Results 1 to 40 of 49
Thread: 21 tire sizes
    Veteran Member Four Rings ThunderDent's Avatar
    Mar 14 2012
    2010 Ibis R8 Coupe 6MT V10 // 2015 Sepang (Stage I) SQ5 // 2018 Galaxy Q7 (Wifey’s)
    Ona, WV
    21 tire sizes
    It looks like there are some additional tires now made for the OEM 21s in the 255/40R21 size.
    http://m.tirerack.com/tires/TireResu...zipCode=null#0
    They've added a Continental tire to the line up for summer performance and as well as a Scorpion winter (seasonal) now back in production. Still no Michelin for that size (my preferred tire).
    Here's the question for all you wheel/tire guys out there. There seem to be a lot more choices in the 265 department.
    That increases width, but keeps rolling diameter and sidewall size the same. Will beefing up to 265 be possible?
    Issues with fitment/seal/rubbing anywhere?
    There is 1 Michelin choice at that size:
    http://m.tirerack.com/tires/TireResu...&diameter=21#0
    Would this tire work better than the Dunlop OE tire I was going to get?
    Current Stable:
    •2010 Audi R8 V10 Ultra Ibis White—Black/White Stitching (6MT)
    [Nemesis/APR/Carbon Fiber/GT/Euro/LMS]
    •2019 Audi RS3 Nardo Gray—Black/Red Stitching (S-Tronic/Daily)
    •2018 Audi Q7 Prestige 3.0T Galaxy Blue—Black (Wife’s Ride)
    •2018 VW Golf S (Daughter’s Ride)
    Past Whips:
    •12 WRX Dark Gray Metallic (6MT) •11 Audi Q5 Ibis White (APR Stg 3) •12 VW GLI Tornado Red (DSG) •16 Audi Q3 Hanian Blue •15 Audi SQ5 Sepang Blue (EPL Stg I) •19 VW GTI SE
    Veteran Member Three Rings DocTJ's Avatar
    Jul 29 2016
    PA
    man... still no all seasons :( lol
    Established Member Two Rings Hrp783's Avatar
    May 07 2014
    F-150 Larriett, Infiniti G35 sport
    Austin Texas
    Increasing to 265 will work!
    Just read it on Audizine "sq5 21" tire options"
    Veteran Member Four Rings riceboy22's Avatar
    Mar 26 2015
    2015 Audi SQ5, Felt F65x, Levy Electric Scooter
    New York, NY
    Quote Originally Posted by ThunderDent View Post
    FYI the sidewall is taller, so your rolling diameter increases (sidewall number is a percentage of width). Most people have been able to fit the taller 265/40R21 tires without issues, but keep in mind that depending on the tire the profile can vary a bit, so you need to make sure it doesn't hit the steering knuckle (not a lot of clearance there if you take a look).
    Current
    2015 Audi SQ5 3.0 TFSI (Build Thread | Flickr | Instagram)
    Past
    2006 Lexus IS350 | 2001 Audi S4 | 2000 Honda S2000 | 1999 Yamaha YZF-R6 | 1995 Acura Integra GS-R
    Sep 28 2010
    NW NC / DE
    I'd be all over that 265 Latitude. I ran those on my VFF-103. Perfect tire for these.
    Jul 10 2014
    Cannot beat Michelin for performance... DWS is BY FAR the best A/S IMO. But the 295's look maybe 1/2 inch wider than my 275 Pirelli A/S's... Getting back to what Riceboy said.
    May 07 2014
    Austin Texas
    21 tire sizes
    What about these?
    Treadwear is 600 A A
    All Season
    Established Member Two Rings goblues38's Avatar
    Aug 14 2016
    STL
    I think I am all over these scorpions. I may bite the bullet and just pay for a cycle of mounting and unmounting this winter as my SQ5 had brand new pirelli pzeros last month. May mount the all seasons decemeber -march.....go back to the pzeros for next summer and then go all seasons full time next december.
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    There is no problem running 265's at all. The only thing you have to be concerned with, other than your aesthetics, is the 29.3" height restriction. That's the maximum diameter before contacting the spindle arm (knuckle). That's why you have to drop to a 35 series if you go wider than 265 on 21"s. Even with aftermarket wheels and varying offsets, you can't go bigger than 29.3".
    Mar 14 2012
    Ona, WV
    Ok so if the 40 is cutting it close to the control arm spindle, and dropping to a 35 help you there, what about these?
    How bad does this fuck up my rolling diameter?
    Current Stable:
    Past Whips:
    Mar 14 2012
    Ona, WV
    Well, I just looked up the size difference calculator.
    I guess maybe I'll just stick wth the OE size. I hate screwing up mph and mileage, and it looks like both do pretty badly. So Dunlop's it is I suppose. Unless I choose the new Conti option. Maybe Michelin will offer a tire in this size by next year.
    I'd really like a Michelin option. Esp PSS's, but Latitudes would work as well.
    Here are the comparisons:
    OEM 21 (255/40) vs 265/40
    OEM 21 (255/40) vs 265/35
    Current Stable:
    Past Whips:
    Mar 14 2012
    Ona, WV
    Honestly, looking at it again, the 265/40 option isn't THAT bad.
    It's only off an additional (0.1) per every 10 mph. That's only 1 mph off up to 100mph. Not awful.
    And it gives you a bit wider base to sit on.
    And it looks like the sidewall gives you (0.2) difference in height. Can't imagine that will interfere with the control arms.
    Esp with a summer performance tire with thinner tread.
    Idk. I'm still really torn.
    Looking at 7 less revolutions per mile on the tire, which will add up to showing lower miles on your car than what are actually on there I think. That's not a bad thing I suppose for resale value.
    And less rev/mile would equal longer tire life potentially.
    Current Stable:
    Past Whips:
    Jan 09 2009
    1of50
    IMO, I would go 265/40 and get the Latitude.
    Senior Member Three Rings rgvsq5's Avatar
    Feb 03 2015
    Texas
    I'm running the 265 Latitude Sport 3's on my stock 21s with absolutely no issues whatsoever. Great tire!
    SQ5 | APR Stage 2+ : APR CPS v2 : AWE : Bilstein : H&R : ECS Tuning : 034Motorsport : P3Cars : Adam's Rotors : E-Code : XPEL
    Apr 26 2014
    DFW
    What I said about dropping to a 35 series implied making up the difference in a wider tire, which would require a wider wheel. I apologize for my omission.
    Mar 14 2012
    Ona, WV
    Quote Originally Posted by rgvsq5 View Post
    Oh great. That's good info.
    •How is handling in the wet/shedding water with them?
    •How is dry cornering?
    •How is the noise level when rolling?
    •Any pics of tires on your 21s?
    I'm leaning this way actually. Just hoping to pick your brain a bit before I pull the trigger if you don't mind.
    Current Stable:
    Past Whips:
    Mar 14 2012
    Ona, WV
    http://www.topgear.com/michelin/refined-defined.html
    Good read on the Latitude Sport 3's.
    They are made for the Macan apparently.
    Current Stable:
    Past Whips:
    Mar 14 2012
    Ona, WV
    Useful info also. Pretty sure I've made up my mind on these.
    Current Stable:
    Past Whips:
    Sep 28 2010
    NW NC / DE
    DNR, but here is 265/40 on a 9. Not sure if that helps.
    NO.-4852 by Audiyos, on Flickr
    Mar 14 2012
    Ona, WV
    That looks pretty fucking fantastic I have to say.
    I'm getting them. TireRack is back ordered. But I'll get them.
    My carbon bits ship next week so I should get install started the week after.
    Current Stable:
    Past Whips:
    Sep 28 2010
    NW NC / DE
    Tam may be able to track some down.
    Mar 14 2012
    Ona, WV
    I may take you up on that. I'll shoot you a PM Monday if I go that route.
    Is that Nardo in the pic or your SQ? I want Nardo so F'ing bad.
    Current Stable:
    Past Whips:
    May 07 2014
    Austin Texas
    21 tire sizes
    Soo, no one interested in the Pirelli all season?
    My wife doesn't track it, pretty much a fast baby hauler.
    Going with the all seasons, 12mm front and 18mm rear spacers
    H&R 1" drop springs
    Any suggestions?
    Jul 29 2016
    PA
    Quote Originally Posted by Hrp783 View Post
    H&R 1" drop springs
    Any suggestions?
    the main reason im not considering them is because they arent good enough for the way i drive and the way i push my sq5, thats just my opinion, id rather downsize to 20in and get the DWS06 in the size i want vs the pirelli all seasons:
    DWS06:
    Pirelli:
    Jan 09 2009
    1of50
    Check discounttires.com they are having their annual Labor Day sale...up to $100 rebate on 4 tires and u can stack with manufacturer's rebate as well. They also price match.
    Senior Member Two Rings Cody Maverick's Avatar
    Sep 28 2011
    2015 SQ5, 2004 R32
    Baltimore
    265 is the way to go. I dont remember who on here suggested it to me but i am glad. It looks much better and also better options and choices out there.
    2015 SQ5
    2013 S4
    2004 R32
    Senior Member Three Rings jpsjr's Avatar
    Jun 08 2016
    2018 Porsche 911 Turbo S Convertible
    Central NJ
    Quote Originally Posted by Cody Maverick View Post
    You have them on your SQ5 now? Can you take pic of tire and front suspension for clearance? Spacers?
    Jose
    2019 Audi A6 3.0T Glacier White/Black
    2018 Porsche 911 Turbo S Convertible White/Black
    2018 Porsche Cayenne Turbo S White/Black
    Mar 14 2012
    Ona, WV
    All that site has is the Conti Sport Contacts. I've looked there already. But thanks for the heads up.
    Tire rack has them delivered in 2-3 days if I lived in Cali.
    But east coast is sold out, and they run through distribution centers. It says my distribution center in in Indiana I believe.
    So if you live certain places you can get them.
    I'm checking with Installer to see if they can source them so I'll get full roadside warranty through them, and if not Mops is getting a PM!
    Current Stable:
    Past Whips:
    Apr 26 2014
    DFW
    I suggested it when I got mine, two years ago.
    You should also check tires-easy.com.
    I'm loving these Vredesteins.
    May 07 2014
    Austin Texas
    Discount tire has them in stock here in Central Texas
    Mar 14 2012
    Ona, WV
    Tires-easy only has Conti, Pirelli and Nokian in that size
    Current Stable:
    Past Whips:
    Apr 26 2014
    DFW
    Their inventory changes from week to week.
    Feb 03 2015
    Texas
    Alive from the dead... But has anyone tried to squeeze a 275/35 21 on the stock SQ5 21" wheels? What, if any fitment issues would there be? Diameter would be about 3/4" smaller than the current 265/40 21's I'm running.
    Veteran Member Four Rings EYE4SPEED's Avatar
    Jan 14 2008
    Macan Turbo, Cayenne Diesel, Audi Jr Quattro
    West Coast of Michigan
    I need 21" winter tires - anyone have a set for sale?
    FS: Audi TT 225Q Roadster
    Sep 28 2011
    2015 SQ5, 2004 R32
    Baltimore
    Quote Originally Posted by jpsjr View Post
    Jose
    sorry never replied.. i have 10mm spacers in front 20mm in rear clearance is all fine with H&R's .. I have a tiny bit of rub but that is because when i got in an accident (that i still havent fixed) the liner is pushed out a half inch or so
    2015 SQ5
    2013 S4
    2004 R32
    Active Member One Ring justinSQ5's Avatar
    Jun 11 2017
    Frisco, TX
    Did you have to install spacers to fit the 265's without rubbing?
    Veteran Member Four Rings BG SQ5's Avatar
    Feb 21 2016
    '07 CBR1000RR
    PA
    275 is too big for a 8.5" rim. Also, that small of a sidewall starts to look pretty weak. I think a 295/35 is a pretty small sidewall.
    Quote Originally Posted by justinSQ5 View Post
    None of the standard 265/40r21s people typically run require spacers. It's the overall diameter that matters with those no the inside clearance...as long as you're under 29.3" or less. Not to mention, I don't know why anyone wouldn't want spacers on a 265 (assuming stock offsets).
    '15 SQ5 Daytona Gray
    APR stage 2 104 oct (e40) - BG TCU (via HPT) - CTS s/c & FD 187 crank - Autotech HPFP - aFe filter/034 tube/modified box - MercRacing h/x - AWE Touring
    21" Forgestar CF10s w/295s - KW Street Comforts - 034 mounts, RSB & end links - ecodes - deAuto LEDs - P3 w/ECA - VCDS
    11.340 @ 120.63 (673 DA) - street trim
    11.012 @ 124.22 (-1346 DA) - track trim
    Instagram: @bg.sq5
    Apr 26 2014
    DFW
    Quote Originally Posted by BG SQ5 View Post
    The 295/35-21 has the same sidewall as a 265/40-21. Only their widths differ.
    None of the standard 265/40r21s people typically run require spacers. It's the overall diameter that matters with those no the inside clearance...as long as you're under 29.3" or less. Not to mention, I don't know why anyone wouldn't want spacers on a 265/35r21 (assuming stock offsets).
    This is true. Get you some spacers, boy!
    Feb 21 2016
    '07 CBR1000RR
    PA
    Quote Originally Posted by SQive View Post
    No, actually they're not. They're pretty close, but a 265/40 is bigger by ~0.1". Here I thought you were an engineer as well...minus points!! *obviously a tire's actual measurement can vary from the advertised size depending on brand and model, so I'm speaking theoretically and going by the math
    For the record- I own set of each...295/35r21s and 265/40r21s. From any kind of angle, I think the optics of the extra width of the 295 make the sidewall appear even smaller.
    Instagram: @bg.sq5
    Apr 26 2014
    DFW
    They all vary by manufacturer, and even by model.
    Here I thought you were an engineer. Of course they appear smaller. That's because of the aspect ratio. 35% of the width will always appear smaller than a sidewall that's 40% of the width.
