Results 1 to 11 of 11
    Aug 09 2012
    Bay Area
    JHM Short Shifter
    Anyone know how to get rid of or has freeplay in the JHM short shifter? Mines pretty bad I think.
    https://www.youtube.com/watch?v=SYidBsDVd2M
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Is this just their shifter or the whole tri package? I would take the covers back off and make sure everything is tightened down. It shouldn't have that much play in gear.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Veteran Member Four Rings 65vetteC6's Avatar
    Jul 28 2007
    V8's
    In an Audi
    I dont think that has to do with the shifter, I think you probably have some worn linkage and bushings
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    Quote Originally Posted by 65vetteC6 View Post
    This. Check the linkage at the transmission.
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Senior Member Three Rings pule333's Avatar
    Jan 14 2013
    Mi4cxl
    london/UK
    To be honest, seems pretty normal to me.. Installed same shifter few months ago and sure it has as much play. Will make a vid a bit later and report back
    Vorsprung durch Technik
    Jan 14 2013
    Mi4cxl
    london/UK
    That's mine. Seems normal
    Aug 09 2012
    Bay Area
    Quote Originally Posted by pule333 View Post
    Ill take a look at the linkages to see if any of them are damaged or are worn out. Thanks for the video pule it could be that both our cars have the same issue haha. Once I check ill report back.
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    the linkage at the tranny is worn slap out... had the same thing and replaced it when my engine and tranny were out with the JHM version, money well spent
    PAST
    2004 Audi (B6) S4 4.2L
    2006 Audi (B7) S4 4.2L 25th Anniversary Special Edition #167
    Current
    2015 Audi (B8.5) A4 2.0T P+ Sline ECS-Luft-Technik Intake System/Air Scoop v2/Silicone Intake Tract Set with turbo muffler delete, GFB DV+ VTA Performance Blow-Off Valve, JHM FMIC/ECU and TCU (Automatic 8 Tip Quattro) Stage 2 tunes. Cosmetic RS4 Honeycomb Mesh Front Grille and Fog Light Vent Grilles
    Aug 09 2012
    Bay Area
    Quote Originally Posted by TarlCabot View Post
    Tarl, did the JHM version come with the entire linkages or just the ball joint piece
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    Quote Originally Posted by Kambesama View Post
    i got the bushings for the stabilizer bar (you can see the bag over the end of it)
    https://jhmotorsports.com/shop/catal...h=21_56_61_105
    and the solid linkage upgrade
    this part in well known to be worn slap out and need replacing with our cars, so i went JHM rather then spend the same amount on a plastic OEM
    i did not get their HD crossrod bar (not worth $125 to me)
    know all i need to get is the short shifter itself
    PAST
    Current
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    I have the Trio (since 2011) and couldn't be happier.
    Old Geezer, formerly known as Stud Muffin
