Results 1 to 15 of 15
    Registered User Four Rings CTS Turbo's Avatar
    Nov 12 2008
    01 S4, 04 A4, 15 GTI, 15 S3
    Vancouver
    BorgWarner K04-015 Turbos - In-stock & On Sale!
    Original Borg Warner K04-015 Turbos - In-stock & On Sale! $949.99 Shipped in the continental US
    CLICK HERE TO ORDER
    Great bolt on performance upgrade, can be used with or without specific programming (only on stock ECU without stage 1, etc).
    The K04 is a straight bolt on turbo that can be used for multiple different reasons. Flows more volume than the standard K03. Can sustain higher boost pressures than the K03. Great replacement turbo if your K03 has gone bad. Can be used without any special programming although specific K04 programming is recommended to extract all potential power from the K04
    If there are any questions, comments or to place an order you can PM or email me at [email protected]
    Nov 12 2008
    Vancouver
    TTT
    Nov 12 2008
    Vancouver
    TTT
    Dec 25 2004
    Earth
    Whats the country of manufacture on the ones your selling? Made in ??? Thanks
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Aug 19 2013
    minnesota
    Diesel porformance in Minnesota has bw ko4 for half that...
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Veteran Member Three Rings Andy_FL's Avatar
    Mar 01 2004
    South Florida
    Quote Originally Posted by jacobsen View Post
    A BW K04 for $500? - please post that link!
    Established Member Two Rings alexb6t's Avatar
    Mar 11 2016
    quebec canada
    Quote Originally Posted by Andy_TN View Post
    Rebuilt probably,but if new i'll take 2 lol
    Sent from my SM-G903W using Tapatalk
    Dec 25 2004
    Earth
    Really? A URL to their website would be nice...Thanks
    Aug 19 2013
    minnesota
    Quote Originally Posted by MikTip View Post
    I just called them when I needed one.
    They're in burnsville.
    Dec 25 2004
    Earth
    https://www.dieselcomponentsinc.com/
    Aug 19 2013
    minnesota
    Yeah that's the one
    Apr 03 2016
    Up North
    Thanks for the heads up jacobsen! Even if they were more expensive than CTS I'd buy it from them simply to not have to deal with CTS...
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Are you positive its a genuine BW? Ive never seen one that cheap, anywhere, ever.
    2019 SQ5 Prestige
    Aug 19 2013
    minnesota
    Quote Originally Posted by texasboy21 View Post
    It's got a bw k04 badge
    Senior Member Three Rings crazyquik22023's Avatar
    Jan 30 2012
    Brunswick, Ohio
    I'm sure it's a rebuild
