Results 1 to 4 of 4
    Oct 29 2015
    Minneapolis MN
    Service Dash Message
    Recently I had the message pop up with the brake pad monitor light, and I have the pads, just need to get back to my dad's farm to do the work, but yesterday leaving work I had a new message stating mostly to the effect
    "Service Vehicle
    72 days or 900 miles"
    This morning, 71 days or 900 miles... Is this just a normal scheduled maintenance reminder?
    The car is an '07 with shy of 90k miles on it, I have had it for a little over 3 years beginning at 48k miles and have never gotten a message beside this, the brake monitor, or the occasional oil level.
    Thanks for looking
    -Tom
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Yes, it's nothing to worry about. There's a way to reset it, I forget how exactly.
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Oct 24 2015
    Perth, WA
    If you have a VCDS you can easily reset the service reminder message - take note of any low oil messages though, they can be catastrophic quite quickly. If you don't have a VCDS, then you can reset it by http://www.audizine.com/forum/showth...terval-Display
    My respray thread
    Oct 29 2015
    Minneapolis MN
    Thank you, I figured that was probably the case. It used to drink oil by about 4qts between changes but I had it in for misfiring at 75k miles and replaced the coils/plugs and had them fix the oil leak out of one of the piston heads at the same time, doesnt go through oil as quick anymore but I still keep a jug in the trunk just in case
    Still will probably get it in at some point since I am considering trading up in the next couple months. Thanks
