APR has recently reintroduced a legacy product, but with a twist which means the elusive R1 diverter valve is getting a facelift. The R1 started as an investment cast construction, this has since morphed into a milled modular billet assembly. With this release Excelerate Performance has found some extra stock of the Cast version. We are blowing these out at 10% off for the remaining 15 units.
Product Info:
The APR R1 Diverter Valve is a critical performance upgrade recommended at all stages of performance as it replaces the failure prone factory unit.
The R1 is designed withstand extreme boost pressures at the highest levels of performance, while offering lightning fast response thanks to the unit’s friction-free diaphragm-based design.
Unlike piston based units that can stick and bind in the winter, the APR R1 is virtually maintenance free, requiring no greasing or o-ring replacements, as is common with other units.
Cast housing with a high-temperature Nomex-reinforced diaphragm, the R1 is designed to be the last DV upgrade the engine will ever need!
Click here to view the sale price on this product!
