    Established Member Two Rings pcardenas's Avatar
    Sep 04 2014
    S4 B8, Audi Q7
    México
    Question Options for a Custom Build BBK ????
    Hi,
    is hard to believe there is no other option than buying a expensive BBK to solve braking issues on TRACK DAYS.
    Im looking to use FRONT CALIPERS from a wasted Audi q7 2009 , seems to be brembo 6 pistons.
    Anybody has taken this path??? Q7 front brake conversion????? any tips????
    _________
    Paulo
    S4 B8 2011 , Dual pulley , Revo 1+ , custom Brakes , bilstein b8 , H&R Rear Sway Bar, CR15 mod, Pipercross Air Filter , Magnaflow xPipe 11386
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    Yes there's a post about it on here. Rotor source is the issue as Q7 has different bolt pattern and offset
    http://bfy.tw/7NXQ
    Sent from my Nexus 6P using Google's ProjectFI
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Apr 05 2016
    Portland, OR
    I don't have time to look at this now but here:
    http://bfy.tw/7NXK
    Geoff
    Sep 04 2014
    S4 B8, Audi Q7
    México
    Thanks,
    well no single one has a z18 z19 caliper setup on B8 platform. seems that q5 4 pistons calipers are the "cheaper" option available to improve our brake system.
    _________
    Paulo
    Veteran Member Three Rings Zaxon55's Avatar
    Mar 13 2014
    Centennial, CO
    Quote Originally Posted by pcardenas View Post
    Thanks,
    I have the 19z calipers on mine. There is a nice kit for it.
    2013 B8.5 - Moonlight Blue Metallic
    - VMR V710 19x9.5 -APR Dual Pulley -AWE Coldfront System -Eurocode Alu Kreuz -Front/Rear Sways and Endlinks -ST Coilovers -SPC Control Arms -034 Transmission Mount and Diff Mount -Roc Euro Intake -Porsche BBK with ECS Drilled/Slotted Rotors, SS Lines, Pads -CR-15 Upper Strut Tower Brace -AWE Touring Exhaust (102mm and stock downpipes) -Deval Diffuser, ECS front and rear spoilers.
