Results 1 to 6 of 6
    Aug 10 2016
    Laval, QC, Canada
    Headlight problem
    Hi everyone, i have a headlight with a broken bracket and check to buy an another set and i want to know why every set of headlight go on a4 with halogen and not on a a4 with projector And can it fit on a a4 with projector
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Que?
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    Aug 10 2016
    Laval, QC, Canada
    Can i fit a headlight that supposed to replace a halogen headlight if i have a projector headlight on my car
    Veteran Member Four Rings pezgoon's Avatar
    Jul 25 2016
    new hampshire
    By projector I think you mean xenon or bi xenon right? If so no, you cannot fit halogens, the ecu was programmed and set up for xenons, supposedly you can only go up and not down, sorry man its super expensive for xenonxs
    BUT if you mean clip, by bracket? Audi sells repair kits that it can simply be fixed, if you mean an exterior clip, if its something wrong with the inside of the headlight you need a replacement
    And theres none for sale, because everyone's buying them to install them on their halogens lol
    Eric
    2005.5 6mt A4 2.0 94k miles
    2010 Q5 3.2L 6at 160k miles
    Aug 10 2016
    Laval, QC, Canada
    Sorry for my english but thank you for all those answer
    Jun 18 2015
    DavidhogAJ
    Philippines
    Quote Originally Posted by pezgoon View Post
    Can't you use VAG COM to change your headlights setting and avoid an error/make them work?
    Sent from my SM-G920P using Tapatalk
