Results 1 to 40 of 47
Hybrid View
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    Does cone filter size affect flow characteristics?
    Heyyoh B5S4 Gurus,
    For those running non-oem intake box setups, have you guys noticed a difference in fuel trim readings based on a filter size change? I've been chasing maxed out MAF readings after 7k miles of my rebuild / reseal of my vehicle. I've exhausted every option aside from replacing the intake tract which has remained the same. I have my doubts that an intake tract can be causing these issues, but I haven't ruled that one out. There is no flow straightener in place, but I feel like the MAF is located a decent amount away from the end of the tube.
    Since my knowledge on fluid flow is quite limited I hope there are some of you guys here that are experienced and can chime in. Will the larger filter size induce more turbulent flow in the intake tract? the MAF sensor location itself has physically not changed between the two setups.
    I had limited knowledge before I started the tear down, so I cannot comment on how the fuel trims were before the work was done. I can however confirm that the current base file flashed to the ECU is scaled (MLHFM tables) appropriately for the MAF on the car.
    Any input / personal experience with this? Should I source an OEM intake setup and plop a 85mm MAF housing in place? Would like to not keep blindly tossing $ at things if possible.
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Short answer. Yes it can.
    MAF's are very sensitive to intake changes. So more or less flow, or more likely issues with airflow created by filters, obstructions, change of locations, etc, etc.
    Jul 01 2014
    'murca
    Quote Originally Posted by NOTORIOUS VR View Post
    I wish the tune was the same as the previous setup so I could know for sure. I guess I can put the old air filter on it and see what happens. Thanks for your input!
    Veteran Member Four Rings wbrunner23's Avatar
    Jun 07 2012
    1955 Johnson QD-16
    KSQ, PA
    Consider adding a flow straightener - I ordered mine from SaxonPC
    http://www.saxonpc.com/100mm-cells-for-100.html
    Jul 01 2014
    'murca
    Quote Originally Posted by wbrunner23 View Post
    Thanks for the link!
    Do you have any better photos of how it attaches to existing piping?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    I've never understood why hot air intakes are so popular
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Jul 01 2014
    'murca
    Quote Originally Posted by redline380 View Post
    me neither. car came with no factory airbox, just trying to make do with what I got -.-
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by erykv1 View Post
    That is highly unfortunate. I'd keep an eye out for a used box. Actually, it just so happens the stock airbox is on limited quantity sale right now on ECS for $267. Definitely a thought. https://www.ecstuning.com/Audi-B5_S4--2.7T/ES2662108/
    With that said, the general consensus is that a 6 inch straight section after the filter and before the MAF will clear things up, so yours appears to be OK. But that straightener listed above certainly won't hurt anything.
    2000 S4- Working?
    Veteran Member Three Rings Audi9's Avatar
    Jul 20 2014
    B5 S4, 8V A3, 8V.5 RS3
    San Antonio, TX
    I've watched them change trims on other platforms. Couldn't tell you about this one unfortunately but VR said it can so I'd go with that.
    If you wanted to verify it try turning the filter/tube and then log it. I've seen just having the filter at a certain angle screw with trims as well
    Jan 29 2009
    Quote Originally Posted by Audi9 View Post
    The issue isn't so much as the air flow/volume change, but rather how the air flow is acting in the pipe... different filters, different pipe lengths, etc will change the airs direction especially at low speeds/idle that air will be bouncing around...
    There are maps in the ECU to correct for this situation.. but if you change something in front of (and to a point even after) the MAF all bets are off.
    Aug 30 2007
    nyc
    whats your maf size and boost at in psi?
    c5 A6 tip
    this n that
    Jun 07 2012
    1955 Johnson QD-16
    KSQ, PA
    I just wedged it inbetween the maf housing and the 4" aluminum tubing to the air filter.
    I also built a fiberglass heatshield and sealed it to the hood.
    Jul 01 2014
    'murca
    Whats weird is, at idle, the MAF readings are fine... but once I start building boost it goes crazy. MAF voltage is maxed out at 17-18 psi... symptoms of a much smaller intake tract / MAF diameter, yet everything is correct in the file. Its like chasing a ghost.
    Quote Originally Posted by dannyn424 View Post
    89mm, cant accurately tell you boost as I've been babying this for months until I can solve this issue.
    Thanks for the input I'll definitely keep it in mind!
    Jan 29 2009
    No intake leaks?
    Post a set of full logs with ME7Logger
    Jul 01 2014
    'murca
    no intake leaks. pressure tested a million times, replaced all the green check valves to rule out any internal leaks, checked with new dv's. new n75, new n249. wastegate lines checked out, cracking pressure checked out. you name it, i've checked it...
    everything aside from replacing the intake tract.
    here is a log: https://drive.google.com/open?id=0B6...kFEdzB4QnM4SlE
    Jan 29 2009
    You have a boost leak. It's the only reasonable explanation, not sure how you are pressure testing, but whatever you're doing isn't working. It's either that or your MAF sensor is bad.
    1. You're in limp mode - WGDC is fixed @ 10% because you're not meeting requested
    2. You boost builds, then drops, holds than creeps to 18 psi by redline. Your MAF is obviously seeing the air being pulled in and accounting for it which will prove the boost leak in point 3.
    3. You're running stupid rich - all signs point to a major boost leak, your MAF is metering for the air being consumed by the turbos but your motor isn't getting any of this air. You're running rich EVERYWHERE especially under boost.
    Jan 29 2009
    Very odd...
    Did you change the MAP sensor? Do you have a boost gauge? Does it correspond with what the ECU is seeing in terms of boost?
    Jul 01 2014
    'murca
    Very odd...
    Yes, I'm running a 3 bar map as requested by the tuner. The boost gauge does correlate to the logs.
    The only other thing I can think of is to test the resistance that go from the ecu side of the harness to the MAF plug to see if they're good. Never been stumped for so long by any car I've owned. I've also had a few Audi / Mercedes tech's look it over and they have no clue. I even went as far as to getting another ecu to see if it would fix it lol.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Is your MAF size properly scaled to the tune on the car? That is a plausible explanation.
    2000 S4- Working?
    Jul 01 2014
    'murca
    When it comes to the tune itself, I have verified (and some other members have also looked at):
    -Appropriate MAF scaling per housing diameter
    -Correct KRKTE / TVUB values for the injectors
    -MLOF is set to zero as per Hitachi MAF
    -Correct definitions file was used
    The only concern I have is that ps_w is over pvdk_w which indicates an overscaled MAF (possibly?)
    Unless theres something grossly simple I'm overlooking, I've been stumped by this for the last 6k miles lol.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    This is all Greek to me since I am a hardware guy, not a software guy. Others can help you out with that but I would verify the tune you are running and check with tuner about appropriate MAF sensor to use, as well as housing diameter
    2000 S4- Working?
    Veteran Member Four Rings phila_dot's Avatar
    May 26 2010
    2001 S4, 2019 Q5
    Philadelphia
    This leak would have to be massive.
    ps_w exceeds pvdk_w at 10% wgdc?
    Any reason you can't swap stock intake/MAF and injectors in and see how it reacts on stock software?
    WTB (1) OEM A8 Flat Five 18x8.5 et45
    WTB Black 6spd Shift Surround
    May 26 2010
    2001 S4, 2019 Q5
    Philadelphia
    I bet they screwed up the 5120
    Jul 01 2014
    'murca
    Quote Originally Posted by phila_dot View Post
    Aside from the fact that I would have to source those, theres no reason why I cant. The car just never came with the stock airbox setup :(
    Any way to check on this? Or some brief instructions?
    Jan 29 2009
    It looks like that could be a Daz base tune - going by the req. AFR curve.
    That said, did you buy the car like this (tune/fueling/map)?
    Jul 01 2014
    'murca
    You are correct on the Daz base tune. But I never got a chance to get revisions unfortunately as I spent months chasing a boost leak I don't have... Been in touch with Blake but due to this weird trim issue I've never gotten a chance to finalize on it. Just been dailying/babying the car with the MAF unplugged.
    I did not buy the car like this. I purchased the car and had to do a ton of work. Was half ass stage 3'd when I got it.
    Jan 29 2009
    Interesting... I'm not sure DAZ's file would have issues with 5120 mod (in English that means the mod that allows us to use larger MAP sensors).
    But there is certainly a big issue somewhere. I find it odd that you're seeing almost 4.7V on the MAF at barely 5600 RPM and 18 psi boost on what I'm guessing are PJK04 turbos? Just doesn't add up.
    Any chance you can borrow a true 85mm MAF housing to test with?
    Jul 01 2014
    'murca
    Daz was no stranger to the srm k24 rs6s which is what I'm running. I can try an epl housing from my buddy but those housings taper to 78mm I believe.
    Sent from my LGLS990 using Tapatalk
    Jan 29 2009
    I agree he wasn't, but something is flat out wrong here and I still believe it's hardware and not software at this point.
    I wouldn't use a housing like that... it would have to be a straight 85mm housing (like 034, etc) to match the SRM 85mm...
    Just as a comparison, here is a log from a car I tuned on 85mm Hitachi, SRM K24 @ 23-24 ps (conservative spool).
    notice that the MAF volts are only slightly higher than your car at 5600 (0.15V maybe) but you're running ~18psi there instead. Volt's are volts... it's not scaled so I still maintain something else is going on here. It looks like the turbos are drawing in the air, it's just not making it to your intake manifold.
    Jul 01 2014
    'murca
    The intake currently on the car looks like this... something solomotorsports put together using an 034 hitachi bung (before they started making their own). There is a weld bead before the sensor but I'm not sure it can be inducing enough turbulence to cause my issues.
    At first look, it seems like theres sufficient distance before the sensor, but I guess the only way I can be sure is to switch out the entire intake tract and see.
    The car will hold 15psi during pressure test for a good 10-15 seconds before slowly bleeding down... I've checked literally every connection with a spray bottle and the only thing I found was a tiny tear in an injector o-ring which I have replaced. The last thing I did was replace the intake manifold gaskets and the o-rings on the spider hose quick connects for good measure... but the symptoms never went away.
    I'm at a point where I feel like dropping it off at a shop but theres not really one I trust where I live lol.
    Aug 30 2007
    nyc
    check your tbb clamp the tbb may be lifting up at a higher boost level.... try ptesting to 20 psi....
    c5 A6 tip
    this n that
    Jul 01 2014
    'murca
    I have an APR bi-pipe, but I can try high pressures for the pressure test.
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    My vote is hardware as well. You said your tune is set up for 88mm Maf but your using an 85mm Maf? Or did I miss read that? I'm running an 85mm Maf at 26psi on k24s and my voltage at redline is around what yours is.
    Jan 29 2009
    I feel like the OP's post is (reading) deceiving as well... Can you confirm if your car was working fine or not before the filter change?
    You say you did the fueling, but then you say you have limited knowledge about anything before the tear down? Did you upgrade your tune/fueling, etc before the tear down? Did you do the tear down/rebuild due to these issues?
    Did you have these issues before the tune/fueling? What tune/fueling was on it before? I can see that the top pic is using a completely different MAP sensor, so I will assume the tune was different.
    As for the MAF tube, I was assuming it was an SRM unit, but it's not as you say. Maybe the placement of the MAF bung is too close to the bend after the MAF causing issues. Really I don't think that is a great placement for the sensor.
    You could try adding a 3-4 inches of straight pipe right after the MAF sensor to see if that helps (if you con't mind cutting up your intake/MAF pipe).
    Jul 01 2014
    'murca
    Let me try to make things a little more clear without typing out a book, my apologies for making it confusing.
    In short, the fueling...
    Before: 044 fuel pump, bosch green giants, hitachi MAF, solo tune
    Currently: 044 fuel pump, 630cc ev14's, hitachi MAF, 3 bar map, daz base tune
    For more specifics:
    Before After
    -Built level 10 auto
    -SRM K24 RS6 turbos
    -SRM bi-pipes
    -SRM 3-2.5" dp's
    -Hacked up RS4 inlets
    -Solo "custom" intake with a smaller filter
    -SOLO/J-fonz tune
    -Green giant injectors
    -Bosch 044 fuel pump
    -034 DVs
    -6 speed swapped the car with a rebuilt 01E with AA parts
    -Retained the same turbos
    -APR bi-pipe
    -3" DP's
    -SRM inlets
    -Solo "custom" intake with a larger filter
    -Daz Base Tune
    -EV14 630cc Injectors
    -Kept the same DV's
    I'll admit I jumped head into this platform without knowing much. The car honestly ran like shit when I got it but I never knew what a "proper" stage 3 car should have felt like, and had ton of things that were hacked together. All of this was my fault for not doing enough research before purchasing.
    I have since replaced / repaired / overhauled a ton of things to try to do this car justice. I know the car was not throwing any codes when I had it, but the hardware / tune left much to be desired.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    So you swapped tunes and not MAF's? Does Daz use the same MAF's as JFonz?
    2000 S4- Working?
    Jul 01 2014
    'murca
    Yes, I had to change tunes due to the changes in hardware.
    Both tunes use a hitachi MAF, I know it is currently scaled correctly. Cant comment on how it was before as I mentioned before.
    Jan 29 2009
    Sorry, but how do you know it's scaled correctly? Just because they are both Hitachi tunes, doesn't mean much.
    Jul 01 2014
    'murca
    I've compared it to other MLHFM tables for known tunes with the same diameter MAFs in tunerpro. I've measured the ID of the MAF housing with a pair of calipers to be sure. In case I missed something due to inexperience, I've had a few other people check the .bin... Blake, Monty, Mark @ EPL, I even questioned DAZ before his passing and he made sure it was correct.
    I'm at a point where I feel like I'm coming across as ignorant, but I've honestly checked / exhausted almost every option.
    Oct 27 2011
    TOYS
    Philly Suburbs
    I've compared it to other MLHFM tables for known tunes with the same diameter MAFs. I've measured the ID of the MAF housing with a pair of calipers to be sure. In case I missed something due to inexperience, I've had a few other people check the .bin... Blake, Monty, Mark @ EPL, I even questioned DAZ before his passing and he made sure it was correct.
    Stock MLHFM * 1.486 for his 89mm maf housing.
    He also had some pretty bad boost creep above 5k rpm at 10%wgdc. Boost increased from 12 to 18psi from 5K to 5.6K where the pull ended.
    edit:
