Page 2 of 2 FirstFirst 12
Results 41 to 79 of 79
  1. #41
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Quote Originally Posted by zuti View Post
    They tell me, it is not the same ports, and other on the old and new instrument cluster. If a dealer remove component protection, what else i must do to make cluster a work ? What is with coding ? he says in instrument must write vehicle ID number and other ?
    Make sure you buy correct color cluster for prefacelift B8:
    km, acc or not, diesel or petrol etc...you need to correct mileage(hackers will do this), dealer will not do this on used cluster, or find one close to your current mileage!
    More info here:
    http://www.audizine.com/forum/showth...r-dis-09-A4-B8
    Good luck!
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
  2. #42
    Junior Member One Ring
    Jul 19 2017
    Bosnia & Herzegovina
    One more question ? How to find instrument cluster number of my cluster, to find new one ? My Audi is 2011y, diesel, no acc ?
  3. #43
    Veteran Member Four Rings CONative's Avatar
    May 06 2015
    B8 A4 Avant / Subaru Outback Limited / Honda Odyssey
    IHave2Turbos - thank you putting this extremely helpful guide together. I have been contemplating doing this for some time and now I feel much more confident with pricing, part #'s and instructions all laid out. Time to begin sourcing parts!
    Cheers,
    Ry-man
  4. #44
    Jul 19 2017
    I was wondering if there's a way to find the id number of the instrument cluster without extraction from the car?
  5. #45
    Oct 21 2012
    Earth...
    You can see nr with vcds, but you dont need your old cluster number to find new one, just use prcodes and use online catalogue or find cluster number in ebay de... Take 2010+ cluster!
  6. #46
    Jul 19 2017
    I contacted an authorized audi store, and they told me I could remove a CP for about $ 35. When I embark on a new instrument cluster for myself, will I be able to start a car to go to them? And when they remove the protection, is it all? Why did others mention that a new instrument cluster should be coded, add additional data to it? In blocks 50 and 20?
  7. #47
    Jul 19 2017
  8. #48
    Jul 19 2017
    Done !! Al what you need is to remove CP from intrument cluster and if you want correct milage. No other coding needed. Replaced instrument cluster is from 2009y. I will tomoroow upload some pictures. Color DIS is awesome !!! My next retrofit will be MMI with NAVI update !!
    THANKS TO Gunnark100 !!!
  9. #49
  10. #50
    Oct 21 2012
    Earth...
    Regardingi Navi, make sure jump to 3G+(EU mainunit with sim 8R1035670)!
  11. #51
    May 11 2016
    CA
    I am working on MMI retrofit project and found this very detailed and fast video of Q5 retrofit.
    https://www.youtube.com/watch?v=2bFaSBHydSU..
  12. #52
    May 11 2016
    CA
    My project budget spend comparison..
    MMI Unit, Controls & Trim:
    7" LCD Trim: 8K1857186H/F eBay I Paid: $48 He Paid: $55 -->I paid $12
    7" LCD Screen: 8R0919604A eBay I Paid: $150 He Paid: $177 --> I paid $74
    MMI System (2010): 8T1035664B eBay I Paid: $112 He Paid: $134 --> I paid $99 (3G high 2015 unit with Sim)
    MMI Bracket: 8K0858969 eBay I Paid: $154 He Paid: $128 -> NA
    MMI Controls: 8T0919609F eBay I Paid: $120 He Paid: $177 --> I paid $34
    MMI ESP Switch: 8K1959673 eBay I Paid: FREE He Paid: $27 (came w/ MMI) -->I paid $20
    CAN Module:
    MOST CAN Gateway: 8T0907468AD eBay I Paid: $80 He Paid: $80 --> I paid $40
    GPS Antenna:
    FAKRA GPS Antenna: N/A eBay I Paid: $8 He Paid: $8 --> I paid $ 7
    GSM Cable: (Just in case I upgrade to MMI3G+ in the future, the Cell Phone cable will be run already)
    FAKRA D GSM Cable to Trunk: N/A eBay I Paid: $13 He Paid: $? --> I paid $8
    Kufatec Radio to MMI3G High Harness:
    Kufatec Harness: N/A Kufatec I Paid: $305 He Paid: $350 -->I paid $265
    Radio/Amp (WA1DGAFE7FDXXXXXX):
    Radio Trunk Bracket: 8T0907368A eBay I Paid: $24 He Paid: $66 --> NA
    Radio/Receiver Tuner: 4G0035082G eBay I Paid: $240 He Paid: $167 -->>$ 130 (2016 unit with HD sirius)
    Radio Protection Removal: N/A dealer I Paid: $144 He Paid: $? --> Still TBD
    AMI Cable
    MMI3G AMI Cable: N/A Ali Express I Paid: $63 He Paid: ? --> NA
    SAT Cable Extension to Trunk:
    15ft Fakra M-to-F SatRadio Ext: N/A eBay I Paid: $16 He Paid: $16 --> I Paid $ 9
  13. #53
    Veteran Member Four Rings Ford Prefect's Avatar
    Jan 20 2017
    RS7
    New Hampshire
    Quote Originally Posted by andybq5 View Post
    7" LCD Trim:8K1857186H/FeBayI Paid: $48He Paid: $55 -->I paid $12
    7" LCD Screen:8R0919604AeBayI Paid: $150He Paid: $177 --> I paid $74
    MMI System (2010):8T1035664BeBayI Paid: $112He Paid: $134 --> I paid $99 (3G high 2015 unit with Sim)
    MMI Bracket:8K0858969eBayI Paid: $154He Paid: $128 -> NA
    MMI Controls:8T0919609FeBayI Paid: $120He Paid: $177 --> I paid $34
    MMI ESP Switch:8K1959673eBayI Paid: FREEHe Paid: $27 (came w/ MMI) -->I paid $20
    CAN Module:
    MOST CAN Gateway:8T0907468ADeBayI Paid: $80He Paid: $80 --> I paid $40
    GPS Antenna:
    FAKRA GPS Antenna:N/AeBayI Paid: $8He Paid: $8 --> I paid $ 7
    FAKRA D GSM Cable to Trunk:N/AeBayI Paid: $13He Paid: $? --> I paid $8
    Kufatec Harness:N/AKufatecI Paid: $305He Paid: $350 -->I paid $265
    Radio Trunk Bracket:8T0907368AeBayI Paid: $24He Paid: $66 --> NA
    Radio/Receiver Tuner:4G0035082GeBayI Paid: $240He Paid: $167 -->>$ 130 (2016 unit with HD sirius)
    Radio Protection Removal:N/AdealerI Paid: $144He Paid: $? --> Still TBD
    AMI Cable
    MMI3G AMI Cable:N/AAli ExpressI Paid: $63He Paid: ? --> NA
    15ft Fakra M-to-F SatRadio Ext:N/AeBayI Paid: $16He Paid: $16 --> I Paid $ 9
    How's you get the Kufatec harness so cheap? Aren't there 3 needed for the swap?
  14. #54
    Veteran Member Three Rings IHave2Turbos's Avatar
    Aug 17 2015
    not sure i understand? the harness kit includes everything you need. the price on their site includes taxes which we don’t pay in the US
    C7.5 S6
    Mods : OEM+ Stage3 / DS1 ECU / SRM TCU / CTS HX
    B8 A4
    Mods : HPA\\\ K04 / Manifold / HFC / Tune | CTS FMIC / DP | CR-15 | ECS Inserts
    Retrofits: MMI3G+ / RVC / AHH / Color DIS / Cruise Stalks
  15. #55
    Aug 17 2015
    also as you can see the prices have continued to trend downwards as more and more of these parts get old and flood ebay.
    C7.5 S6
    B8 A4
  16. #56
    Aug 17 2015
    i’ll probably re-retrofit to mmi3g+ if i can scoop up controls and main unit on the cheap.
    C7.5 S6
    B8 A4
  17. #57
    Jan 20 2017
    RS7
    New Hampshire
    Quote Originally Posted by IHave2Turbos View Post
    This cable, which I believe is right, mentions you also need part numbers 36735 and 39411. The main harness is $299 euros so I'm guessing eBay was the source for the $265 price.
    https://www.kufatec.de/shop/en/audi/...g-harness-audi
  18. #58
    Aug 17 2015
    299 euro minus 19% VAT
    those additional harnesses would be for if you wanted to add or adapt factory AMI. I posted my link to AliExpress where I bought a factory one.
    Another optional harness is their dual microphone adapter but i didn’t buy that either.
    C7.5 S6
    B8 A4
  19. #59
    May 11 2016
    CA
    Quote Originally Posted by Ford Prefect View Post
    Well, no I haggled and had Kufatec price match to a similar cable on eBay.
  20. #60
    May 11 2016
    CA
    Go for it man.. there are many available for cheap on eBay and also chcek out https://www.partsmarket.com/ .
  21. #61
    Jan 20 2017
    RS7
    New Hampshire
    Ah! I misunderstood, -19%, very good.
  22. #62
    Aug 17 2015
    Murica!!!!!
    C7.5 S6
    B8 A4
  23. #63
    May 11 2016
    CA
    Here is another deal on MMI 3G bluetooth microphone.
    https://www.ebay.com/itm/Audi-A4L-A6...72.m2749.l2649
  24. #64
    May 11 2016
    CA
    Murica!!!!!
    When you swapped your DIS did it cause any mileage discrepancy?
  25. #65
    Aug 17 2015
    yes i bought one that luckily was only about 20 more than i had on the car. otherwise you need to get the DIS coded with your mileage
    C7.5 S6
    B8 A4
  26. #66
    May 11 2016
    CA
    I started my upgrade today but got stuck at radio amp unit. My Q5 has factory sat Sirius radio and all I find in back rear bracket is an Amp unit with rectangular plug but not trace of Sirius unit. Kufatec cable came with an empty quadlock and wires and no instruction on how to mount MMI radio in trunk. Do you have any pictures on how to get cable wiring for quadlock and fit in to MMI HD radio?
  27. #67
    May 11 2016
    CA
    Hi I am trying to upgrade from concert to MMI 3g plus and need help connecting Kufatec pink display wire 4 pin to back of MMI unit. There isnt any pink connector on back of MMI unit. Can you please help? I am also not getting display or key light up on console button near shifter.. What could be wrong?
  28. #68
    Feb 24 2013
    CA
    Bump, help him out lol
  29. #69
    Jan 20 2017
    RS7
    New Hampshire
    Just quoting so maybe you can assist.
  30. #70
    Nov 03 2014
    Markham Ontario
    I want to personally thank everyone for all the info on this thread. I have been wanting to do this since I purchased my 2010 S4
  31. #71
    May 11 2016
    CA
    Bump.. no activity..
  32. #72
    Nov 23 2015
    AV4NT.6MT.HPA.K04
    NH
    if somebody is planning to take on this mod, hit me up — i have a custom white LED gauge cluster that i’d like to sell you. it currently has the red DIS, so it’s a good candidate for the color DIS swap. the white LEDs were fitted to a stock a4 cluster to allow for white illumination of the gauge needles of white needles are fitted (like s4).
  33. #73
    May 11 2016
    CA
    Can you post pics?
  34. #74
    Nov 23 2015
    AV4NT.6MT.HPA.K04
    NH
    here is a pic of what it looks like in an a4 with color DIS, white needles, and my white LEDs
  35. #75
    May 11 2016
    CA
    Looks cool!! I am on 65k Miles and it’s on 54k not sure I can go with it. Pm me your asking price
  36. #76
    May 11 2016
    CA
    Btw I got my mmi 3g plus retro done and working with Google 3G. It’s was a bad 5F unit!!
  37. #77
    Jan 20 2017
    RS7
    New Hampshire
    Nice!! How long did it take you, total?
  38. #78
    May 11 2016
    CA
    Around 6 hrs split in two days
  39. #79
    May 11 2016
    CA
    DIY: Color DIS Retrofit and Concert to MMI3G Retrofit
    Now have mmi 3g kit for sale ..Sold!!!
