Results 1 to 7 of 7
    Sep 11 2013
    91 Toyota MR2
    south bend, in
    Quattro Rear end clunky?
    ive had other awd vehicles before, but this car since ive owned it 5+ years now, there seems to be a slight clunk coming from the rear end to which I can only this that is the rear end diff. Its only noticeable when taking off from a complete stop and sometimes goes into 2nd gear. I can feel it as well not only hear it. Im wondering if this normal or typical for the Audi Quattro awd system? It is concerning and sometimes annoying, but just want to make sure my rear end is not going out.
    Established Member Two Rings Mr. Wolfsberg's Avatar
    Jun 02 2015
    Indiana
    Most likely it's the front upper diff mount, upgrade with a poly mount to eliminate the sound for good. Akipol is a good option but it's not cheap
    Sent from my MotoG3 using Tapatalk
    Veteran Member Three Rings tHatOne guY's Avatar
    Aug 20 2012
    06' Yamaha R1...Raven
    Mesa, Az
    Hopefully your culprit is the mount/bushes. I picked up a used diff and rebuilt it to throw in as my factory rear diff has way too much backlash.
    Senior Member Three Rings thetikm's Avatar
    Jun 24 2014
    NC
    I got the powerflex race bushing. Much cheaper than the other stuff. No increase in nvh
    Veteran Member Three Rings 5ktq's Avatar
    Aug 15 2016
    Western Canada
    You don't mean the kind of.. Low frequency noise/feel you get when turning full lock at low speed, right? That's just the crab-walk noise, normal on all the quattro I've had.
    Sep 11 2013
    91 Toyota MR2
    south bend, in
    Yes, almost like that noise but I get it more when just taking off from dead stop and going straight.
    Active Member Two Rings kNightsfallen's Avatar
    Aug 08 2016
    Fairfield, CT
    Quote Originally Posted by neemo6 View Post
    Could be the trans mount, nose mount, engine mounts.... Control arms.
    Audi's Quattro system is second to none. I've seen maybe 3 differs replaced in 10 years for noises.... And every single one didn't fix the problem. 99% sure your problem lay elsewhere
    Sent from my iPad using Audizine mobile app
    Audi Master Technician
