The OEM design seems to use those little 'spring finger' on the CV shaft to go inside the output flange to center the shaft.
The aftermarket version does not seem to have a 'centering aid'. There is a machine step at the shaft flange, but it is smaller (quite some play) than the output shaft flange step.
If not centered properly, would that not cause vibrations?
http://i1273.photobucket.com/albums/...psuoweaq2d.jpg
