Results 1 to 8 of 8
Thread: VCDS Question
    May 20 2010
    VCDS Question
    I was recently having issues with my a/c (wound up needing to replace the condenser and refrigerant pressure switch). Shop pulled about 7 codes for the HVAC. However, whenever I would scan with VCDS, it would not even pick up on HVAC (8- HVAC; would go through the three attempts and timeout). I could scan the remaining modules I have, but not that one. I have an authentic Ross-Tech cable and full version of VCDS.
    Any idea why that's happening?
    Another issue I'm having is that the brake pad sensor light is illuminated, despite having new pads/sensors. I know i can short it to make the light go out, but I'd prefer to actually fix the issue. Where do the wires go from the wheel well, so I can trace back where it may be broken?
    Thanks in advance!
    Senior Member Three Rings AllroadMass's Avatar
    Oct 30 2015
    Massachusetts
    Did you figure out why VCDS wasn't able to connect to the HVAC module?
    May 20 2010
    No, I've been emailing back and forth with Ross-Tech, providing scan logs and debug logs to try to figure it out. Still not connecting.
    Veteran Member Four Rings LakeTahoeQuattr's Avatar
    Jan 04 2013
    '07 JHM S6, '21 TTRS, '06 CTT, '20 Supra GR
    Zephyr Cove NV
    You have to change the baud rate or something to connect to some HVAC units. Just google it, there are plenty of other people with the exact same problem. I had the same issue and changed some setting in the adapter settings in windows and it worked instantly.
    21 TTRS - track whip 1
    20 Supra GR - track whip 2
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    May 20 2010
    They replied back to me late last night, saying that i had an unusual and out of date calibration file, and to use the one they attached in the email. Haven't gotten a chance to test it out yet.
    Jan 04 2013
    Zephyr Cove NV
    http://www.audiworld.com/forums/vag-...ac-a4-2583856/
    This is what I was referring to and what worked for me.
    Did you receive a calibration file from rosstech for the hvac? I was informed there were no label files for the hvac unit...
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    May 20 2010
    Quote Originally Posted by LakeTahoeQuattr View Post
    I don't see any comm errors, just no comm at all to the HVAC. They didn't specify whether the cal file was specifically for the HVAC. The calibration on my cable is what I think they were referring to. So when I get a chance to test (in about an hour), they provided a few steps to follow to see if it does, indeed, finally connect to the HVAC, and run another scan.
    May 20 2010
    Update: Calibration file took immediately upon hitting "Test" in the options. Went to 08 - HVAC and it read it on the first try!
