Results 1 to 14 of 14
    Sep 20 2015
    Is it safe to run a 235/35/19 or 245/35/19
    Is it possible to run this size tire on 19x9.5 wheels? From research the 235/35/19 has a 91y load rating and 245/35/19 has a 93y load rating. Manufacturer states 96y I believe. Anybody ever run these sizes?
    Senior Member Two Rings Malv1's Avatar
    Nov 23 2012
    1995 Volvo 850 T-5 R
    Rochester Hills, MI
    I am currently running a 245/30/20 until I can get my 255/30/20's installed. I have had no issues at all. They are a little thinner but they are within spec of acceptable according to tire rack's site.
    - 2014 Glut S4 DSG. Stock
    - 2007 Imola RS4. Milltek catless, non resonated exhaust, APR tune, RS5 20" Rotors... SOLD
    Sep 20 2015
    Quote Originally Posted by Malv1 View Post
    Since you have 20's the load rating is greater. 245/30/20 is probably around 95y or up for load rating which is within spec.
    Dec 07 2009
    East Coast
    Definitely would not run 91 loading rating. That's just asking for trouble. Also why would try to downsize a tire and upsize wheel width at the same time? Most here go with wider meatier tires. You've got some room to play on that RS4 widebody....
    Forget the B8, keep the V8!
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    +1.
    And, why would you want to downsize from stock? Especially with the extra power you're making!
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by Mr.Wrong View Post
    This.
    I wouldn't run a 91 load rating with any B6/7 car unless I am the only thing in the car and probably not on public roads. There is no point in downsizing the tires onto wider wheels. Go smaller overall or go bigger. Kind of like go big or go home.
    Established Member Two Rings FaisalJ's Avatar
    May 19 2009
    London
    Keep in mind that your speedo will be wrong too with incorrect sized tyres. With a 235/35/19 instead of 255/35/19 it'll be off by 2.2%
    And your tyres will be pretty stretched...
    So, as others have asked......why would you do this?
    2007 RS4 B7 Avant
    Phantom Black | Black Optics | MRC Stage 2 | KW V3 coilovers | H&R ARBs | JC Weldfab Full Exhaust | GTechniq crystal serum coating | Alcantara/leather interior retrim | Privacy Glass all round | Pioneer Apple Carplay HU, JL amp and sub, Focal components | LEDs all round | Modified Xenons -Clear lens, 6000K bulbs, black internals |
    Jun 25 2009
    07 RS4, 91 BMW 318is
    SC
    Probably so he can slam the fuck out of it
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by komseh View Post
    Yep.
    Jun 25 2009
    SC
    OP, there's a much safer way to get the look you're going for: https://store.034motorsport.com/hell...ering-kit.html
    Sep 20 2015
    I have that kit already
    Sep 20 2015
    Yes. After some research I will stay within spec. I have some wheels that I'm tempted to fit but need a low profile tire to bring the sexy out.
    Senior Member Three Rings joe@dubaudi.com's Avatar
    Mar 21 2010
    B7 S4 Avant / 2014 Allroad / 2015 Q7 TDI
    Point Pleasant NJ
    yes you will be totally fine with those sizes. 235/35 on a 9.5 is a mild stretch. nothing crazy and you can still rip it through the twisties confidently.
    Run a little higher psi though like 42-44psi
    Sep 20 2015
    Quote Originally Posted by [email protected] View Post
    Not worried about the stretch. It's the load rating of the tire that's available that I was concerned about. So far I only found one other person run that size.
