Results 1 to 15 of 15
    Aug 26 2014
    Fort Wayne, Indiana
    Angry Seized Wheel Bolt
    Gang,
    I went to rotate the tires on my '08 S4 this weekend and didn't get very far. I was working on the security bolts first and they all came off pretty easy except for the the front passenger. Wouldn't budge. Damn. I worked at it and tried a few things for a while with no luck. Decided to quit and regroup. Fast forward a couple of days and I just happened to be driving by my Audi dealer and thought I'd stop in and see if they could get it loose. Most of the techs had already gone home for the day, but they drove it around back to check it out. Well, they didn't get it off either.
    So, what do you do in this situation? I'm almost ready to try hammering a slightly smaller socket onto it with a rubber mallet and trying that trick. I don't think I can really get to the bolt enough to get PB blaster on it. I suppose I could have someone weld a nut on the front. Any good tricks?
    Thanks in advance for any pointers.
    Feb 24 2010
    And have never been happier
    Quote Originally Posted by grouchycrouchy View Post
    Gang,
    Few thoughts come to mind and you may have already tried them..
    - Is it possible to put something on the lug nut and tap it with a hammer? Goal is to break the "seal" and then try to loosen it again?
    - Also, this might sound odd, but it works in many applications, what about trying to tighten it just a nudge and then loosening it? Put a ratchet and tap it with a hammer just to break that seal.
    Have you tried with wheel off the ground using an impact (low setting)? Some have that hammer feature where it may just move it a nudge perhaps
    Would you be able to post a pic of the lug nut?
    Switched to Tesla and have never been happier. No more shady mechanic bills and excuses - oil top off before an oil change is normal or dealing with outdated forums that have image size limitations. And no more dealing with vendors that do not provide horsepower numbers but sell you random things by labeling them as performance parts. No more dealing with the Audi dealership and having to buy custom Audi specific tools. Wow. I can't believe I lived through all of this. Money pit.
    Established Member Two Rings Koopsdeville's Avatar
    Jul 25 2016
    I guarantee u get it off by using a pipe. Put a solid socket type wrench on like the one that comes with the jack in the trunk. Put a pipe on it, the bigger the better. Make sure it's a solid steel pipe. Make sure the tires are on the ground when doing it. Im a tool maker/cnc machinist by trade and I've never had a bolt I couldn't get off using a pipe. Good luck
    Sent from my HUAWEI MT7-TL10 using Tapatalk
    Veteran Member Four Rings roboto_1337's Avatar
    Jul 05 2016
    B7 S4 6MT, Porsche 958.2
    Ontario, Canada
    Gang,
    I would try soaking it with PB blaster when it's cold... The thing about penetrating oils is that they'll work into the thread to break it free....
    Give it a good soaking and wait 15mins.... Another application and wait five. Then set your tire iron up in a good location to kick it and give it a good hoof with the heel of your boot.... Should pop free...
    Hope it works for you... Good luck
    Senior Member Three Rings joe@dubaudi.com's Avatar
    Mar 21 2010
    B7 S4 Avant / 2014 Allroad / 2015 Q7 TDI
    Point Pleasant NJ
    Like koopsdeville said. A pipe will work over your regular breaker bar/lug wrench. Leverage is your friend.
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    Quote Originally Posted by [email protected] View Post
    Agreed - just make sure that socket is on there nice and snug otherwise you run the risk of rounding the bitch off.
    2014 R8 V10 - Gated
    2005 S4 Avant 6 Speed - JHM Stuff
    2017 TRDoffroad 4 Runner
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    Motherf***ing securety bolts, f***ing F***.
    Reduced my lifespan for 1 hour, BUT I GOT IT OFF! We have a saying, which directly translates "The smarter one gives up."
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    I had to have all 4 of mine drilled out. Not doing that again.
    Old Geezer, formerly known as Stud Muffin
    Jun 07 2013
    West
    Impact wrench or repeated fast hammer taps on regular wrench.
    Senior Member Three Rings AllroadMass's Avatar
    Oct 30 2015
    Massachusetts
    I've used the bar on the jack, as you have in the picture, plenty of times and works like a champ. Detached it and put it on your 1/2 socket or lug nut wrench. Good luck on the other side.
    May 30 2007
    MA
    You need a bigger breaker bar!
    Aug 26 2014
    Fort Wayne, Indiana
    Yea, venom's got it right. That's basically what I've been trying. The problem with those damn security bolts is the key slips out of them so easily. Thanks for the tips, gang. I'll get it out if it's the last thing I do.
    Aug 26 2014
    Fort Wayne, Indiana
    Well, I ended up taking a torch to it, but finally worked it out. I proceeded to throw all of the security bolts in the trash and put normal ones back in. Went ahead and put new pads in while the wheels were off. Also painted the calipers red with G2. Looks good and, as you know, red calipers add about 15hp!
    May 10 2015
    Slovenia
    Don't be joking... 40bhp on the wheels MINIMUM!
    James May: "Yes."
    Jul 05 2016
    Ontario, Canada
