Results 1 to 13 of 13
    Veteran Member Four Rings jonan's Avatar
    Nov 25 2006
    2X B7 RS4 - STG III B6 A4 (gone, but still in the family) - Mini R56 S - '15 Macan S - 997.1
    Austin, TX
    URO timing belt damper
    so i was going through my order history on ECS tuning and noticed that the last timing belt kit i ordered had an URO timing belt damper...the tensioning roller is NTN, OEM audi water pump and continental belts...
    i looked because i ran across a few threads on other forums that said URO parts were crap...does anyone have any experience or ever hear of an URO timing belt damper failing prematurely??? i changed it last year and only have around ~5,000 miles, if that, on the new parts...
    here is the part i am referring to...
    https://www.ecstuning.com/ES2535081/
    Want my guns??? ΜΟΛΩΝ ΛΑΒΕ!!!
    B6 Mods:
    Fully Built Motor w/ GT2860RS and all supporting mods : My Build Thread
    RS4 Mods (sprint):
    RNS-e MKII : ECS SS : JHM Spacers : Deflapped IM : UM Tune : KW V3s : Tubi Rumore : Hotchkiss F&R SBs : 034 Diff Inserts : Phil Special Headlights w/ STI Lenses : 10 Layers : Spare 07BNS (#masterrace) : Apikol Diff & Trans Mount
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    URO parts do not have the best reputation from what I've seen. Never had a personal experience though. If you are concerned, order a new tensioner and swap it out. Should be fairly easy to do.
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    not as a recommendation, but every time i've done a full timing belt water pump etc job i've used ebay chinese parts. Chain Tensioner was the only one that ever gave me issues, all else worked flawelessly.
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    ÜRO parts = garbage
    NTN is where its at. Just order your timing kit from integrated engineering. They wont sell you any junk.
    Audi Club Bay Area
    Oct 02 2006
    Wadsworth,OH
    Our kits no longer use a URO belt damper. They come standard with a Febi damper. You are more than welcome to have any one of the parts in our kit swapped out for any brand we offer, just give our sales staff a call and they'll take care of you.
    Jason
    Veteran Member Three Rings tHatOne guY's Avatar
    Aug 20 2012
    06' Yamaha R1...Raven
    Mesa, Az
    Maybe the next time you do the cam belt job try changing up to the newer style tensioner, just easier to install really.
    Dec 19 2013
    Jason
    Thats good customer service right there !
    Audi Club Bay Area
    Oct 02 2006
    Wadsworth,OH
    Jason
    Veteran Member Three Rings 5ktq's Avatar
    Aug 15 2016
    Western Canada
    Yeah, timing belt components are an area you really don't want to cheap out on. Last time I bought a tensioner I spent an extra.. $10 or so for an INA one, I wanted German quality.
    Opened the box and it was made by NTN in Japan anyway - still a reputable company. I guess INA doesn't actually make them and just sourced them. But had I know that I could have ordered NTN for $10 less!
    Apr 03 2016
    Up North
    URO is total crap. I bought one of the ECS kits with that tensioner. It lasted 28,000 km. Nothing like having to do the job all over again at 1/4 of the service interval. Not fun at all on a transverse 1.8t. I don't buy anything but OEM parts now... I'd love to put some blame on ECS for packaging that POS in their kit, but it is my fault for not doing my homework before buying. Plenty of folks on Vortex dissing URO when I looked after the fact. Same thing you discovered apparently.
    Personally I'd change it out. My engine was saved by pure luck. It had jumped two teeth by the time I realized it had gone bad...
    Nov 25 2006
    Austin, TX
    is it normal for the tensioner to sit so closely to the damper?
    i'm not sure if the tension in the belt fluctuates at all...there doesn't seem to be much play, is pretty snug and it doesn't make any weird noises while running...
    B6 Mods:
    RS4 Mods (sprint):
    Nov 02 2007
    SF Bay Area, CA
    from what i can tell nothing looks out of place in the above picture in regards to tensioner. your engine is quite dirty behind the timing belt though. are you not running the upper cover? or have you battled with valve cover oil leakage?
    Nov 25 2006
    Austin, TX
    lol, that's just 13 years of built up crude, coolant, dirt and oil from my old VC gasket that was leaking before i changed it...i run with the cover on and just removed it to inspect it when i took that photo...(plus i was being an ass and pouring oil in without a funnel and missing the fill hole)
    B6 Mods:
    RS4 Mods (sprint):
