Results 1 to 8 of 8
    Feb 06 2013
    WV
    Aeb engine in a 2001 A4?
    Most cases this makes no sense. However in my situation I have bought a 2001 avant and would like to swap in my 2.0 aeb built monster. Is it possible? What would it take? Better to sale and go 06A?
    Thanks
    If you can read this thank a teacher, since its English thank a veteran...
    Audi make a great car, but their heater cores are, well $h!t.....
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Not a direct drop-in by any means:
    -AC compressor and location a little different. You might be able to use the AEB accessory bracket, but I can't verify. Not sure if AC is important to you.
    -AWM ECU and cluster expect oil pan sensor. The AWM oil pan might work on 058 block, but I can't verify.
    -2001 is DBW obviously, so swap over throttle body.
    -I think oil pressure switch connector might be different, so swap AWM oil pressure sensor onto AEB (unless connector is the same).
    -power steering pump and/or lines might be different?
    -alternator connectors are probably different, maybe just move AWM alternator to AEB?
    -might have to use AEB lower radiator hose. AWM thermostat/housing is located differently, so AWM lower rad hose might not fit.
    That's all I have off the top of my head.
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
    Feb 06 2013
    WV
    What about the crank trigger? I thought the crank wheels are different designs?
    Veteran Member Three Rings S4NIK8's Avatar
    Jun 09 2009
    RS6 6 speed
    Somewhere Cold
    I recently did this for the same reason as op, no issues with the crank wheel (swapped crank sensor) but the camshaft sensor wheel needs to be changed
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Quote Originally Posted by S4NIK8 View Post
    Along those same lines, the AWM ECU will expect a VVT actuator, so you could swap the CCT from AWM onto AEB head. Or you can code out VVT or plug in a resistor to the harness.
    Veteran Member Four Rings ray4624's Avatar
    Nov 27 2010
    mass
    yea part numbers are now the same for the trigger wheel as well. The old 058 wheel is obsolete. I have an 06a wheel in my 058
    Senior Member Three Rings crazyquik22023's Avatar
    Jan 30 2012
    Brunswick, Ohio
    Why not just swap over the entire engine harness and ECU from the AEB? To avoid any wiring/compatabilty issues
    Nov 27 2010
    mass
    Because then you lose all the advantages the 2001 has with tuning etc
