Results 1 to 11 of 11
    Veteran Member Four Rings achilleas101's Avatar
    Mar 09 2010
    2015 Acura RDX
    Falls Church, VA
    anybody had coolant level go back up after being several oz below min level?
    So this was weird. after i did my oil change, i noticed my coolant level was low. Engine was a little warm but it was below the min level. I decided to let it sit overnight to see how low it got, and sure enough the next morning when the coolant was cold, it had dropped even lower.
    This is how it looked the next morning; pen mark is where it was after the oil change.
    So i had some G12 coolant around, mixed it with distilled water and filled it up back to just above the min level. Over the next couple days, the level rose and receded as expected staying below the max level after driving around, and receding to the min level by the morning.
    Well, today i get my car back from the dealer (had to take it in after - long story short and talked about in another thread - i somehow screwed up and got an o-ring stuck in the throttle flapper or whatever its called at the base of the air intake), and i pop the hood only to see that the coolant reservoir is almost overflowing its so full. I open the cap and it's full to the brim. I turkey basted at least 10 oz of fluid out to bring it back down to the 'max' line.
    anybody seen something like that before? i highly doubt the dealer would've added any coolant. i know they do weird stuff sometimes, but that's just not something that would make any sense.
    Gone but not forgotten:
    2013 S4 Imola Yellow | Black leather/Silver Alcantara | 6MT | B&O | Sport Diff | Silver 19x8.5 Avant Garde m550 | XPel Ultimate full hood/fenders | Eurocode SS
    2003 A4 3.0 6MT;
    1998 Acura Integra GSR 5spd
    Gone and most likely in a junk yard somewhere: 1990 Toyota Tercel
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    I have had a similar experience, but the level did not go as high as yours. Not sure what is going on with this.....but do you have the "water gurgling behind the dash sound" when the car is started up, when cold?
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    Quote Originally Posted by S4'ed View Post
    When in doubt, bleed the system again.
    Veteran Member Three Rings creativecody's Avatar
    Jul 20 2012
    Quote Originally Posted by achilleas101 View Post
    ..........i highly doubt the dealer would've added any coolant. i know they do weird stuff sometimes, but that's just not something that would make any sense.
    .........Don't "highly doubt" anything with it comes to dealer service techs.......My initial guess was that the dealer topped off your coolant to the brim.
    2013 S4
    APR Stage 2+ (Dual Pulley & Ultracharger) | APR CPS v2 | Milltek Resonated | Bilstein PSS10 Coilovers | Eurocode Alu Kreuz, Front/Rear Sways, Front/Rear Endlinks | Eurocode Transmission & Differential Mounts | SPC Control Arms | Stoptech BBK 380mm (front), Stoptech Rotors/Pads (rear), SS Lines | HRE FF01 19x9.5 et45 | Michelin PSS 265/35/19 | ECS Carbon Fiber
    Jun 28 2016
    US
    ^^^ That's what I'd think too.
    Veteran Member Three Rings VenturiRS's Avatar
    Dec 27 2008
    I was expecting someone to respond "Yea, after I topped it off" by now. Audizine has changed.
    B8.5 Estoril Blue S4 | P+ | DSG | SD | ADS | B&O | CF | Nappa | Advance Key | CF Badges
    Mar 09 2010
    2015 Acura RDX
    Falls Church, VA
    Hm i dont think so but i may uave heard it a few times. For some reason the way you described it sounds familiar.
    2003 A4 3.0 6MT;
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Sounds like an air bubble trapped, causing coolant to pool somewhere it isn't supposed to stay?
    2021 Audi S4, P34 Intake
    Jun 29 2015
    They clearly topped it off. If there was air it would drop not go up. Obviously they should not have if it was at the min level.
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    Dealer topped off coolant, standard practice after oil change.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Nov 23 2018
    Ontario Canada
    I had this exact thing happen to me today. Coolant level was always at the proper level, yesterday I heard gurgling. When I shut the car off and now today it’s below min, started the car and revd it upto about 2500 rpm and it started filling up to max again. Let the car sit for 5 hours with the cap off and now it’s low again.
