Page 2 of 5 FirstFirst 1234 ... LastLast
Results 41 to 80 of 168
  1. #41
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    Yes! You bought Alberts mounts from Poland. He's a great knowledgeable guy to deal with. He started making poly and solid mounts for my c4 urs4 upon requests amongst many other parts.
    I hope his business start catching on a lot more over here. Great products especially for the older chassis's.
  2. #42
    Dec 15 2015
    Perth Western Australia
    Whilst do calculations on my fuel demand from my Walbro 450 '274'. I found I would max out my pump and it would limit the amount of power I could make on E85.
    Not wanting to run 2 fuel pumps in the tank I decided to use a MSD2351 fuel pump voltage controller to boost pump voltage only when running E85 and only when required.
    Walbro rates the pump to 16vDC max. At this voltage, It will be more than enough flow to supply my fuel requirement. I have chosen this route to limit the heat that 2 pumps would have made in the tank. The controller is fully programmable based on manifold pressure.
  3. #43
    Dec 15 2015
    Quote Originally Posted by landfill View Post
    Albert is a pleasure to deal with. He was the only person I found making a full poly kit for the rear and also poly sub-frame mounts. I wanted firmer mounts for the front sub-frame but just couldn't bring myself to put the solid Aluminium ones in the front.
  4. #44
    Quote Originally Posted by Perth_RS4 View Post
    Dude that's a good idea
  5. #45
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    Or run 1 brushless pump and be good for 1khp
    Sent from my GT-I9305 using Tapatalk
    2000 Achat S4
  6. #46
    Jul 04 2012
    Woodbridge, VA
    That's badass! I please post your install when you're done!
    Subd
  7. #47
    Dec 15 2015
    New intake has arrived from THE-Tuner.
  8. #48
    Veteran Member Four Rings davkav's Avatar
    Dec 04 2008
    Dublin, Ireland
    That is VERY sexy
    -Dave
    B6 A4 USP Avant 1.9 TQ 6M (01E) - 71r - Revo 550 File
  9. #49
    Mar 21 2011
    '06 B7/B6 RS4 JHM Stage 1+ S/C, '04 Ford Expedition, '08 Lambroghini Gallardo SL TT
    Dubai
    Hi mate, im watching your thread with interest as its something i want to do here in dubai. I was thinking about going the 3.0L route though- what do you think? We only have 2 B5's here in the whole region and both are RS4's.
  10. #50
    Dec 15 2015
    Quote Originally Posted by iconic78 View Post
    I would love to go the 3.0L route. I'm not sure it is worth it with anything less than TTE780's. Spool on the TTE550 is simular to the RS4 K04's. It would be nice to have boost a little bit earlier, But for the cost, its just not worth staying with such a small turbo.
    Put it this way. You have to build the motor the same anyway(same costs involved). If built properly, It should be able to handle 1000hp. Would you prefer spool to be 3-400rpm earlier or would you prefer 400hp more with spool occurring 3-400rpm later?
    Were i live there are only 2 B5 RS4's in the whole state. It is cool having a rare unique car that only a real enthusiast knows.
  11. #51
    Mar 21 2011
    Dubai
    So how would you build it? B5's are new territory to me vs the B7. I'm like you whose not Afraid to spend the money on where it counts.
  12. #52
    Dec 15 2015
    If I open the motor up, I would put a 3.0L crank in. Pauter rods, Mahle pistons but only 0.5mm larger. This would make the build a '2.9L' technically. From there I would use all the parts im currently using.
    I would keep the AZR/ASJ heads. Without them its not really a rs4 motor anymore plus they flow better than the 2.8 heads.
    If money was no issue, I would put a set of titanium conrods in.
  13. #53
    Established Member Two Rings QuattroS.Africa's Avatar
    Jan 23 2012
    95 Audi-Porsche RS2 Avant, B7 RS4 Avant Imola, B8.5 allroad, B5S4 Avant build (from C5 allroad 6mt)
    Durban,South Africa
    Goodness me , this is about the most comprehensive , all-encompassing B5 build I've seen.
    Do you perhaps have an instagram account where you post updates?
    All the best.
    1995 Audi Porsche RS2 Avant -NogaroBlue
    1999 B5 A4 Avant 2.8q soon to be B5S4
    2002 C5 2.7T allroad MQ- (Static)- breaking to build S4 Avant
    2006 A3 3dr 3.2 q 6mt- daily driven
    2008 B7 RS4 Avan Imola Yellow
    2013 A4 allroad 2.0T S-Tronic - mommywagon
    Instagram: @quattro4sprung
  14. #54
    Established Member Two Rings piffington's Avatar
    May 17 2016
    2000 b5 s4 in the process of reviving, 1997 chevy k3500 CCLB twin turbo cummins build
    ny
    Hey very nice build, just have a question for you, how do i get in touch with this albert fellow about some bushings? Let me know, thank you
    piFF
  15. #55
    Dec 15 2015
    Quote Originally Posted by QuattroS.Africa View Post
    All the best.
    Thanks mate. I post all my updates I remember to here. No instagram account here.
    Quote Originally Posted by piffington View Post
    You can get in touch with him through his website. Akmotorsport.net
  16. #56
    May 17 2016
    ny
    Thanks alot, good luck with everything ill be keeping tabs on the build 👍
    piFF
  17. #57
    Mar 21 2011
    Dubai
    What's your opinion on using KKK K16's?
  18. #58
    Dec 15 2015
    I would use the TTE950 over genuine kkk k16. Reason being is they are not a direct fit. A fair bit of custom work is required. If you do all that work, would you not want the best turbo?
  19. #59
    Dec 15 2015
  20. #60
    Dec 15 2015
    Turbos fitted today now all the seals I wanted to change are done.
  21. #61
    Aug 24 2014
    Newport Beach, CA
    Super clean, some painting makes a world of difference to the undercarriage components.
    2024 M3 Comp xDrive
  22. #62
    Dec 15 2015
  23. #63
    Jul 04 2012
    Woodbridge, VA
    Where'd you get the bracket for the oil separator ? I have the same one I have not installed. Also, where do you have the drain going to?
  24. #64
    Dec 15 2015
    Quote Originally Posted by vavJETTAw36 View Post
    The bracket was there already. It usually has a cover over the top of it. In the tiptronic cars, a vacuum pump sits in it i believe. Its empty in the Manuel cars. I modified it with my trustee dremel until I was happy with how it sat and then painted it. The return Line goes back into the sump with an inline check valve.
  25. #65
    Dec 15 2015
    Anyone on here used this bearing? Looks like it has a few shims. Any advice for setting it up?
    I have also purchased an adjustable pedal stop.
  26. #66
    Dec 15 2015
  27. #67
    Dec 15 2015
    Have all the parts required now to put the engine and gearbox back in. Hope to have her running again by the end of the week.
    Some of my coolant hoses were looking abit average so I ordered a set of silicone coolant hoses to replace all of them. Should give me some more confidence in the car for the cross continent trips that are planned.
  28. #68
    Veteran Member Three Rings rnagy86's Avatar
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    How makes that fancy pedal stop?
  29. #69
    Feb 19 2011
    Earth
    Quote Originally Posted by rnagy86 View Post
    looks like ul en's one.
    2000 Achat S4
  30. #70
    Dec 15 2015
    I got it from Arlow's in germany. They have an ebay and a website.
  31. #71
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    200 EUR for that?! My god. :) I am glad I made mine for free :P
  32. #72
    Dec 15 2015
    Yeah it was ridiculous priced. Honestly was the only one I could find 😅
  33. #73
    Veteran Member Three Rings uponone nogaro's Avatar
    Sep 13 2011
    01 Silver S4, 00 Noggy S4 Sport Package, B8.5 Dsg S4 Dual Pulley,240sx w/2j swap
    Bay Area CA.
    sik build
  34. #74
    Dec 15 2015
  35. #75
    Dec 15 2015
    More progress.
  36. #76
    Dec 15 2015
    My fueling setup. Missing from pictures is the fuel pump voltage controller (was programming it). Wiring all upgraded along with a vacuum line running from manifold to under the rear seat to the fuel pump controller. Fuel pump controller has its own power wires running to the battery power leads under the dash.
    This fuel set up should work for my power goals in the future(E85 3.0l TTE780)
  37. #77
    Feb 19 2011
    Earth
    Falco, did you sell your k04's?
    2000 Achat S4
  38. #78
    Dec 15 2015
    The standard ones were sold a long time ago.
  39. #79
    Dec 15 2015
    More pics of the fueling setup.
    Refreshed my front shocks.
  40. #80
    Dec 15 2015
    Wired in my AEM widebands today. They are lined up for the drivers line of sight when the glove box is open. Top one is passangers side bank and bottom is drivers side bank. They are wired into the main fuse box together so i can know if the fuse blows one day.
    The sensors are mounted just infront of the cats.
