Hey guys. I have an A6/C5 quattro 2.8L and I'm having an "overheating" problem. The auto-check system is saying my engine is overheating (the coolant at this point is topped up). My coolant temp on the dash (the senor for this is new) gets to middle point and stays there, which is normal. The radiator fans however would not come on even after turning on A/C to full blast. I tested the fans with 12 volts and they work with direct power. When I tested the thermo-switch at the lower rad hose, the fans still didn't come on. I tested the voltage at the wire that gives power to the fan control module and it was good. As a result, I changed the fan control module today. Fans are still a no go and my auto check system still says overheat even thought coolant temps and coolant levels are good.
I did find out however my A/C condenser isn't spinning even though the pulley is.
My question is, could the non-spinning of the a/c condenser cause the "overheating" symbol? Could it also cause the radiator fans to not spin?
And what else should I check to figure out why radiator fans aren't spinning?
Oh and could it be that the thermo-switch AND the FCM were bad?
Any feedback is greatly appreciated
