Results 1 to 20 of 20
    Established Member Two Rings torquewrench's Avatar
    Jan 26 2009
    WA
    Exhaust note changed, Loss of power, vibration under load, EPC light
    I'm hoping to get some help on an issue. Yesterday on the freeway after accelerating, the exhaust note changed to a much deeper tone. The exhaust sounds normal unless it's under any amount of acceleration and load. It also seemed as though the car was in a gear too high, but it wasn't.
    This morning, I accelerated hard and the EPC light came on immediately. Then it wouldn't shift gears automatically (I could shift manually) , and the car would shake violently when trying to slowly accelerate. After 3K RPM, it would somewhat smooth out.
    I don't have a VAG-com, but scanned with my generic scanner and it came back with cylinder 3 misfire. No big surprise. At this point, the idle was rough and the EPC light was on. I cleared the code as the car was running, and the idle smoothed out.
    Still feels like it's in 5th gear when going 25 mph.
    Does the EPC light cause the car to go into limp mode? If so, that would explain why I can clear the code and then continue to drive (with a weird exhaust note and low power under 3K)
    The exhaust note has me a bit baffled. Possibly a timing issue? I'm going to see if anyone local has a vag-com and/or will replace the coilpacks as as starting point.
    Anyone else experience something similar? Any help is appreciated.
    2012 S4 ,DSG
    Jul 15 2014
    You've got a clogged/failed cat.
    Jan 26 2009
    WA
    Quote Originally Posted by soltez View Post
    I appreciate the reply, however I would think the secondary O2 sensor would tell the ECU that something is wrong and I'd get a code.
    Veteran Member Three Rings brainpan's Avatar
    Apr 11 2010
    sk8 banana
    ontario
    Sounds like failed cats to me, my cats on bank 1 and 2 melted without any cat efficiency codes. Random misfires and EPC light under full throttle. I spent a long time chasing the problem and it seems like more and more people are running into this issue.
    I'm now running jhm cats and so far the car is running well again, exhaust note change is a definite sign of failing cats.
    Sent from my Note 5
    Bryan
    Jan 26 2009
    WA
    Great. It looks like everything is pointing to the cats. And from what I hear, it's a big job. ECS has some reasonably priced cats at 440 that are legal.
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Failed cat. I had both of mine fail. Same symptoms. No CEL
    Jan 26 2009
    WA
    Quote Originally Posted by CELison View Post
    Thank you for taking the time to let me know. Where did you buy your cats, and do you mind letting me know the cost to replace?
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by torquewrench View Post
    There's a 8yr/80k warranty on cats. I had mine replaced by a dealer. Just had to flash it back to stock and take all the bolt ons off. If it's not throwing a code they might give you a hard time. I went up the dps with a borescope and showed them the cat that had come apart.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Nov 16 2018
    San Clemente/CA
    Folks, I had the same issue on my Q5, wit the EPC and check engine lights coming on. The dealer tells me that I need to replace all 6 of my fuel injectors at a total cost of $2800. Dealer tell me that it is not the spark plugs nor its the ignition coil and so has got to be the injectors.
    Any suggestions?
    Veteran Member Four Rings Morritse's Avatar
    May 08 2018
    Stage 2 b8 a5 (sold)
    Berkeley, CA
    Quote Originally Posted by fvijay View Post
    Any suggestions?
    You have VCDS? Log primary and secondary O2 sensors as a graph on both banks and you can see if one of your cats is fucked up.
    Unless your dealer did testing, they are retarded to assume injectors. If you can, look at which cylinder is being disabled and see if it's always ones from bank 1 or 2.
    FBO B8. ~ 10.95@126 ~ 2.96s 0-60 ~ full weight street tires.
    Jan 26 2009
    WA
    Any suggestions?
    I caution you and your dealings with your dealer. I have found too many "mechanics" only know how to scan for codes, and blindly follow a diagnostic manual without taking a second to think.
    Let me tell you my experience with the dealer. Don't get in a situation like this:
    Since the car was techically under the 80K cat warranty, I brought my car to the dealer. I typically do all my own work, but hey I'll leave it to them if warranty was doing it. (my thought anyway)
    It was misfiring so bad it wasn't drivable, I had it towed. I gave them hints as to what the problem likely was, but naturally they went ahead and started from the top, charging me for a full diagnositic. I get why they do that. Then they started charging me for spark plugs (I just replaced them), coils (I just replaced them), then more diagnositics. I brought my car in with the exhaust off, so they thought it was lack of back pressure causing the misfire. LOL. I paid for them to install my exhaust, and same issue. They wanted to replace injectors and if that wasn't it, they wanted to start tearing into my head, thinking it was the valves. It had been a month at this point, and diagnostics/parts were over 1K. I asked them to do a backpressure test, they came back in 15 minutes saying they just did. Knowing they were lying, I went home and got my 1989 junker truck and loaded it with my tools. I was livid.
    I had them push the car out to the parking lot so I could 'take a look'. I tore the car apart right there while their 'mechcanics' took smoke breaks watching. I connected a gauge to the o2 sensors and the gauge was pegged. The cat was plugged on the side of the misfire. Just to verify, I removed the pressure gauge and let the exhaust pressure flow out the O2 sensor bung. The engine could breathe, and the car ran smooth.
    I'm not a confrontational person, and just wanted to solved the problem. I asked for the mechanic to come out - and he wouldn't. So much for working together on this one. The service manager finally came out and I showed him the pegged pressure gauge and how I could make the car idle perfectly when removed. He said "But there's no code showing that the cats are plugged". I lost my mind.
    I had another shop replace both cats as there is no way I would ever let them touch my vehicle. Its difficult, but spend the time finding someone that actually knows how IC engines work.
    Jul 26 2017
    Coquitlam BC
    One random question,
    is the 8yr/80km as long as you bought the car from Audi? I purchased it CPO and my CPO warranty is up in 2019 but if they were to fail in 2020, if it's under 8 years they would still warranty them? Is that correct?
    []S4 - EPL Stage 2 Single Pulley ECU/TCU 91 | Roc Euro | Custom MF Exhaust
    Veteran Member Four Rings Silver Streakin's Avatar
    Mar 05 2004
    B8 S4, 17 Expedition EL, 2009 328ix coupe
    NoVA
    Quote Originally Posted by alexbai94 View Post
    It's a federal law/warranty across all cars. 8yr/80k miles. Nothing to do with Audi.
    2011 S4, 6M, BB/panda, Sport diff, ADS, B&O | UniTronic stage 3 Dual Pulley | MercRacing HX | RocEuro intake | AWE Track & DPs resonated | H&R c/o w/Bilstein B8 rears| 19" VMR 710 & 19" Peelers | 034 trans insert | AK brace | CR15 bar | DEVAL CF Diffuser
    SOLD 2007 S4 DTM, Phantom Black Pearl, manual | JHM | FI | H&R | VMR | 034
    RIP 2001.5 A4 1.8TQMS, Silver/Ebony | APR stage 3 | STaSIS Tracksports | StopTechs
    SOLD 1995 90
    Dec 20 2016
    OC, CA
    Had this happen to me on the freeway today. Pulled over, shut car off and tuned back on. EPC light went away and the car's been running fine since. Are failed cats the only thing to cause this?
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by jak77 View Post
    These specific symptoms? Including the exhaust note change? 99% yes.
    Dec 20 2016
    OC, CA
    Quote Originally Posted by Morritse View Post
    Most of them. Cant say for sure the exhaust or not since I pulled over right away and restarted the car. If the cats are going, would it stop happening and then happen again? Or would it be continuous?
    Only mods on my car are bolt-ons (exhaust and intake). So far. Its a 2014 with 45k on the odometer.
    May 08 2018
    Berkeley, CA
    It's continuous. EPC will usually come on when you push the car a bit. You should scan the codes and post them here.
    Veteran Member Four Rings Audibellybutton's Avatar
    Jun 28 2019
    California
    Are my cats bad? I’ve been doing a lot of digging to try to fix my misfire EPC issue
    I recently had maintenance done, new injector o rings/seals, coolant crossover pipe and carbon cleaning etc
    A few days ago I flashed my e85 map back on and tried to have some fun with it. The car would misfire whenever you get over 3k rpm or give it some load. Epc light come on and it runs like shit vcds scan brought the code P0302 misfire on cylinder 2 only so I changed the plug and coil, didn’t work. Also did a. Compression test it was fine.
    Fearing it was e85 related I went back to 93 octane map and it seemed to run fine a little while and then the issue come back except now it’s p0305 misfire on cylinder 5 only
    I flashed the car back to stock and now i haven’t been able to recreate the issue. Flashed the tune again and it came back. Another symptom I have is the car backfired on deceleration but it didn’t before. When I run the stock map it doesn’t backfire at all. Could these be a symptom of bad cats? It’s weird how the issue jumped from cylinder 2 on bank 1 to cylinder 5 on bank 2 and it’s always only one cylinder. It throws epc light but not mil
    C7 Audi A7 Prestige 3.0t (RIP) - Dual Pulley E40 , Turtle TCU Tune, Ported Blower, Meth, Porsche 997 TB, Merc Racing Heat Exchanger, CWA-100, RKX Silicone Intake hose, RS7 Airbox, RS7 LPFP, JHM 207 pulley,SRM Driveshaft Upgrade, H&R Springs, 034 Drivetrain inserts, Vossen VFS2, RS7 Steering Wheel, Autotech HPFP
    C7 Audi S6 Prestige 4.0t (Current) - Custom E85 tune W/ FE STG2 Turbos, JHM TCU,Meth, Merc Racing HX, EMP Coolant Pump,GFB DV+,LPFP upgrade, ECS Inlets, TS Gates, Exhaust
    IG:@stolens6
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Quote Originally Posted by Audibellybutton View Post
    After I had new a carbon clean and injector o rings replaced I was having issues of loss of power. Ended up one of my injectors went bad, most likely from removing and cleaning them. I replaced just that one injector and solved issue. I am not sure if this is the case with your issue. But yes I would check the cats and anything fuel related. Clogged lpfp filter? I had to replace this in my car after running e85 for a while. Have you checked your plugs? They go bad a lot sooner when tuned. I change mine every 10k or so and gap them to .026"
    Sent from my Pixel 4 XL using Audizine mobile app
    Jun 28 2019
    California
    Quote Originally Posted by ModItNow View Post
    thanks. Just wanted to give an update in case any other forum lurkers run into this issue.
    Turned out to be spark plugs, I was in denial of this because I changed all of them recently, and then changed the ones in the cylinder that misfired again, but it was. I have a valve cover leak that seems to got oil on the plug and fouled them pretty quickly.so far the issue is gone.
    IG:@stolens6
