Results 1 to 14 of 14
Thread: Wtf audi
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    Wtf audi
    What type of bolt holds on the idler pulley? It doesn't appear to be a torx. Triple square? These cars cost so much money when new because the engineering and parts logistics makes no friggin sense. The tensioner pulley bolt is a torx why not the idler!??
    May 18 2012
    2005 S4
    Portland, OR
    The original bolts are hex drive and VERY prone to stripping out. I spent a couple of hours removing my tensioner because of it. Replacements are triple square, for this exact reason.
    May 30 2007
    MA
    Shit. What's the course of action to getting a stripped hex out?
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by SuperAvant View Post
    Well, sometimes you can hammer a larger hex into place, but I was unable to do this because I was trying to do the job with the lock carrier in service position rather than draining the coolant and removing it entirely. You can also grab it with some vise grips and go to town. I ended up using a plier wrench to get my stripped tensioner bolt out. However, if the idler pulley looks like triple square, then that's probably what it is, so try that first.
    May 30 2007
    MA
    Yeah I'm in The service position as well. I don't think I can take the whole front clip off without draining the AC correct? The coolant I'm not worried about because I'm replacing both auxiliary radiators. With the car in the service position it is very difficult to get a look at the bolt to see exactly what type it is .
    May 18 2012
    2005 S4
    Portland, OR
    Oh yeah, the AC as well. I was thinking about my B5 which intelligently put the condenser inlet and outlet on the same side so you can swing that out of the way and remove the rest. I've had the front of my B6 off as well...to do the AC. I think it's a triple square though for the idler.
    Apr 18 2012
    1995 Toyota Land Cruiser (FJ80/FZJ80)
    Central Texas
    make sure it's not just triple square, versus a munged Torx. i picked up a nice set of triple squares (aka ZZY or YZZ or some other Rush reference) on Amazon and have definitely used them on several services.
    i'm pretty sure the baffling mix of fastners is from a combination of separate design groups and wanting to make sure service procedures are distinct (e.g. the different fasteners around the intake manifold).
    - emilio
    Jun 07 2013
    West
    Triple Square or 12-pt Torx are used for high torque applications.
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by emilio View Post
    - emilio
    The current part number for the idler pulley bolt is absolutely a triple square. When I referred to the originals being hex, I was thinking that both the tensioner and idler were like this, but I believe the idler bolt may have always been that.
    Senior Member Three Rings AllroadMass's Avatar
    Oct 30 2015
    Massachusetts
    Lucky you, my front end is off at the moment. My bolt is a mangled hex.
    You should be able to loosen the entire front end, pull it out as far as possible with all the lines attached, rest it on the snub mount, and bolt the clip to the last hole on the frame to hold everything up that way you don't have to move the AC line. I did this all the time on the v6 passat when I didn't want to pull everything off. The top will have to lean forward because the lower left side has the PS lines cooler. The AC lines that connect to the condenser has some wiggle so you should be safe.
    Oct 30 2015
    Massachusetts
    Quote Originally Posted by 924Carrera View Post
    What don't you know!
    Sent from my Nexus 5 using Tapatalk
    Jul 15 2015
    Rochester NY
    Just get a cold chisel on the circumference, and loosen it, then after undoing it, throw it away. I had exactly that problem and that's how I dealt with it - two minutes max. Don't worry about the bearing; you can replace it if necessary. I got some off the interwebs.
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by AllroadMass View Post
    Why I still have a random shaking at idle, haha. I've chased that for months.
    May 30 2007
    MA
    Quote Originally Posted by neilpaku View Post
    Cold Chisel sounds good. Just ordered a triple square set off amazon. We shall see. Also replacing this with the JHM auto tensioner so I guess I couple try to pry the plastic pulley assembly off with the bitch persuader bar and get the two bolts that hold the mount on underneath.
    2014 R8 V10 - Gated
    2005 S4 Avant 6 Speed - JHM Stuff
    2017 TRDoffroad 4 Runner
