901 E HW: 8E0 920 901 E Component: KOMBI+WFS 4 H14 0110 Revision: 0110 Serial number: 00000000000000 Coding: 0023361 Shop #: WSC 93204 999 83903 VCID: 275D3D45953A537AC1-5124 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl Part No SW: 8E0 920 901 E HW: 8E0 920 901 E Component: KOMBI+WFS 4 H14 0110 Revision: 0110 Serial number: 00000000000000 Coding: 0023361 Shop #: WSC 93204 999 83903 VCID: 275D3D45953A537AC1-5124 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl Part No: 8E0 959 760 Component: Sitzmemory R2 F 0305 Coding: 00002 Shop #: WSC 00000 VCID: 71E9131D3B7E5DCA5F-4B00 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 CG Component: Komfortgerát T7B 4135 Coding: 11820 Shop #: WSC 06335 VCID: 78FF2E3958040C8298-4B00 Subsystem 1 - Part No: 8E1959801G Component: Tőrsteuer.FS BRM 0706 Subsystem 2 - Part No: 8E1959802G Component: Tőrsteuer.BF BRM 0706 Subsystem 3 - Part No: 8E0959801E Component: Tőrsteuer.HL BRM 0606 Subsystem 4 - Part No: 8E0959802E Component: Tőrsteuer.HR BRM 0606 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl Part No SW: 4F0 910 357 F HW: 4F0 907 357 F Component: AFS 1 H01 0020 Revision: 00000001 Serial number: Coding: 0000019 Shop #: WSC 06335 000 00000 VCID: 29593B7D802E650AD7-807C Subsystem 1 - Part No: 8E0 941 329 A Component: AFS-Modul links H03 0010 Subsystem 2 - Part No: 8E0 941 329 A Component: AFS-Modul rechtsH03 0010 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 8J0-035-1xx-56.clb Part No SW: 8E0 035 195 AC HW: 8E0 035 195 AC Component: R Symphony2+ H02 0070 Revision: 00H02000 Serial number: AUZ1Z4F2825142 Coding: 0610112 Shop #: WSC 06335 000 00000 VCID: 68DF7E7958A49C0208-5140 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 8P0-862-335.lbl Part No SW: 8P0 862 335 J HW: 8P0 862 335 J Component: FSE_255x BT H21 0290 Revision: 00000001 Serial number: 00000000497438 Coding: 0001677 Shop #: WSC 06335 000 00000 VCID: 3D71FF2D67A6E9AA8B-5124 No fault code found. End-------------------------(Elapsed Time: 05:53)--------------------------
