Results 1 to 8 of 8
Thread: Trunk unlocking
    May 27 2016
    Maine
    Trunk unlocking
    I have searched on multiple forums and have not found an answer.
    When i first got my(new to me) A4 the trunk would lock and unlock with the doors. Now I have to either release the trunk from the drivers door latch or use the remote. At no time am I able to open the trunk by lifting it and pushing the release above the license plate.
    I do not know what is different or what I did to disable this. I have looked through the manual, lock settings in console and even tried to fix this through Carista but no luck.
    I just want the trunk to unlock when my doors unlock and stay unlocked if my doors also stay unlocked.
    Any ideas?
    Thanks
    Tim
    Tim R.
    2010 A4q MT Premium+, Brilliant Black
    Injen intake
    Eiback Sportline Springs
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    _
    Quote Originally Posted by Tim R. View Post
    Any ideas?
    Thanks
    Tim
    Sounds like the central locking option in your MMI/AMI has been disabled for your trunk. I am not with my B8 to confirm the menus, but it should be Car > Central Locking > Trunk
    2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW
    1999 A4 Avant | Cactus
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Veteran Member Four Rings a4_matt's Avatar
    Sep 19 2006
    Wanted: e30 calyso vert!
    Chicago
    Quote Originally Posted by bakedziti View Post
    agree with this, but also not near the car to check.
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    I had the same issue when I got my S4.....my recollection is that I had to change the MMI selection...but the menu choice labels seemed backwards.....
    Veteran Member Three Rings Townending's Avatar
    Aug 29 2014
    Claremont, CA / Big Bear, CA
    It's a long shot, but make sure valet mode is also turned off. IIRC trunk unlocking is disabled in valet mode.
    2009 BMW E92 M3 - SilverStone II - Full IPE F1 Exhaust - Stage 2
    2013 A4 Quattro - Moonlight Blue
    Mods : APR K04 E85 - Solowerks S1 Coilovers - Treadstone TR8 - RS4 Honeycomb Grille / Foglight Grilles - ECS Intake tubing - Hardwired Valentine 1
    034 Motor Mounts / Tranny Mount + Insert - ECS Rear Diff Mounts + Insert - Alzor Style 349 Wheels 19"x9.5" ET 40 - 265/35/19 Michelin PSS - VAGCOM Mods
    Veteran Member Three Rings jcs's Avatar
    Jul 22 2009
    GTA, ON
    ^ what he said. Sounds like the Valet button in the glove box got activated. Press it again to disable if the light on that button is on.
    2009 A4 2.0T - APR Stg II+ + Eurocode HFIC + Eurocode HFC (Uninstalled) + Eurocode Twin Tip Catback (Sold) + Gloss Black Front Grille + Custom Gloss Black Fog Grilles + RS6 Pedals + RS5 Dead Pedal + RS6 Shift Knob + Gloss Black Vinyl'd Front Splitter + Gloss Black Vinyl'd Roof + 35% Tint + DavidB8 Tail Light Mod + LED License Plate & Interior Bulbs
    May 27 2016
    Maine
    Thanks. It was the setting in the MMI. I had to set trunk locking to off in central locking. That does seem backwards.
    Tim R.
    Injen intake
    Established Member Two Rings gstrouse's Avatar
    May 13 2007
    2012 VW Tiguan SEL 2015 F-150
    Northampton, PA
    Thanks all. I have the same issue with my 2014 PPlus. I'll check it out .
