Results 1 to 22 of 22
    Jul 22 2016
    '05 Subie LGT 5MT lmtd wgn, '02 A4 1.8Tq auto, 2 MGBs, '08 Acadia
    Suction jet pump brands
    I just replaced the suction jet pump in my '02 1.8T with the cheapest one on ECS, the MTC for $10. That was a bust, arrived with a leak. Trying to figure out whether to spend the $47 for the OEM or pick one of the in-between ones. Brief googling indicates URO is the OEM supplier for this part, but that seems unlikely given the $11 price tag. Anyone had experience choosing the cheapest SJP that will last a while? Thanks!
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    Delete that beeyatch all together. Its worthless.
    Audi Club Bay Area
    Veteran Member Four Rings B5nDisciple's Avatar
    Aug 23 2014
    2006 Honda Odyssey--Cannondale Caad 12--Giant Talon
    Tucson
    Quote Originally Posted by Furly View Post
    Not sure if it's worthless. Metalman (has a B5 and a B6 1.8T) found out that If you have to brake hard after immediately coming off WOT, vacuum doesn't build fast enough without the SJP for the brakes to work properly. It takes a bit (a second or two if I remember correctly) for the vacuum to build without it. Metalman and others have switched back to using it because of that issue. When it comes to braking I'm not willing to give up any time at all, which is why I am still running it.
    But for the OP's question I would definitely go with OEM for a part that helps provide safety with regard to braking.
    Sent from my VS990 using Tapatalk
    Then Jesus said, “Come to me, all of you who are weary and carry heavy burdens, and I will give you rest." Matthew 11:28
    Jul 22 2016
    Quote Originally Posted by B5nDisciple View Post
    If you have to brake hard after immediately coming off WOT, vacuum doesn't build fast enough without the SJP for the brakes to work properly. It takes a bit (a second or two of I remember correctly) for the vacuum to build without it. Metalman and others have switched back to using it because of that issue. When it comes to braking I'm not willing to give up any time at all, which is why I am still running it.
    And that explains why I was throwing brake booster codes prior to replacing the SJP.
    This is my wife's commuter car, and my 3 kids sit in the back. Your advice is valuable, appreciated, and... followed.
    Dec 30 2014
    Nogaro 2000 S4 6-Speed, Ebony Pearl 2002 A4 5-Speed
    South Carolina
    Not sure if it's worthless. Metalman (has a B5 and a B6 1.8T) found out that If you have to brake hard after immediately coming off WOT, vacuum doesn't build fast enough without the SJP for the brakes to work properly. It takes a bit (a second or two of I remember correctly) for the vacuum to build without it. Metalman and others have switched back to using it because of that issue. When it comes to braking I'm not willing to give up any time at all, which is why I am still running it.
    I deleted mine for I had no choice when going big turbo. My booster runs ton manifold vacuum with a check valve, works flawlessly and no change to braking under any conditions.
    Apr 15 2014
    Ottawa/Gatineau Canada
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    Quote Originally Posted by KHARDa4 View Post
    What check valve did you use? The one in the B5 line?
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
    Veteran Member Three Rings 5ktq's Avatar
    Aug 15 2016
    Western Canada
    I don't think URO is the OEM supplier for anything. Seems to be chinese parts distributor house AFAICT.
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    SJP is actually a very well designed feature. simple in functionality, but very well thought out. i honestly commend VAG for designing it. as much as it adds quite a bit of hosing work, i'd vote to keep it unless you plan to install a standalone vacuum booster canister/pump. turbo cars on boost normally will not be able to supply vacuum to the brake booster for normal operation.
    Aug 23 2014
    Tucson
    Quote Originally Posted by BARRY View Post
    I concur. Thanks for elaborating.
    Quote Originally Posted by relative4 View Post
    Oh definitely.
    You're very welcome, my pleasure. When it comes to something regarding safety I find it impossible not to chime in. I have three little wee ones so I know your persoective. Glad I could help. :)
    Jul 22 2016
    Note that this car already has a vacuum pump for the brake booster. And in certain conditions it doesn't kick on soon enough to meet immediate needs. The SJP fills that gap.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Normally for a part like this I would go with OEM. Unfortunately I have blown up two OEM SJP’s. So the last time I replaced it I went with this one that has a screwed on cap rather than a glued on cap. That was about four years ago and still working fine.
    Clicky click®
    Aug 23 2014
    Tucson
    Clicky click®
    Oh nice Old Guy! That's a great option. I really like the screw on cap.
    Nov 02 2007
    SF Bay Area, CA
    didn't know there was a screw on cap version! Thanks Old Guy. my avant's glued version separated from the seam, this would solve that!
    Jun 27 2011
    Clicky click®
    Thats the latest revision one. I ran that in my b6 for 3+ years without a single issue. Those updated ones have the glued and screwed cap. Pretty much can't leak unless it physically cracks off.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Clicky click®
    I'm fairly confident the Genuine ones look like this now... or at least the one on my B5 (AWM engine code) which is Genuine that I bought 1.5 years ago does.
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
    Dec 28 2006
    Western Maryland
    That is true for any automatic Audi. The manual transmission models do not come with a vacuum assist pump.
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by MetalMan View Post
    Glad to hear that Audi finally saw the light and made an improvement on it.
    Dec 30 2014
    South Carolina
    Quote Originally Posted by PreciseD View Post
    I used the boomba racing 1/2 inch or 12mm check valve.
    http://www.boombaracing.com/check-valve-12-mm-1-2/
    Feb 05 2014
    That looks like a good option but I might try the B5 line first.
    Oct 23 2010
    2004 Atlas Gray A4 Avant
    Cranberry TWP, PA
    Yeah, latest OE revision has the screw on cap. The friction welded old style cap blew apart on mine after about 2k worth of stage1 miles.
    2004 Atlas Gray B6 Avant, built 2.7T w/ BB K24's on E85
    2005 Touareg 4.2 gas guzzling daily
    2002 Triumph Daytona 955i
    1997 BMW M3 Coupe (sold, sad reacts only)
    Jun 27 2011
    It's just the latest revision. Often times the aftermarket designs are older revisions.
    I bought mine way back in 2011 or something and it was this screw on cap version. I had to get the OEM one as all the aftermarket ones ECS stocked at the time were the shitty old design.
    -CP
    2017 Q7 3.0t
