Results 1 to 24 of 24
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    ::EXCELERATE PERFORMACE:: APR Products In Stock!
    Fresh pallets of APR products to re-fill the warehouse!
    APR K04 turbos
    Down pipes!
    Always software!
    We carry most of the APR product line. Let me know how I can assist you!
    Check Us Out on Social Media!
    Feb 14 2014
    Audi's
    Branford, CT
    B8 A4 APR cast downpipes in stock!
    • More power and less turbo lag
      +40-47 HP & +36-45 FT-LBS over APR Stage
    • Full 76mm downpipe system
      Say goodbye to the tiny, kinked, 60mm tubing and chambered resonator.
    • Bell-mouth investment-cast downpipe inlet
      Ultra smooth cast inlet for unmatched performance.
    • GESI High-flow catalysts
      Strong and reliable catalyst, which reduces emissions, smell and noise over catless setups without the performance hit.
    • T304L stainless steel construction
      Premium grade materials to resists corrosion and stands the test of time.
    • Argon back-purged TIG welding
      Clean, strong and attractive welds both inside and outside the pipes.
    • OEM-style low-profile slip-on clamps
      Easy to install with tons of clearance. Resists leaks and doesn't deform the pipe.
    • OEM-style internally-corrugated flex section
      High flow without the failures common with braided setups.
    • Investment cast secondary oxygen sensor bungs
      A perfect fit that doesn't protrude into the pipe.
    • Compatible with the OEM catback exhaust
      Bolt-on and go.
    • In-house design, assembly and quality control
      All critical aspects of the system are handled internally to ensure the highest quality fit and finish.
    • All hardware and instructions included
      All included for a headache free install.
    • Limited lifetime warranty
      The best system with the best warranty.
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    Best mod!.. love mine!
    Sent from my Nexus 7 using Tapatalk
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Senior Member Three Rings burg3ngold's Avatar
    Apr 13 2016
    Washington DC Area
    Pm for k04 price?
    Sent from my ONE A2005 using Tapatalk
    Veteran Member Three Rings Roadtrippn's Avatar
    Sep 15 2011
    Hilton Head Island
    What are the chances this sucker bolt up to the CTS k04 turbo?
    18' RS3 Stage II and all the Fixn’s
    2011 A4 2.0TQ 6MT Stage III
    2001 A4 Stage II
    Sep 03 2012
    Lehigh Valley, PA
    Quote Originally Posted by Roadtrippn View Post
    It should!
    Feb 14 2014
    Audi's
    Branford, CT
    You bet it bolts right up!
    Feb 14 2014
    Audi's
    Branford, CT
    Quote Originally Posted by burg3ngold View Post
    Pm for k04 price?
    PM sent!
    Sep 09 2010
    Destin, FL
    I don't think so. They have their own HFC with an angle in it to account for their turbo setup.
    - - - Updated - - -
    Quote Originally Posted by Excelerate Rep View Post
    Might want to look into that before telling customers the wrong info.
    Feb 14 2014
    Audi's
    Branford, CT
    We have intakes in stock as well!
    The APR Carbon Fiber Intake System is an attractive high-performance upgrade designed to increase performance by letting the engine breathe more freely.
    The factory intake design has the foundation for excellent performance, but much of this is sacrificed in an effort to meet other design requirements. With requirements set forth for only supporting factory power output levels, low engine sound levels and long service intervals, there is plenty of room for improvement.
    The APR Carbon Fiber Intake System increases performance primarily by improving mass airflow through the system while still proving adequate filtration. Expect greater horsepower and torque through the power band with a more direct and responsive feel upon pressing the throttle. Sounds from the engine and turbocharger are enhanced and some may even experience better fuel economy depending on driving style.
    Feb 14 2014
    Audi's
    Branford, CT
    Do not forget we do no appointment flashing and no labor charges for new APR flash customers.
    Sep 03 2012
    Lehigh Valley, PA
    Quote Originally Posted by The Infiltrator View Post
    - - - Updated - - -
    I didn't realize their k04 turbo outlet was slightly different, and not a factory ihi placement...
    Feb 14 2014
    Audi's
    Branford, CT
    Quote Originally Posted by hyperunion View Post
    Neither did we, that is interesting info. Standing corrected. Thanks infiltrator!
    Sep 09 2010
    Destin, FL
    Feb 14 2014
    Audi's
    Branford, CT
    We still have many APR products in stock and ready to ship!
    Sep 03 2012
    Lehigh Valley, PA
    Now you did show a picture of their test pipe... Not necessarily a high flow cat... I know of some people using a 034 high flow cat with the CTS k04. which utilizes the factory midpipe .. if that's the case the CTS ko4 still is the same factory position .. then the apr hfc dp should bolt right up... As you see by this pic the test pipe is designed to work with the factory midpipe.
    Sep 09 2010
    Destin, FL
    Call them, they will tell you.
    1-604-530-3092
    Sep 03 2012
    Lehigh Valley, PA
    So I guess the CTS ko4 option is out for apr dp owners... Apr's k04 kit would be the only way to go.. with no additional charge for the k04 programing... And a 500 charge if someone did have the CTS k04 kit...
    Nov 23 2009
    NYC, US
    Are you guys far from NYC?
    How much is for the k04 turbo conversion on a 2010 A4? What parts do I need in addition to the turbo kit?
    How much does the labor cost for the complete conversion?
    Feb 14 2014
    Audi's
    Branford, CT
    Quote Originally Posted by AutoRacer100 View Post
    Depending where in the city it can be as little as an hour but with traffic lately, you might sit on 95 of the Merrit. We are on average 1.25-1.5 hours to NYC.
    Let us know and we can work up a quote for you.
    Feb 14 2014
    Audi's
    Branford, CT
    Once again its monday!
    We still have many APR products in stock and ready for new homes.
    Thanks,
    Alex
    Feb 14 2014
    Audi's
    Branford, CT
    You read it right! no labor charges on APR software and no appointment needed. Contact me for more information:
    [email protected]
    Or shoot me a PM here!
    Thanks,
    Alex
    Feb 14 2014
    Audi's
    Branford, CT
    WEBSTORE
    For a limited time we are offering up to 5% off on select APR products by using the promo code GOAPR on our VAG store. Promo code discounts vary per product and cannot be combined with any other offer.
    Click here or the image below to experience the online shopping experience with Excelerate Performance. Many APR products are in stock and will ship the same day.
    If you want to determine exact stock status we encourage you to contact us.
    Feel free to contact us via Live Chat, email at [email protected], or phone at 203-483-6100. We are here to answer questions! Thank you.
    If you would like to know more either call
    203-483-6100
    E-Mail
    [email protected]
    Or, check it out online
    http://vag.excelerateperformance.com/products?bid=13716
    Feb 14 2014
    Audi's
    Branford, CT
    These might not be in stock anymore but we have more then enough APR products in stock for other applications!
    Thanks,
    Alex
