Page 1 of 4 123 ... LastLast
Results 1 to 40 of 136
    Rest in Peace Four Rings adam's rotors's Avatar
    B9SQ5 | B9S4 | HD FXLRST
    customizable, made-to-order B9 A4 & S4 adam's rotors NOW AVAILABLE!!!
    BUILD YOUR CUSTOM ORDER | MACHINE PATTERN, ZINC FINISH, HUB COATING, METALLURGY, & BRAKE PAD/STAINLESS STEEL LINE/FLUID PKGS.
    WWW.ADAMSROTORS.COM
    adam's rotors inc. started out small and remains that way...a tight knit, self-owned & operated company established & going strong since 2006.
    the small outfit and one-on-one interaction creates only the best service w/quick response & even faster made-to-order set-ups. with top notch products, this lends hand to our success thus far.
    working 24/7 throughout the day, any and all questions are answered within the hour to the best of our ability, if not instantly.
    being an online company we do business direct via email, instant message, PM, and over the web in our ever growing threads...we're always here ready to reply!
    we are a fully made-to-order, replacement disc brake, rotor manufacturer...we offer only factory fit, OE spec, plug n' play discs.
    WE CATER TO THE CAR ENTHUSIAST WHO NOT ONLY NEEDS NEW BRAKE ROTORS, BUT WANTS SOMETHING DIFFERENT BEHIND A NICE SET OF WHEELS.
    be it looks or performance, adam's rotors is the only company to bring you over 20+ machine pattern variations (most of which are exclusive to AR), 3 zinc finish offerings, and 5 ceramic-silica hub coating options.
    YOU PICK, WHAT YOU WANT AT AN ALL-INCLUSIVE PRICE | COMPLIMENTARY CORROSION PREVENTION, FREE SHIPPING, CHOICE OF DRILLING, SLOTTING, AND/OR DIMPLING, ALL LOADED INTO OUR WEBSTORE.
    adam's rotors expertise is in the VW/audi market, but do set-ups for ANY make/models car/truck/van…check to our store!
    WHY ADAM’S ROTORS? WE’RE DIFFERENT!
    because we do what no one else does. AR is a customizable product, having managed to turn a boring replacement product into something different. it's a have-it-your-way, made-to-order modification item ideal for any enthusiast. now, instead of just picking 1 of 1-3 drilled or slotted rotor styles from off-the-shelf inventory, we offer over 20+ patterns for your choice/taste, how YOU want them. after that pick a zinc for corrosion prevention...silver? gold? maybe black? thereafter you can even add one of our coated hub colors in a satin ceramic finish to finalize your set and truly give them polished, unique look. we now even offer upgraded metallurgy, to a stronger premium grade high carbon iron if you so wish. we at AR believe a rotor ISN'T just a plain ol' service part...rather a fun, custom, cool way to not only enhance the look of your car, but add performance, protection, and something different to your build, with a ton of bang for your buck!
    oh yeh...and they actually perform!!!
    track tested, endurance race team approved; check it out HERE.
    QUALITY, IT'S ALL IN THE DETAILS...
    we chamfer each drill hole and pay extreme attention to how we lay down our machining…taking meticulous measures to avoid each and every vent rib; the internal cooling veins in most modern vented brake rotors. AR will not drill a rotor we are unable to do so with and thus unlike most, never have issues. this is another reason why unlike many, we also offer dimples and unique slot patterns, ways of avoiding this and offering better, longer lasting, quality products when we see possible issues with venting. lastly each set is made for YOU without the limitations of pattern & finish pre-made, “in stock”, off-the-shelf parts have. instead, we start each order upon payment & cater to your needs/wants for your car.
    HOW IT WORKS:these are customized by you & made per order; you'll have them in about 2-3 weeks...
    (this takes in account ordering raw material, ship time to the shop, pattern machining, zinc finishing, hub coating & curing, packaging, & shipment pick-up!)
    we hold NO inventory & are held to the same final sale terms as our policy.
    we make ONLY factory fit replacement rotors to OE spec. plug n' play original fitment.
    whatever one-off size you may be after other than what your car came with, will need to be based off another application's rotor that already exists.
    in some cases, we can open up hub bore and modify bolt-patterns (within reason) but we need to discuss via email, first.
    YOU TELL US HOW YOU WANT THEM!
    1. dimpled
    2. drilled
    3. slotted
    4. dimpled/slotted
    5. drilled/slotted
    6. dimple/dimple/slot
    7. drill/drill/slot
    8. AR race (exclusive double slot)
    9. AR street (exclusive double slot/drill)
    10. AR track (exclusive double slot/dimple)
    11. AR sport I (exclusive over-dimple)
    12. AR sport II (exclusive over-slot)
    13. AR speed (exclusive multi-slot)
    14. AR dift I (exclusive triple curve)
    15. AR drift II (exclusive triple curve/slot)
    16. AR drag I (exclusive cross-hatch/slot)
    17. AR drag II (exclusive cross-hatch/double slot)
    18. NEW: AR sport III (exclusive radial dimple)
    19. NEW: AR sport III (exclusive radial slot)
    20. NEW: AR hex (exclusive honeycomb w/radial slot inner face)
    silver zinc, for brilliant rust-free finish is STANDARD on all orders, is a corrosion prevention process/measure, BUT...
    *COLORED ZINC FINISH:
    gold zinc or black zinc finishes are a subtle, unique, aesthetic touch for your rotors, very few offer!
    also...
    *HUBS COATINGS:
    this gives the rotor a nice clean, tailored, finished look.
    the rotor is still standard silver zinc dipped, with a high temp, satin, ceramic-silica finish.
    available in 5 colors…we can do some custom colors, so let us know what you need/want.
    or
    *G4000 HIGH CARBON IRON METTALURGY UPGRADE:
    we have started to offer a premium grade cast iron option, available for most all applications.
    standard grade G3000 is great and more than sufficient for most any use, but in some scenario's, a stronger iron is beneficial.
    reports of longer lasting rotors have been found, ideal for high mileage cars, haulers, or even heavy track goers who really beat up their brakes.
    it also greatly reduces the worry of pad squeal in cases of high friction with high performance brake pads.
    the harder iron is stronger and fights warping and cracking concerns, and higher carbon & chromium levels aid in oxidation resistance.
    another great benefit to the G4000 upgrade, is the price includes a premium black coating on the rotor at no charge.
    WWW.ADAMSROTORS.COM
    ONE (1) YEAR exchange warranty for:
    manufacture defects (cracking) per rotor...on all orders!!!
    EVERY ORDERS IS FINAL-SALE, ONCE PROCESSED | NO EXCEPTIONS.
    again, we hold NO inventory & are held to the same final sale terms as our policy.
    if there is EVER any issue with fitment/error on OUR end, we will ALWAYS make it right!
    AR EXCLUSIVES-
    *NEW: AR sport III & IIII [radial dimple & radial slot] & AR hex [honeycomb w/radial slot inner face]:
    [must be ordered with coated hubs]
    AR drift I [triple curve] &
    AR drift II [triple curve/slot]:
    AR drag I [cross-hatch/slot] &
    AR drag II [cross-hatch/double slot]:
    coated hubs]
    AR sport I [over-dimple] &
    AR sport II [over-slot]:
    coated hubs]
    AR race [double slot] &
    AR street [double slot/drill]:
    coated hubs]
    AR speed [multi-slot] & AR track [double slot/dimple]:
    coated hubs]
    adam | adam's rotors inc. | [email protected] | est. 2006
    customizable factory-fit brake rotors, made-to-order | adamsrotors.com
    follow/like/@/tag @adamsrotors on twitter, instagram, & facebook | #adamsrotors
    Active Member One Ring Bio][azard's Avatar
    Aug 20 2016
    St Louis, MO
    Way cool!
    What brake pads do you recommend for B9 track use?
    our offering is here w/breakdown on each and why: www.adamsrotors.com/pads
    killer shot from a customer, sporting Neuspeed wheels over their AR Drag I's:
    opening up your AR shipment is like Christmas no matter what time of year...
    sport II's:
    brandy-wine. new coating options coming soon...email us now if interested in pre-release:
    what a month that was...here's to the last one of 2016!!!
    Christmas presents that come in 4...you can't go wrong!
    custom machined to order, in house how you want them!
    -made-to-order, per customer, per corner
    -17+ CNC'd patterns
    -unique zinc finishes
    -custom hub coatings
    -chamfered dimples & drilling
    -double ground rotor faces
    -machine balanced discs
    -high carbon content metallurgy upgrade
    -premium one-to-one small business service
    factory fit brake rotors unlike anyone else!
    happy new year!
    a little insight on adam's passion project!
    with over 3 days of filming, everything you could possibly imagine go wrong, hard work, and months of editing, here is our full length, short film by Layer Media x adam's rotors inc.
    we're excited for everyone to see & let us know what you think.
    www.LayerMedia.com | @layermedia
    www.adamsrotors.com | @adamsrotors
    the new project is here:
    stumbled upon this photo from over 7 years ago, of a prototype pattern we did for an old school build, that was never released.
    ...should we bring it back to life?
    follow us on IG: @adamsrotors
    hope everyone had a great weekend!
    back to our roots! the adam's rotors D4 A8L:
    TGIF!!!
    Account Terminated Four Rings
    Sep 13 2014
    New York
    Are your rotors as robust as the factory rotor? Not looking for a weight savings.
    they are...infact most of the time, stronger.
    we're not a light weight company, but a positive effect from machining patterns, is natural weight loss, tho marginal.
    as posted in our FAQ's:
    "do adam's rotors weigh less?"
    yes, but we don't advertise as a lightweight alternative because the difference is marginal. but yes, they are lighter.
    unless you're a true race driver and this car only sees the track, noone out there can truly feel/utilize this "unsprung" weight with brakes on a daily driver that people have argued for ages. more importantly, it is hardly worth the extra money for these costly discs or the severely shorter lifespan of 2-piece LW alternatives for that matter. the blanks weigh less than stock blanks as is and after machining, even less of course. drilling takes about .75lb from the fronts and about .5lb from the rears. slotting takes half that amount. drilled/slotted variations are somewhere between those two give or take and a bit more when we look at our own patterns.
    Sep 13 2014
    New York
    I didn't see the s4 or s5 on your website drop down menu. Any info on price? Any idea when a low dust pad will be available? I prefer Hawk hps or hps 5.0. I don't want to loose any initial bite.
    ^ not sure what you mean...we do and sell them all the time. what year are you searching?
    shoot us an email.
    and we off our POSI-Quiet option for years and have had great luck with it: www.adamsrotors.com/pads
    Sep 13 2014
    New York
    New S4 and S5 are different size rotors then the B 8.5 cars. Calipers , hence the pads are different as well.
    I will be passing on this from your company.
    asking for specifics on your search sir. let us help you.
    I want to recreate your problem with our webstore. tell us what year you are searching and I can get to the bottom of that first. pads we can address thereafter.
    Sep 13 2014
    New York
    You posted here in the 2018 Audi s4 forum. These are brand new different rotors and pads then the previous generation. 2018 s4 and s5 use the same brake system. What are you trying to sell customers? The old generation parts? Very disturbing on your part.
    we've been in business here on audizine for 11 years and started this company on these very forums...you need to calm down and stop jumping the gun my friend...I'm trying to figure out what you're experiencing and why on our site. if you took a second to answer our question and provide more info, instead of trying to shame us for a misunderstanding we could help. we're not "trying" to do anything but help you. we make what you need, factory fit and gurantee fitment. I want to fix the site for you. I'll have my webmaster work on his tomorrow, thanks!!!
    Veteran Member Three Rings yb28's Avatar
    Mar 06 2013
    2017 B9 A4 2.0T Quattro DSG , 2017 Q5 2.0T Quattro TIP
    Toronto, ON
    ygpm
    2017 B9 A4 2.0T Quattro S Tronic | Daytona Gray | Xenon to LED Headlights Conversion | Custom Brembo 8 pot BBK |
    Build Thread
    2015 B8.5 A4 2.0T Tip Black
    2003 B6 A4 1.8T Tip DG
    B9A4's, use 2017 for now...
    our database, which is the industry standard Autocare, simply hasn't added the 2018 model year for A4's. it's out of our control.
    =click HERE to order=
    B9S4's are the same fit/price as previous generation, so you can do the same...pricing is current & loaded.
    we will of course update this as soon as we can, but we at least have A4's up now for the new chassis. use the order notes for more einfor and we'll of course get you what we need, being made to order.
    thank for your patience & understanding!
    before and after of out brilliant silver zinc bath, complimentary (FREE!!!) on EVERY G3000 AR order placed!
    (sport II's | over-slot)
    how was everyone's memorial day weekend?
    the AR D4:
    it's the first day of summer but we've been feeling it here in the office for over 2 straight weeks of 100-110 degrees!!!
    working on a new website...v3.0 coming soon!
    hope everyone had a great 4th and a short week!
    AR track | [double slot/dimple]
    Jun 27 2017
    Brutale 1090, BMW 535ix
    Minneapolis, MN
    Quote Originally Posted by Adam@SPP View Post
    Do you have pads for the 2018 s4?
    we can get them, yup!
    getting closer to our adamsrotors.com v3.0 release!
    how often are you on your phone/tablet, browsing automotive sites & retailers?
    is mobile friendly important or do you typically surf/shop at a desktop?
    Sep 13 2014
    New York
    Where are these low dust pads for the s/4 or s/5. Nobody has them yet. Where are you supposedly getting them from?
    POSI-Quiets are available when in stock. email us please.
    Sep 13 2014
    New York
    That’s not an upgrade
    ^ it absolutely is. OEM compounds are inferior to anything we offer...we've offered POSI's for years on all models in the Audi line-up and run them on our own cars.
    you sound combative & snarky; please keep scrolling or email us directly as requested, as not to clutter up out sales thread with it, thanks!
