Results 1 to 40 of 208
    Jan 09 2008
    Winnipeg
    Quote Originally Posted by eurotic View Post
    For those that have the B12 kit installed but do not have adjustable control arms, what were your alignment specs after the B12 install? If you know what you were before the B12 install that would be awesome to know too.
    My car stock has about -1.2 degrees of camber and I want to get more. I know lowering will increase it but it would be great to know by how much as it might be enough to not also have to do adjustable control arms.
    Yeah, I'm quoting myself in hopes that someone can chime in about before and after alignment specs.
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Somewhere in the -1.6 to -1.7 range on the front. The rear is obviously adjustable to whatever you want. I personally think it's fine without adjustable control arms, but anything lower I'd probably add them.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Jan 09 2008
    Winnipeg
    Quote Originally Posted by jran76 View Post
    Thanks. I'm actually looking to get in the -2.5 to -3 range actually for an autocross friendly setup.
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Adjustable control arms would be the only way to get there unless you are slammed. Getting up to -2.5 degrees would be ideal for an autocross or track setup; just probably not so much for the street. The SPC arms will give you something like +/- 1.5 degrees from your static position.
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    I lost my alignment sheet, but camber was to the max negative factory spec IIRC.
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
