Results 1 to 13 of 13
    Senior Member Two Rings RamW24's Avatar
    Apr 07 2015
    Sugar Land, Tx
    Alignment after being lowered...
    For those of you lowered on springs. Did you have any problems after alignment? I'm lowered on H&R sports and my car pulls to the right after the alignment...
    IG @Project_S4 - B8.5 Prestige / GIAC / AWE / ENLAES / HRE / VORSTEINER / ECS / FLUIDAMPR / EUROCODE / V1 / P3
    Nov 28 2015
    Montreal, QC
    alignement wasnt right, go back. or let the spring settle for some times before getting the alignement done
    S4 B8.5 no track, just enjoying spirited driving.
    Mar 01 2016
    Gone: 2007 Acura TL Type S, 2004 Acura TL, 2005 VW Passat 1.8T
    NH
    Make sure they actually centered your steering wheel correctly, with the electric rack on these cars I think it is harder and they may have thought they centered it but it could have been a bit off. This happened to me when getting new wheels and tires.
    2013 S4 DSG | VX3 LED Fogs | LED interior conversion | LED reverse lights and plate lights | CR-15 Strut Tower Brace | 35% Window Tint |
    Veteran Member Four Rings stereojorge's Avatar
    Oct 15 2013
    2014 Audi S4 P+ DSG, 2015 Audi SQ5 Prestige
    Tampa, Florida
    Always want to get an alignment right at install, then a follow up alignment 2 weeks after springs have settled to see what needs readjusted. A GOOD motorsports division who does these kind of installs would include both alignments in the price of install. I have a go to guy for it and he always does it this way with any suspension work, whether it be Springs or Coilovers :)
    '14 Misano Red S4/APR Stage II+ DP ECU+TCU & UC/187mm Crank & AWE 57.55mm SC Pulleys/CMD Charge Chamber Intake/KW V1 Coilovers/EuroCode Sway Bars & AluKreuz/CR-15/034 Trans Mount/Apikol Rear Diff Mount/ECS Rear Diff Carrier Mounts/CMD Test Pipes/AWE Reso.Downpipes/AWE Track Exhaust 102mm Tips/Vossen HF-3 19" x 9.5"/Michelin PS4S'/StopTech Drilled Rotors/Akebono Euro Ceramic Pads/StopTech SS Lines
    Also: 2015 SQ5 Prestige | 2003 A4 Avant Quattro 6MT
    Previous: 2010 S4 P+ | 2008 A4 S-Line
    Mar 21 2015
    Everyone Ive asked says get the alignment done the day of the suspension work and that's all you need. No difference when the springs settle.
    Apr 30 2014
    B8.5 S4, A3 e-tron
    CA, Bay Area
    Day of and 2 weeks or so later.
    Apr 07 2015
    Sugar Land, Tx
    Quote Originally Posted by stereojorge View Post
    Quote Originally Posted by mlavelle92 View Post
    Its been a little over 2 weeks, guess its time to go back. Thanks
    Veteran Member Three Rings bayonet14's Avatar
    Aug 07 2013
    BMW 335i
    Pinelands NC
    +1
    Senior Member Two Rings S4ilicious's Avatar
    Feb 09 2015
    2001 A4 2.8 Quattro
    Bay Area, California
    Op, I would wait a couple days for the springs to of settled before doing an alignment. That's what I did and everything went fine but it seems like you waited a bit longer for that (:
    2014 Brilliant Black | 034 Motorsports filter | 034 DSG Tune | Black Fine Nappa Leather | Prestige | 7 Speed S-Stronic | Apr tune | Roc Euro Intake | X pipe Exhaust | Akebono Brake Pads | Deval CF Rear Diffuser | ECS Spacer Flush kit 10F 12.5R |
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    I did control arms when I lowered my car on kw has, my alignment straight on. This car does have a tendency to pull to one side especially with uneven roads and/or stage 2 and beyond in power..
    Sent from my SM-G925V using Audizine mobile app
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Not to derail the thread, but just saw this and couldn't resist posting ...
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Veteran Member Four Rings DBFL's Avatar
    Jan 01 2016
    2016 S4, 2018 Ford F-150, 2022 Audi SQ5, 1982 Audi Coupe
    Tampa Bay
    Not true. My installer included two alignments with all suspension work, so I had an alignment when my coilovers were installed. Went back a few weeks later - about 500 miles - and had a second alignment. It wasn't way out of spec when I went back, but it was still out from the springs settling.
    Two alignments is definitely the way to go. Premature tire wear will cost you more than the cost of a second alignment.
    2016 S4 P+ | 6MT | Sports Diff. | Tech. Package
    S4 Build Thread
    Feb 09 2015
    2001 A4 2.8 Quattro
    Quote Originally Posted by LYKUNO View Post
    Lolz good one! A human Halibut ��
