2500 local pickup
Update thread from when I got it but I did stop updating the thread at some point:
http://www.audizine.com/forum/showth...-Please-look-D
Car specs:
VIN: WAULH54B1YN043319
2000 Audi A6 Avant Quattro/All Wheel Drive
2.8L Engine 210HP
3 keys, two with chip, 1 valet
92k miles, going up daily as it is my daily.
Oil changed at 88K miles with BMW 5W30 Synthetic Oil
Drive & Passenger power seats.
Front & Rear Heated Seats
HOT Heat and ICE COLD A/C.
Bose Premium sound system with steering wheel controls.
3rd Row kids rear facing seat capable.
Full Spare
Fog lights
Here is what I have done since purchased in August 2015, either upgraded or replaced:
Tint done all around 5% on all rear windows 25% on two front windows.
18" RS4 reps(7 double spoke), one is riding on 4 lugs, hole repaired and needs to be bored.
Like new all weather tires with about 6K miles on them.
Audi Allroad door blades installed
HID Lights installed
LED interior lights were installed
New Audi all weather mats
New Audi wind deflectors
New windshield was installed as the old original one had chips
New wiper blades
New Audi coolant reservoir
Air Filter replaced
Cabin Filter replaced
Spark Plugs replaced
Oil Changed every 3,500-5,000 miles since owned at 75K miles
New Rear rotors and brakes
New Front brakes and rotors
ALL timing belt components, water pump, tensioners, pulleys, serpentine belt were changed at 82,200 miles
Valve cover gaskets and cam gaskets/seals were all replaced when timing belt job was done however passenger side has a very slow leak.
SAI was deleted and combi valves removed, block off plates were installed
Transmission front diff fluid was changed at 84K miles
Transmission gasket, filter and oil replaced at 84K miles
Resonator was removed and new pipe installed.
The Bad: Which I am constantly working on when I get a chance.
Center LED pixles are dying, common issue (Pictured)
There is a small dent right above the driver side wheel well, pictured.
Check engine light is on but that's because the purge valve is not connected, not affecting anything.
There is a small leak from the half moon seal that is dripping on the exhaust and is more annoying than anything as it creates light smoke the first 10min of driving.
Thanks for looking.
