Results 1 to 24 of 24
Thread: Misfire 1.8t
    Established Member Two Rings Adamwagg's Avatar
    Jul 10 2016
    Bournemouth uk
    Misfire 1.8t
    Hi guys not started my car all week went to go out today and it's misfiring badly and everytime it's try to come on boost it obviously gets worse I plugged it into vag com and it has come up with misfire from cylinder 1. So will this be a coil pack I only put new plugs in it 4 weeks ago
    Sent from my E5823 using Tapatalk
    Sep 14 2015
    portage, mi
    yes coil pack or vacuum leak. pull each coil one at a time and see if it gets worse
    Jul 10 2016
    Bournemouth uk
    Vacuum leak??
    Sep 14 2015
    portage, mi
    boost, vacuum. whatever you want to refer to it as. check the suction jet pump to see if it split
    Jul 10 2016
    Bournemouth uk
    OK mate where would that be located sorry new to the 1.8t
    Sep 14 2015
    portage, mi
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    It just sounds like a coil pack to me, I wouldn't jump right on tracing down a vacuum leak before ruling out a coil pack, which is much more straight forward.
    Swap the cylinder one coil pack to cylinder 2 and see if the misfire code switches to that cylinder. If it stays on cylinder one inspect the wiring to that cylinder, if the code switches with the coil pack then replace said coil pack. A vacuum leak shouldn't repeatedly cause a cylinder 1 misfire only.
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    Coil pack harness... They are known to fail...
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
    Established Member Two Rings Shortrun's Avatar
    Dec 21 2015
    Ontario
    Did the fault exist before the new spark plugs?
    Jul 10 2016
    Bournemouth uk
    No not at all
    Feb 05 2014
    I bet you cracked the wires near the connector when changing out the plugs... It becomes very brittle... Just cut off the rubber boot (carefully) and see if the wires are bare... My money is they are....
    Feb 05 2014
    Jul 10 2016
    Bournemouth uk
    Wow of they look like that it means they are knackered yea
    Would that not cause multiple misfires
    Feb 05 2014
    Quote Originally Posted by Adamwagg View Post
    It would cause misfires anywhere the wires are cracked at... You can make a new harness pretty cheap and it will last for years to come...
    Jul 10 2016
    Bournemouth uk
    Are the 034 Motorsport harnesses any good is that your engine bay mate
    Feb 05 2014
    They are nice but they are the most expensive... I just bought new ends for $15 and crimped them in...
    Yes that is my engine....
    Jul 10 2016
    Bournemouth uk
    Cool and you just wired them all up yourself tracing each wire
    Feb 05 2014
    Yeah! Just do one at a time (do not cut off all 4)... It is only 4 wires each and you just need to crimp them in place..
    Man I hate UK pricing... you guys get ripped off in your country....
    http://www.ebay.co.uk/itm/SET-OF-4-A...EAAOSwGotWiSj3
    http://www.ebay.co.uk/itm/50-RED-HEA...3D371282719418
    Jul 10 2016
    Bournemouth uk
    Cheers mate tell me about it mate get ripped off on everything mate try running a car over here 😤
    Feb 05 2014
    Oh I know.. My dad lived there for 3 years... he would tell me that basically everything is double the price it is here in the states...
    Aug 10 2011
    330i ZHP
    Like I said in my original post, be sure to rule out the bad coil pack before you assume it is a wiring issue. If wiring (which it still may be) I would expect misfires at idle as well (?).
    Feb 05 2014
    Quote Originally Posted by MacFady View Post
    He can just move the coil to another cylinder to see if the misfire follows the coil.. If not, it's the harness.. Either way I would still replace the harness... They are mostly all junk by now...
    Dec 21 2015
    Ontario
    No not at all
    Maybe you have a bad spark plug. Try changing that first.
    Jul 10 2016
    Bournemouth uk
    Sorted coil pack cylinder 1 but am going to be doing the re wiring of the packs and do the 2.0l upgrade
