Page 1 of 5 123 ... LastLast
Results 1 to 40 of 208
    Jan 09 2008
    Winnipeg
    Bilstein B12 Pro-kit, is it a valid performance upgrade over stock?
    I have been thinking about doing an upgrade to my S4 (2012, 6MT, sports diff) in the suspension department with a focus on improving on what the car is in stock form. The S4 is my daily driver, I autocross frequently and have hopes of doing hot laps if I can ever get up to the track.
    I know that coilovers are the best option however I'm just trying to watch all the dollars I spend and I suspect with all the adjustability of coilovers that I might just ruin everything. I also suspect that I will just set it to something that I think is good and never touch it again. As such I am looking at the Bilstein B12 Pro-kit along with anti-sway bars (H&R), adjustable control arms (034) and x-brace (034).
    I have heard unhappy stories of people upgrading to lowering springs on stock shocks and getting a bouncey ride which is something I want to avoid, hence the kit that has upgraded shocks and springs.
    So the question is, from a performance standpoint, is the Bilstein B12 Pro-Kit a decent upgrade compared to stock? For those that autocross or track your car, would you upgrade to this kit or just run stock suspension if those were your only 2 choices?
    Shawn
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    Defintely an upgrade over stock. But I think sway bars, the AK and the CR15 are better bang for your $$$
    Dec 21 2013
    Quote Originally Posted by GRUMPY-S4 View Post
    What is AK?
    Current: 2021 R8, 2019 A6, 2017 Ghibli SQ4
    Past: 2009 C300, 2011 C63, 2013 535i, 2014 S4, 2016 M4, 2016 Macan, 2017 Macan Turbo, 2017 E350, 2017 750i, 2018 Panamera Turbo
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    Quote Originally Posted by snowmuch View Post
    What is AK?
    Eurocode Alu Kruez
    Or a Russian rifle if you are interested :D
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Apr 04 2012
    MSP
    Yes - big improvement.
    I'd suggest at least doing the rear sway and AK as well.
    I went with HR OE springs and Bilstein B8 shocks.
    Veteran Member Four Rings 14S4GWM's Avatar
    Mar 21 2015
    Quote Originally Posted by MrFunk View Post
    Im getting those installed in 2 weeks, how do you like them and is there anything else I should get for the install?
    Veteran Member Three Rings kobrian85's Avatar
    Oct 23 2012
    Quote Originally Posted by 14S4GWM View Post
    How many miles on the car? Might consider getting new perches for the front and spring pads for the rear, maybe if you're over 30k miles...? Otherwise, in my limited experience, you should be good - I've only upgraded the suspension on one previous car, and it was done at like 800 miles, so I didn't have to worry about components being worn at all.
    2019 RS5 \ Sonoma Green
    IG: kobrian85
    Apr 04 2012
    MSP
    Nothing unless you have some worn bits you want to address while at the shop.
    I think it's a perfect set up for a Daily modded S4 which will never need height adjustment. It is stiffer than stock obviously but in a good way IMO.
    Mar 21 2015
    Quote Originally Posted by kobrian85 View Post
    Im at 16k miles right now
    I bought these as they were recommended by another member.
    https://store.034motorsport.com/stru...s5-rs5-q5.html
    Jan 09 2008
    Winnipeg
    Thanks for the confirmation guys. Any reason to think the Eibach springs would be inferior to the H&R OE? I haven't been able to find anything that can tell me spring rates.
    For sure sways and subframe brace (although I like the 034 x-brace more than the AK, po-tay-toe po-tah-toe I figure) will be going in too. Plus transmission mount, ECS drivetrain inserts, maybe a short shifter, maybe new wheels with RE-71R's, ... ugh need more disposable income!
    Senior Member Two Rings Caymanite's Avatar
    May 04 2016
    Jupiter, Florida
    I just had the B12 kit installed on Saturday and it's definitely stiffer than stock, which I like, and less body roll.
    I considered doing the H&R springs but ECS had the B12 kit for $630 shipped so I couldn't say no.
    I do have a metallic clunking sound up front but I am assuming this may be an installer issue so I am going to give them a ring.
    I am also waiting for the springs to settle before I measure the drop
    Jan 09 2014
    2012 a4, 2015 s4
    TX
    Quote Originally Posted by Caymanite View Post
    Have you had that clunking sound fixed yet? What was the prob and what was the fix?
    Thanks,
    Have the kit in the shopping cart and want to know about possible problems.
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    I absolutely love my b12 kit, I've always been a fan of Eibach and progressive springs for all my cars.
    Flat in the turns and good for a daily driver with little bounce. Fender to ground height settles a 26" for front and rear.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Jan 09 2008
    Winnipeg
    Quote Originally Posted by fitzydude View Post
    So bouncier than stock? Or maybe put a different way, bouncier that coilovers would be? I'm fine with a firm ride (I prefer it to floaty) but I just don't want to be like so many imports I see that get unsettled because they are overly stiff and hop around on uneven roads.
    Jul 05 2014
    Houston
    Quote Originally Posted by eurotic View Post
    I think should have said the ride is a little firmer than stock and all the floatiness is gone!
    I've always had issues with coil over setups be it poor ride quaility, adjustment issues, or premature wear on stock suspension bits. That's why I prefer a good strut and spring setup.
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Totally agree with all of this and I also have the B12 kit. I previously had H&R OE springs and Koni Yellow dampers and the ride was horrible. Way too stiff/bouncy for a daily driver.
    The B12 kit rides fantastic and eliminates all of the factory "float". It also drops the car nicely and eliminates much of the stock body roll. This is without aftermarket sway bars.
    The price is a steal and leaves plenty of mod cash left over for sways and chassis brace if you want to go that route.
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Oct 23 2012
    Quote Originally Posted by Vogz View Post
    Don't Yellow's have adjustable dampers? I had Koni Coilovers with Yellows, and I had them turned one-full-turn firm from factory settings and never felt like it was terrible for daily driving. Maybe it's different when paired with the H&R OE Springs?
    IG: kobrian85
    Oct 08 2015
    Is there any spring&shock kit/coilovers gives our car a more comfortable ride? Roads around my area is so bad that even stock suspension rides too harsh for me.
    Current: '18 M3 ZCP
    Nov 28 2015
    Montreal, QC
    save that 400 of the AK and get yourself suspension or sway bar. I barely felt any different with AK.. I bet most feel a difference because its the first thing they add to the car, but if you do coilover first and the CR-15 brace.. the AK offer a minimal difference IMO.
    Jul 26 2015
    MT
    With the B12 Pro Kit would you not need get one of those camber adjustment kits as well since you are lowering the car? Sorry for what easily could be a dumb question.
    ~2013 S4 - Moonlight Blue~
    Oct 23 2012
    Quote Originally Posted by Donkey Hotay View Post
    Not necessary, you're not going low enough to create aggressive camber, and thus chew through tires.
    IG: kobrian85
    Jan 09 2008
    Winnipeg
    Thanks everyone, this is exactly the information I was looking for and exactly what I was hoping to hear.
    Oct 31 2013
    Morris County, NJ
    I have the H&R OE with bilsteins. Love it!!! It's a bit firmer than stock but still comfortable. Drop is perfect for me. Looks and performs great.
    2011 S4 P+ 6mt | AWE Touring | Roc Euro | H&R OE/Bilstein/034 RSB | APR Stage 2 DP + CPS | TSW Bathurst 19X9.5 | Michelin PSS 255/35/19
    Mar 21 2015
    Whats the difference between the 12 and 8 kit from Bilsteins?
    May 04 2016
    Jupiter, Florida
    B12 kit contains the B8 shocks/struts and Eibach springs and the B8 kit is just the shocks/struts without any springs
    Jan 09 2008
    Winnipeg
    And go figure, the B12 kit is cheaper than the B8 shocks by themselves.
    Senior Member Three Rings Symko's Avatar
    Jun 10 2011
    ‘12 Glacier S4 ‘19 SQ5 (wife’s)
    Reston, VA
    Can you still utilize the magnetic ride with this kit? How does this kit compare to the KW H.A.S. Or is this not the same type of setup?
    Thanks, Dave
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by Symko View Post
    Thanks, Dave
    No, this is dampers AND springs, so magnetic ride would be eliminated.
    Oct 11 2012
    San Martin CA
    Just for comparison purposes, how does the b12 kit feel compared to ST coils which give the benefit of height adjustability?
    2014 S4 DSG, APR stage 2, APR DSG tune, 034 Intake, real dipstick.
    Jan 24 2014
    United States
    very happy with my b12 kit. best bang for the buck imo
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Very happy with the Bilstein B8/H&R OE combo. I'd have no issue also recommending the B12 kit if it fits the bill (been in Fitzydude's car with this setup). I think either is a good option for someone that does not need the adjustability of coilovers. Either way, it blows away springs on the stock shocks or any lower-end coilover setup....
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Oct 29 2015
    Los Angeles, CA
    B12 is totally worth it! It rides way better than stock. First thing i noticed, brake dive was almost eliminated compared to stock and it soaked up bumps like nobody's business. Firm, sporty yet comfortable. Very good for everyday driving.
    Oct 08 2015
    Quote Originally Posted by LA_S4 View Post
    How does it compare to stock on bad/bumpy roads? Stock suspension is very uncomfortable on a very bad road near my house.
    Current: '18 M3 ZCP
    Oct 29 2015
    Los Angeles, CA
    Quote Originally Posted by yjypm View Post
    Not bad at all for me on LA roads. It actually feels more comfortable than stock. Less bounciness.
    Senior Member Two Rings lowjonathan's Avatar
    Jun 30 2015
    Just to check B12 versus our stock electronic suspension in dynamic mode
    i find electronic suspension with H&R super sport spring are kinda too firm for the uneven roads.
    in comfort mode, it was just kinda of floaty
    how does this B12 fare in term better ride? absorb the bumps better?
    I thinking to ditch away my elect suspension for B12
    Has anyone ditch anyway their electric suspension for B12?
    Volk racing G25
    KW v3
    Hotchkis ARB
    034 adjustable upp arms
    034 tranmission inserts & mount
    Uprated front bushing.
    CTS intake kit
    CTS SC pulley
    KI 184mm crank
    Custom tuned with DSG remap
    May 04 2016
    Jupiter, Florida
    It is definitely more bumpy than the stock suspension so if you have bad roads you will feel the bumps more.
    2015 S4 DSG
    B12 Kit
    Oct 31 2013
    Morris County, NJ
    +1. On bad roads you really need to do a good job at dodging the potholes.
    Jan 24 2014
    United States
    id say the b12 shocks are firm, but smooth
    Jan 09 2008
    Winnipeg
    For those that have the B12 kit installed but do not have adjustable control arms, what were your alignment specs after the B12 install? If you know what you were before the B12 install that would be awesome to know too.
    My car stock has about -1.2 degrees of camber and I want to get more. I know lowering will increase it but it would be great to know by how much as it might be enough to not also have to do adjustable control arms.
    Jan 09 2008
    Winnipeg
    Yeah, I'm quoting myself in hopes that someone can chime in about before and after alignment specs.
