Results 1 to 14 of 14
    May 27 2016
    Maine
    Car remote range
    I am the new owner of a 2010 A4. I have found that the remote range really sucks. I can unlock the doors from about 40 ft away but have to be within 20 ft. to open the windows(used Carista to set this) which to me seems a little useless on a hot day. Both of my remotes do this and I have installed new batteries in them. I have seen issues with this with earlier models(b6,b7) where you can lengthen the antenna to get more range but on the b8 the antenna is part of the FM antenna. Can anything be done to extend the range on my b8?
    Tim R.
    2010 A4q MT Premium+, Brilliant Black
    Injen intake
    Eiback Sportline Springs
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    Try holding the remote to your cheek, seems to improve the range a bit. But unfortunately yes, the range is pretty dismal.
    My 2009 A4 Prem+ Build thread
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    _
    Saw this years ago on Top Gear, and have done this ever since.
    2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW
    1999 A4 Avant | Cactus
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by bakedziti View Post
    Ha, that's awesome. I miss that show! And yes, the range is garbage on these cars while my truck will reach further than any I've seen.
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Quote Originally Posted by Tim R. View Post
    This range is way to low!
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Mar 26 2012
    Charlotte, NC
    I don't mind the range anymore. I had someone clone my lock/unlock signal and they went into my car and robbed everything inside. I have them on my dashcam.... So if the range was better it might happen more often...
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    I hardly ever touch my key fob. Since it unlocks when I reach for the door handle, I dont really need it to open any sooner than that, lol.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by adamazing View Post
    You suck! I've been thinking about doing a retrofit wit the push start and all that.
    Apr 02 2016
    none
    mine sucks to
    what kills me is that i can start my truck from inside my office building using a prestige alarm i install in 06 but i have to be about 5 cars away just to unlock the fuken door on this 2014 S5
    i did see something about the antenna cracking on these cars but even after the fix the range is still short
    Apr 26 2014
    San Diego, CA
    I guess that's one feature I wish we had, or had easy access to retrofit... remote start. I'm pretty OCD about letting my engine warm up to operating temp (or close enough) before I drive off. It would be nice to let the car do that while I finish getting ready for work in the morning.
    Senior Member Two Rings mecg's Avatar
    Apr 12 2016
    Readfield, Maine, USA
    Actually, the manual says "It takes a long time to warm up fully when it is running at idle. However, wear and noxious emissions are especially high when the engine is warming up. So you should drive away as soon as you start the engine and avoid running at high rpms while the engine is still warming up." My '08 Saab 9-5 manual says basically the same thing - don't warm up at idle and instead drive off to warm the engine up faster - just don't over-rev the engine until it does warm up.
    2013 Audi A4 quattro Prem, ZF8, APR Stage 2+ 93/E85 Tune + Cast Downpipe/HFC, R8 coils, aFe Dry Pro, Eurocode Intercooler pipe, Turbo Muffler Delete, Fitch Fuel Catalyst, RS Grille, Tinted windows, Audi logo puddle lights, Interior LEDs, VCDS tweaks, 18x8 Andros R9 Wheels w/ Michelin Pilot Super Sports
    2008 Saab 9-5 2.3T BCB², K&N, Fitch Fuel Catalyst, Interior LEDs
    May 27 2016
    Maine
    Quote Originally Posted by mecg View Post
    And do not use the coolant temp to determine if the engine is warmed up. Use the oil temp.
    Tim R.
    Injen intake
    Veteran Member Four Rings Party_Marty's Avatar
    Nov 02 2015
    Sector 9 Long-board, Rugby Kit
    In the woods
    Quote Originally Posted by The Infiltrator View Post
    I would be super super interested in this as well. I kindov just counted my losses and told myself that my next Audi will have 3g nav, keyless entry, etc. etc....
    ---------------------------------------------------------- IG: party_martyy ----------------------------------------------------------------------
    ---------------------2014 A4 - 6 Speed - Phantom Black Pearl -------------- Peep the Build ---------------------
    Apr 12 2016
    Agreed!
