Hey to all audi guru's and tech's anybody know how to or have solved a rough idle after coing to a stop ,note very slight rough idle no check engine lights ,misfires readings are ok ,could this be fuel pump related or aftermarket fuel filter related ,fuel filter been the 2port in and 2port out type ,or could it be wiring ,ecm issue ,throttle body issue ,please help all response welcome. UPDATE INFO ,I HAVE REPLACED PLUGS ,FUEL FILTER [NOT OEM TYPE] ,MASS AIR FLOW SENSOR [MAF] ,SWAP OUT COILS ,PCV VALVE AND CHECK VALVE ,VALVE COVER GASKETS PLUS SO MUCH MORE ,SO MY ONLY OTHER THING TO CHECK IS MY FUEL FLOW AND VOLUME RATE AT IDLE ,AND THATS WHERE I NEED THAT INFO FOR THE 4.2L V8,SO ANY AUDI TECHS OUT THERE WITH THAT INFO I WOULD SURE APPRECIATE THAT INFO .further update just check my fuel filter and it is the wrong filter bought from eBay for cheap and did not come with the fuel pressure regulator built into it I checked part number at dealer so I ordered original filter ,when installed I'll update on cars performance after install .so i feel with this the fuel is leaking down from the rail when at idle causing the rough idle ,I hope this solve my issue tho .UPDATE FIX ,so today I went to my dealership and pickup and install my Audi original fuel filter with fuel pressure regulator built into it ,and upon startup I know my issue was solved ,it idle so smooth ,I took it for a road test drive and I was smiling all the way ,so my idle when stop is gone ,I guess the first filter that a got on the car when I bought it was bad and then I got a eBay filter which just confused the hell out of me thinking it was engine related idle issue but just replacing with factory filter making sure part number was correct solved my problem so hope this help others out there ,good luck.
