Results 1 to 15 of 15
Thread: Wideband Gauge
    Active Member Two Rings wagongang's Avatar
    May 25 2016
    1999 Audi A4 Avant 1.8t (totalled)
    Neenah, Wisconsin
    Wideband Gauge
    I have a 2000 A4 Avant 1.8t that has a catless testpipe installed. I'm thinking that since there is no cat both O2 sensors should be reading about the same. Would I be able to wire one O2 sensors to both banks and not hurt performance? The reason why I would do this is to install a wideband sensor in the other bung. Thoughts?
    Watch out for drunk drivers...
    they'll total your car.
    Veteran Member Three Rings xthealienatorx's Avatar
    Mar 01 2013
    10 Avant, 03 Superduty 6.0 zf6, 13 Grand Cherokee Overland Hemi
    Louisville, Kentucky
    Just get rid of the second sensor.
    Sent from my SM-G920T using Tapatalk
    May 25 2016
    Neenah, Wisconsin
    It won't hurt anything if the car is not getting that signal?
    Sent from my SM-G930V using Tapatalk
    Sep 01 2011
    Louisville Kentucky
    Leave it connected and zip tie it to the fire wall or somewhere else so that the tip isn't touching anything. I've got mine on top of the shock tower mount in the engine bay
    Veteran Member Three Rings bikerbob951's Avatar
    Jul 25 2008
    2006 Volvo XC70 AWD, 1936 Dodge D2 Touring Sedan
    Cincinnati, OH
    Why not just get a third bung welded in place, and do it correctly? Probably wouldn't cost more than $30.
    Vorsprung Durch Technik.
    1999 AEB B5 A4 quattro
    My new build thread. Instagram
    Sep 01 2011
    Louisville Kentucky
    Quote Originally Posted by bikerbob951 View Post
    There's that too... For me, I didn't want to go through the the trouble of reaching the downpipe bolts, and it's my daily driver and I haven't been able to negotiate the down time...
    May 25 2016
    Neenah, Wisconsin
    I'm learning tig welding soon so I'll probably weld one in myself. I have my exaust apart right now to replace my driveshaft so I figured I would wire up the gauge while the car is out of action.
    May 25 2016
    Neenah, Wisconsin
    Quote Originally Posted by SynapticA4TQM View Post
    Does is matter which one I remove?
    Sep 01 2011
    Louisville Kentucky
    Quote Originally Posted by wagongang View Post
    Don't remove your front O2!
    May 25 2016
    Neenah, Wisconsin
    Thanks for the help!
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    First off, your engine only has one bank. It is a I4. Second, yes, you cannot delete the primary o2 sensor, that one is important.
    Now, an option for you is to run the wideband o2 sensor only and use the simulated narrowband signal for the ECU. This would mean you only have to run one sensor period, and you can have your gauge and feed your ecu signal too. However, I would recommend against this since OEM is usually best.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Sep 01 2011
    Louisville Kentucky
    ^^^ that's the logic I followed... Better to leave the front/primary O2, and replaced my rear o2 with the wideband. That and the idea of trying to splice wires into the harness didn't sound like too much fun...
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Splicing isn't a big deal since you would just chop up the sensor harness not the engine harness.
    2000 S4- Working?
    Sep 01 2011
    Louisville Kentucky
    Quote Originally Posted by redline380 View Post
    That is true
    Dec 05 2007
    Code it out and get rid of it. Then use the secondary bung.
