Results 1 to 19 of 19
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    DRL Color Modification
    I have been thinking about doing something different with my DRL's. I'm interested to know if anyone has ever considered modifying them before. What I would like to do is change them from white to blue. I have Sepang and think it would look good and be unique. As far as I know, there aren't many laws concerning the DRL's, and the only color not legally possible is red. How hard could it be? Has anyone researched this before? Thoughts?
    Veteran Member Four Rings tcm glx's Avatar
    So Cal
    Quote Originally Posted by SQive View Post
    There is a guy here in So Cal who I am pretty sure could do it, but would likely be extremely costly. Minimum 500 bucks I'm thinking. These Audi lights are sealed with PermaSeal which is the enemy when it comes to opening up headlights. Once open, then it's just a matter of working on the LED which isn't as big a concern.
    Look for a guy on IG Called El Stig. He is the guy who could pull it off.
    2013 Audi Q5 2.0T Premium Ibis White/Chesnut Brown
    2022 Audi Q8 3.0T Glacier White
    Sep 28 2010
    NW NC / DE
    @bknewtype
    Jan 07 2011
    2013 C300 4Matic
    180 customs in brooklyn may b able to help out. They have done lots of headlight mods for bmw's, infinitis, and even audis
    Sent from my iPhone 6s
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    thought we couldn't open our headlights? If I remember correctly @riceboy22 was turned down from 180 customs, otherwise we'd all have ecodes
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Apr 26 2014
    DFW
    Too bad, because I think this would look pretty damn cool on my ride:
    https://www.flickr.com/photos/oneigh...n/photostream/
    Veteran Member Four Rings riceboy22's Avatar
    Mar 26 2015
    2015 Audi SQ5, Felt F65x, Levy Electric Scooter
    New York, NY
    Quote Originally Posted by q5 dave View Post
    Yeah, they actually installed my ecodes and took a look at both sets of lights then. No bueno. They can be opened up, but it's a PITA and you risk breaking something in the process. It's too bad because they do some awesome work.
    Current
    2015 Audi SQ5 3.0 TFSI (Build Thread | Flickr | Instagram)
    Past
    2006 Lexus IS350 | 2001 Audi S4 | 2000 Honda S2000 | 1999 Yamaha YZF-R6 | 1995 Acura Integra GS-R
    So Cal
    They can be opened up, it just requires a lot of time and patience, that's all SQive, I know George at El Stig, if you'd like I can ping him and ask him for quote/thoughts.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Right, but that's just the surround that's painted and not the actual LED output (obviously)
    I think the above does look cool when done right... On the other hand, here is an RS5 that had color-changing LEDs installed. He could pick any RGB color via remote inside the cabin. Personally, I think it looks terribly tacky (never mind the rest of the car ) but to each his own.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Jul 10 2014
    Quote Originally Posted by riceboy22 View Post
    This ^... correct as usual!
    Jan 07 2011
    2013 C300 4Matic
    To be clear they cant open up pre fl headlights for the 5, but can do fl ( see above ).
    And i just noticed this was the q5 section haha
    They cant open valeos
    Present:
    IG: bknewtype
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    GTFO!
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Bye Felicia
    Veteran Member Three Rings HMS's Avatar
    Apr 28 2015
    BOS
    good god man, I've seen harlequin babies that look better than this.
    (If you don't know what that is, don't google it)
    Sent from the future.
    2013 Audi [R]S5 Panther Black - Mods: 034, Capristo, ECS, H&R.
    Instagram: RS5_onthe_Run
    Apr 26 2014
    DFW
    Oh, dear lord. . .you told me not to.
    I should have listened as it's one of those things you can't un-see.
    Veteran Member Four Rings BG SQ5's Avatar
    Feb 21 2016
    '07 CBR1000RR
    PA
    I don't know why I came across this (searching drl color for fog matching), so sorry to bring up an old thread. However, I don't see why this would be that hard. You don't have to open the headlights to access/change the drl source leds. I'm pretty sure it's just a module that you swap off the back any time you change headlights (ie. anyone that has installed ecodes moved the drl leds over). I know I've lit up the drl surround of my ecodes that sit in my room with a green led off a power adapter messing around before. All you have to do is pull the headlights to access the back of them, and this should be relatively easily. It might require soldering new leds into the module but certainly not opening up headlights.
    When I swap mine in a few weeks I'll try to remember to follow up with details once I put my eyes on the module myself.
    '15 SQ5 Daytona Gray
    APR stage 2 104 oct (e40) - BG TCU (via HPT) - CTS s/c & FD 187 crank - Autotech HPFP - aFe filter/034 tube/modified box - MercRacing h/x - AWE Touring
    21" Forgestar CF10s w/295s - KW Street Comforts - 034 mounts, RSB & end links - ecodes - deAuto LEDs - P3 w/ECA - VCDS
    11.340 @ 120.63 (673 DA) - street trim
    11.012 @ 124.22 (-1346 DA) - track trim
    Instagram: @bg.sq5
    May 19 2016
    Somerville/MA
    Bump
    Jul 31 2016
    PA
    There is a company called EMTuning in the UK that does a lot of lights including replacement of the LED driver. When I talked to them last, they were working on stuff for the Q5, not sure if it's done or not.
    As stated headlights don't have to he opened, but they can be if you want to do anything else to them. If you want, send them to lightwerkz they were much more helpful and communicative when I was doing my build then 180 was.
    Sent from my Pixel 3 using Tapatalk
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Apr 21 2011
    Central NY
    This is using yellow film in front of one LED
